  Flywheel
Flywheel by ThomasB
Started on: 07-31-2016 08:20 PM
Replies: 13 (561 views)
Last post by: Bruce on 08-03-2016 12:49 AM
ThomasB
Report this Post07-31-2016 08:20 PM Click Here to See the Profile for ThomasBSend a Private Message to ThomasBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey guys i was wondering if the fkywheel from an 88 Fiero will fit ( work ) in an 87 ?
Report this Post07-31-2016 08:26 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
No... the '88 Fiero 2.8 flywheel is balanced differently than the '85-'87 ones.
ThomasB
Report this Post07-31-2016 08:29 PM Click Here to See the Profile for ThomasBSend a Private Message to ThomasBEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very cool Thanks!!!
ThomasB
Report this Post07-31-2016 08:30 PM Click Here to See the Profile for ThomasBSend a Private Message to ThomasBEdit/Delete MessageReply w/QuoteDirect Link to This Post
ThomasB
Member since Apr 2016
Hey Patrick any idea where i can get a new flywheels for my 87 GT ? I'm on Vancouver Island Thanks!
Report this Post07-31-2016 09:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
In over 20 years of owning and maintaining Fieros, I've never had to replace a flywheel. Dare I ask what has happened to your current one?
[This message has been edited by Patrick (edited 08-01-2016).]
ThomasB
Report this Post08-01-2016 01:32 PM Click Here to See the Profile for ThomasBSend a Private Message to ThomasBEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought the car with severe clutch slip. The flywheel is burned blue and has chatter marks all over it just thought with replacing all the other components i would replace the flywheel as well.
Report this Post08-01-2016 02:20 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The flywheel is burned blue and has chatter marks all over it...
Is it worn/damaged beyond simply being resurfaced?
David Hambleton
Report this Post08-01-2016 02:22 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hmmm... common sources show only '88 flywheels.
http://www.fierostore.com/P.../Detail.aspx?s=54020
https://www.rockauto.com/en...manual,flywheel,5348
[This message has been edited by David Hambleton (edited 08-01-2016).]
Blacktree
Total ratings: 350
Report this Post08-02-2016 09:24 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm with Patrick on this. Since new flywheels aren't readily available, your best bet would be to resurface your existing flywheel (and shim it, if necessary).
lou_dias
Report this Post08-02-2016 12:25 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
AFAIK, you can use an 88 flywheel on 'older' engines but they are heavier by 3 lbs and that's why 88's make slightly less hp...
The issue is with pre-88's the rotating assembly gets balanced by adding weight to the flywheel (externally balanced). 88+ engines have all their internal rotating assembly components balanced already (crank, rods, pistons). If you rebuilt your engine and had it fully balanced, you can use the 88 flywheel no problem.
[This message has been edited by lou_dias (edited 08-02-2016).]
edfiero
Report this Post08-02-2016 03:55 PM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
FWIW I had planned to replace the flywheel on my 84 with 165k miles when I did my engine swap, but too my surprise a bit of wire brush action and some 1000 grit sand paper, made my flywheel look like new.
Report this Post08-02-2016 04:25 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by edfiero:
165k miles... too my surprise a bit of wire brush action and some 1000 grit sand paper, made my flywheel look like new.
That may have made the flywheel look all nice and shiny, but I doubt very much you removed any high spots. Your flywheel wouldn't have been completely flat. IMO it's a big mistake not to resurface a flywheel when replacing the clutch disc.
Watch the video below and notice how the flywheel surface doesn't get cleaned up all at once. It takes awhile to remove areas of the flywheel which haven't been worn down (as much) by the clutch disc.
viperine
Report this Post08-02-2016 06:08 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had a burned flywheel turned once, I had myself convinced that the hot spots would be too deep and result in a resurfaced product that wasn't thick enough. I turned out to be quite wrong and was very happy with the results from the machine shop. Secondly, most clutches demand a new or resurfaced flywheel or else the warranty is voided in the event of clutch failure.
Bruce
Report this Post08-03-2016 12:49 AM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
NAPA carries a weighted flywheel for $59. Just look it up under "NAPA," but it has to be back-ordered.
b
