  supercharged 2.8. Give me your opinions/ideas! (Page 3)
supercharged 2.8. Give me your opinions/ideas! by Boot
Started on: 09-06-2016 06:37 PM
Replies: 110 (3060 views)
Last post by: BillS on 12-30-2016 11:13 AM
Boot
Report this Post09-12-2016 06:49 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
So Im having trouble procuring a big enough pulley for the blower... The best alternative I can think of isnt nearly as efficient, but it would be extremely simple and easily adjustable.
Basically, I would run a pipe with an adjustable valve from the manifold post supercharger to the adaptor Ill be making thats between the supercharger and throttle body.
Ill be able to open this valve just enough to keep the pressure where I want it, and instead of releasing the excess pressure to the atmosphere itll keep it in the system. That way its accounted for by the throttle body. My thought was that if the air thats already been accounted for get released into the atmosphere the air/fuel ratio will be all wrong. This way itll just get sucked in by the supecharger again, and the ratios will stay correct. This will be a serious loss of efficiency but who really cares at this point. Itll take 10hp to run the blower, and about 3 to move its extra weight along with that of the adapters. 6psi of boost should add at least 50-60hp so itll still be a huge performance increase.
Thoughts?
pmbrunelle
Total ratings: 63
Report this Post09-12-2016 08:33 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is already a pneumatically-actuated boost bypass valve on the supercharger. You can control it by applying PWM to the control solenoid.
I don't think it's meant for controlling boost at WOT...
But just get the right pulley sizes already. If you can't figure out how to get appropriate pulleys, you're in over your head, and something else in this complicated plan will stop you instead.
The throttle body is not an air measuring device; feel free to bleed out any air that has gone through it.
What you don't want are leaks downstream of a mass airflow sensor (MAF). Will you be using a MAF? Probably the ideal would be to grab the 3800 ECM, trigger wheel and peripherals... the longevity is all in the controls. Obviously it will be easier to tune/adapt controls that worked with a supercharged engine from the factory.
Boot
Report this Post09-12-2016 09:30 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh geez im an idiot. All the cars Ive ever had have had MAF sensors built into the throttle body.. I totally forgot the fiero has a map sensor instead. I guess Ill just have to plug the vacuum line for the map sensor in before the supercharger inlet. Probably in the same place as I was going to put that valve. Yeesh. I cant believe I actually thought that all through without realizing theres no maf sensor
[This message has been edited by Boot (edited 09-12-2016).]
fierosound
Total ratings: 286
Report this Post09-12-2016 11:44 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually, you'd want a 2 BAR MAP sensor on the pressure side and change your PROM program setting to 2 BAR.
Boot
Report this Post09-12-2016 11:55 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Okay. I see why Id want to do that. But just out of curiosity, why wont the regular map before the blower work? Wouldnt the manifold vacuum still reflect the amount of air going in?
pmbrunelle
Total ratings: 63
Report this Post09-13-2016 12:09 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you leave the boost bypass valve shut all the time, then you could connect your existing 1 bar MAP sensor pre-supercharger, but post-TB. This would not be reading the plenum pressure, but you would be reading something repeatable that could be used as the basis of a tune.
However, if you are going to twiddle around with the boost bypass valve, then the plenum pressure will not be a strict function of the post-TB pressure. The plenum pressure will also depend on whether the boost bypass valve is open or closed.
In this case, you should use the 2 bar MAP sensor plumbed to the plenum.
Boot
Report this Post09-13-2016 02:55 AM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
But if any boost that was bypassed was put back into the chamber with the map, wouldnt that adjust the pressure to reflect whats actually going into the engine? The air would get sucked back into the SC instead of being released to the atmosphere. Im thinking say screw the built in bypass and build a manual one myself. Itll be an adjustable valve, not just an open/closed one. This valve will then be adjusted so that at WOT I max out at 7lbs of boost, and left at that setting. So the percentage of the boost pressure that escapes through the valve will be a constant as well.
[This message has been edited by Boot (edited 09-13-2016).]
pmbrunelle
Total ratings: 63
Report this Post09-13-2016 08:48 AM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I wouldn't trust anything but a positive displacement blower to be remotely consistent, but you decide for yourself...
I guess in the stock ECM, you'll get power enrichment above 0.8 bar absolute manifold pressure (or maybe it's TPS)???
If you want to duplicate this behaviour, how will you relate the pressure post-TB to the plenum pressure?
