I have a VDO gauge set I am installing in my Mera. The tach will not work as is with the RPM signal from the Series II ECU.
I did some research, LS1 guys have the same problem, and found an easy fix. The tach needs a pull up resistor wired between the 12V lead going to the tack and the signal lead.
A 1K 1/2 watt resistor did the trick, couple of bucks at Radio Shack instead of a more complicated remedy.
The VDO tach reads the same as the RPM shown on an OBD II scanner.
http://ls1tech.com/forums/c...lessons-learned.html