You should wipe all the tables (make a backup) of your stock ECM clean, and tune the engine from zero. The exercise of tuning the N/A engine will serve as forgiving training to teach you how to later tune the supercharged engine. Furthermore, this exercise will allow you to become familiar with what the Fiero ECM can and cannot do; which may drive decisions such as 1 bar or 2 bar MAP. You may even decide the Fiero ECM is not adequate.
[This message has been edited by pmbrunelle (edited 09-13-2016).]
Blacktree
Total ratings: 350
Report this Post09-13-2016 10:10 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correction: you SHOULD decide the Fiero ECM is inadequate for this... because it is. The electronic controls will most likely be what makes or breaks this engine, literally. At the very least, I'd suggest a GM 7730 ECM with turbo code, and a 2-Bar MAP sensor. It would also be a good idea to get a wideband O2 sensor for data logging.
Boot
Report this Post09-13-2016 05:29 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thats what this is, isnt it?
Also whats involved in swapping to the 7730?
pmbrunelle
Total ratings: 63
Report this Post09-13-2016 06:35 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The blower is consistent, but I'm not sure the bleed air would be consistent.
Don't just look at 7730 in GM ECMs. You should consider the 3800 ECM as well.
Also, instead of trying to reverse engineer other people's crap, you could buy a standalone ECU that's actually designed to be tuned by the end user.
I don't have the patience for trying to decipher hacked stuff that doesn't quite fit, so I run a MegaSquirt computer on my 2.8.
dobey
Total ratings: 371
Report this Post09-13-2016 11:02 PM Click Here to See the Profile for dobeySend a Private Message to dobeyEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would not try to retrofit a 2.8 to be able to run off the 3800 PCM. IF you want to go that far, you should just swap in a 3800 and be done with it.
Boot
Report this Post09-14-2016 12:32 AM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I get serious about this car that will be my first investment.
I have no idea what Im doing, but Im doing it.
RotrexFiero
Report this Post09-20-2016 08:28 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any progress here?
Boot
Report this Post09-22-2016 04:30 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RotrexFiero:
Any progress here?
Yup, I finally just figured out how Im making the manifold adaptor the other day. Its rather difficult to explain, but Ive been recording my progress and Im going to upload a video on youtube when its done. Progress is just going to be slow, because after a rather unfortunate turn of events the Fiero is now my daily. So before I actually take it apart I need to come up with another daily for obvious reasons.
Thanks!
Blacktree
Total ratings: 350
Report this Post09-22-2016 05:55 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ouch, that sux. Best of luck, man.
Boot
Report this Post09-27-2016 06:03 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Quick update... I'm still dailying the Fiero, but since I bought the extra manifold I can keep working some anyways!
So I was having a hard time figuring out how I was going to make spacers that would let me use the original bolt holes on the manifold. It looked like it was just going to be a b*tch and there was nothing I could do about it, until I had a small stroke of genius. Why not drill out the holes on the manifold, and use studs with nuts on the bottom instead? That way I could just use this 2x3ish square tube I had around and just weld bolts to the inside for the studs.
As you can see I had to do some ghetto machining on the drill press with a special drillbit I made, and some clearancing with the death wheel in order to get the nuts to sit flat against the manifold because it wasnt meant to have nuts on that side. Its sort of ugly but it works.
I just took these screencaps from the last video I made. Its all going to get put together into a short film on youtube that goes through the thinking I did to make this thing work... For under $200 Ghettocharging at its best!
Next up is making the plate to bolt the supercharger to, and the stuff to mate it all together.
Total ratings: 463
Report this Post09-27-2016 07:27 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Boot, if you can keep the file size below 300 kb, your images will display without the need to click on an icon.
Boot
Report this Post09-27-2016 07:48 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im doing this all from my phone, so I dont really have a way to do that
Total ratings: 463
Report this Post09-27-2016 08:48 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Im doing this all from my phone...
Well, that's a silly way to be doing it.
Neils88
Total ratings: 55
Report this Post09-27-2016 09:47 PM Click Here to See the Profile for Neils88Send a Private Message to Neils88Edit/Delete MessageReply w/QuoteDirect Link to This Post
You should be able to set a lower resolution on your phone under your camera's app settings.
jscott1
Total ratings: 415
Report this Post09-29-2016 02:37 AM Click Here to See the Profile for jscott1Send a Private Message to jscott1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The whine of the supercharger combined with the growl of the 60-degree V6 sounds awesome!
Definitely. The 60 degree V6 sounds way better than the 90 degree V6.
RotrexFiero
Report this Post09-29-2016 08:06 AM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
My turbo 3.2 sounded the best. Like I mentioned, I never could get a good idle out of it, so at lights I would always be blipping the throttle. I was sitting at a light once, doing such, and I found myself next to one of those magnum Hemi things. I did not want to race, but pulled out quickly. He never gave pursuit. I would get all kinds of crazy looks and I guess it was pretty intimidating. But, that happened a lot.
The thing is with most cars, if you have a little knowledge, you know what's under that hood. With a Fiero, or a real hotrod, you never know. Especially when the engine is looping, huffing and puffing.
Report this Post09-29-2016 02:04 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero ECM can be programmed to work with boost. You will need to plug in a GM 2 BAR MAP sensor and reprogram the MAP vs RPM vs Timing table in the ECM chip. The timing table is split by a factor of two to have RPM and Timing for conditions of both boost and vacuum. Tunercat makes a program designed for such an application and has definition codes for the 85 and the 86-88 ECM's .Programmers like Sinister Performance can most likely help you with a chip to work with the 2 BAR MAP. Note that you cannot just plug in the 2 BAR MAP and expect it to work.
RotrexFiero
Report this Post09-29-2016 08:06 PM Click Here to See the Profile for RotrexFieroClick Here to visit RotrexFiero's HomePageSend a Private Message to RotrexFieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is mythical and somewhat reminiscent of that old cartoon I watched as a kid -- Speed Racer. They built an engine so powerful that it could propel a car so fast it would make people delirious. They would go insane. Even so everyone wanted it and they were trying to steal the engine. So to keep it from falling into the wrong hands "Pops" destroyed it. But, at the same time he secretly etched the plans for the engine onto the windshield of the Mach 5. That still did not stop them. When someone tried to steal the plans, "Pops" shattered the windshield with a wrench. The secret was lost, but it left you thinking should something so powerful ever be built?
I think this should be discussed before we progress any further.
Boot
Report this Post09-30-2016 05:28 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Based on this, we should definitely progress! That way the Fiero will get all the respect it deserves!!!
Boot
Report this Post12-27-2016 01:30 PM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Figured I should add some closure to this thread...
I met a guy at a car show who did nearly the exact same thing I was doing here... Just to a rwd 2.8 in a rat rod. Same blower and everything. He said he revved it once and blew both headgaskets, replaced them with better ones, and then it snapped off the crank within 100 miles.
So that was a little disappointing to hear. And since the Fiero is still my daily, I stopped working on it
Just last weekend, I traded the supercharger to a buddy of mine for an old Garret gt1752 turbo off of some sort of volvo, with a top mount intercooled turbo build in mind. Had the worst shaft play either of us had ever seen. More than an eigth of an inch. Whatever, I thought, rebuild kits are only $60. Took it home and pulled the compressor housing off to find out the the shaft is actually broken in half. So thatll be $120 for a new core section. But in the end Ill have a working turbo, and when I get a new daily (looking at an '02 BMW 540i with a 4.4 dohc v8 and a 6 speed manual ) Ill get cracking on the fiero. If/when the 2.8 kerplodes, itll probably get a 3400 turbo.
Thanks to everyone who contributed to this thread!!! It was a lot of fun figuring out all the little challenges. With an m62 I could see it working much better. Maybe some other time...
cam-a-lot
Total ratings: 97
Report this Post12-27-2016 03:52 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope you appreciate all the people that tried to give you a reality check before you flushed thousands of dollars down the drain!
Boot
Report this Post12-29-2016 11:46 AM Click Here to See the Profile for BootSend a Private Message to BootEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thousands of dollars??? I had about $300 into it for almost all the parts I needed! The junkyard is life, and Cheap is an art form
cam-a-lot
Total ratings: 97
Report this Post12-29-2016 07:25 PM Click Here to See the Profile for cam-a-lotSend a Private Message to cam-a-lotEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thousands of dollars referred to an actual, finished, running project.
BillS
Report this Post12-30-2016 11:13 AM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
Finally some sanity. This thread was painfl to watch, but people will do what they want despite advice to the contrary.
It is a waste of time playing with the 2.8 when a stronger stroked crank is available from the 3.1/3.4 (same crank) and using stock pistons ensures failure - you need some forged slugs that will take the boost.
Turbo is a nice way to go on these (I ran one as my primary street car for more thn 20 years, boosted to 10-12 psi) but you can't just grab the first used turbo you find, you need to spend a lot of time with turbo charts figuring out which one is optimal (hint - it won't be as big a turbo as you think).
At least you got a learning experience without spending a ton of money.
BTW, it has been done before - if no one mentioned it, see here http://614streets.com/Fageol.html
