  Rear caliper won't compress
Rear caliper won't compress by Buck531
Started on: 09-13-2016 07:37 PM
Replies: 16 (633 views)
Last post by: 85 SE VIN 9 on 09-19-2016 01:09 PM
Buck531
Report this Post09-13-2016 07:37 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm in the middle of my L67 swap and I was putting on new pads for the back. I just can't seem to get the piston to go back in. I got it to fully extend (grr) but now it won't go back in. I've looked at ogres cave and did everything I could. The piston starts to move a very little and just stops. I can turn the screw on the piston and it starts to go back out. I remove the parking lever and If I keep turning the screw to the left it keeps spinning but nothing happens. When I go to the right it starts extending the piston.
I can't see this being a bad caliper as they were working fine a few weeks ago when I was driving the car. Any ideas?
03 Buick Regal. 13.0x @103
87 Fiero GT. L67 swap soon
Report this Post09-13-2016 08:45 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
might Ran screw out of piston
If your lucky, pushing piston and turn screw until threads catch. push in piston rest of way.
If not, very short:
Get rebuild seal kit in case you tear rubber
Pull piston and screw.
thread screw into piston.
Carefully reinstall.
Or piston is dead. get a another caliper.
Total ratings: 154
Report this Post09-13-2016 08:46 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
You may be able to remove the lever and screw the piston back using a GM disk brake piston tool. It's a small cube that snaps onto a ratchet. I got one at NAPA but other parts stores sell them as does The Fiero Store.
Buck531
Report this Post09-13-2016 09:05 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok. Is the thread on the inside of the piston to the screw a reverse thread?
Also. should I be able to pull the piston screw (hand brake piece) out? it's pretty rusted but wasn't sure how far it should come out.I'm not sure what inside of the piston chamber looks like.
Report this Post09-14-2016 10:41 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pbrake screw comes out with the piston.
Screw "Threads" are different for each side. I think for Fiero... (Haven't look at them in a while.)
P side is normal
D side is left hand
Buck531
Report this Post09-14-2016 12:41 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
When I get home tonight I'll take a few pictures of what I'm dealing with.
Buck531
Report this Post09-14-2016 07:30 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
Buck531
Member since Mar 2016
Well that sucks. I finally got the piston to go in. Put everything back together and then the rotor wouldn't fit between the pads. I noticed that when i turn parking lever the piston goes out but doesn't go back in when going the other way.
Messing with it the piston came out. Now I can't get it to go back in. Everything looks ok. The screw in the piston moves freeley but I'm kinda stuck now.
Hudini
Total ratings: 165
Report this Post09-14-2016 07:40 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 154
Report this Post09-14-2016 09:10 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you put the inboard pad on, the clips should hold it to the piston. The D tabs on the back of the pad must rest in the D slots on the piston. This keeps the piston from rotating and keeps the pad in full contact with the piston,. It also helps to keep the pad from moving around and allows the Ebrake to adjust as you use it.
Report this Post09-14-2016 11:29 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
piston should be <5mm when compress fully. if doesn't then very likely piston is bad.
Then pads will clear the rotors most times. (Heavy Rust on edge of rotor can be a problem.)
See my Cave, Clamp Method notes
Fieroking
Total ratings: 78
Report this Post09-14-2016 11:31 PM Click Here to See the Profile for FierokingClick Here to visit Fieroking's HomePageSend a Private Message to FierokingEdit/Delete MessageReply w/QuoteDirect Link to This Post
You need to get the GM piston retract tool to get the piston to retract. The e brake lever will only push the piston out. The design is the piston retracts only by bring rotated you can not push the piston back like the front pistons.
Joe Sokol
85 SE Daily driver with a 3.4 DOHC OBD II
88 Formula/GT 4.9 Allante Intake (My Baby)
www.fieroking.com
Report this Post09-15-2016 01:10 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wrong.
see same cave page or read 84-87 FSM. 87 is best because GM finally fix rear brake section of FSM.
GM made a tool for 88 to retract w/o removing the Pbrake level to save dealer service time but can retract w/ clamp method etc but iron for outside pad blocks the C clamp. If piston and screw are ok and remove the lever, can return by carefully using a pry bar. Don't pry on friction material or can break the pads.
This is possible because the "threads" on the screw is not made the same as normal bolts/nut combo. In fact, it take so little effort to move that when out of caliper and clean the screw can literally drop into or out of the "nut" just from gravity when piston face is pointing up or down.
85 SE VIN 9
Report this Post09-15-2016 05:52 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
Turning the screw in the direction the ebrake lever would move when handle is pulled causes the piston to go out, turning the other way allows the piston to be pushed back.
Before I learned this I used a harmonic damper puller to push the piston. You could do that to push the piston back in.
weaselbeak
Total ratings: 76
Report this Post09-17-2016 03:05 PM Click Here to See the Profile for weaselbeakSend a Private Message to weaselbeakEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by theogre:
[QUOTE]Originally posted by Fieroking:
Wrong.
Not sure how he is wrong. Mine simply could not be compressed without rotating the piston. I borrowed the tool from a tire shop.
[This message has been edited by weaselbeak (edited 09-17-2016).]
Buck531
Report this Post09-18-2016 06:56 PM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is there a way to get the piston back in the rubber sleeve? I'm holding the piston and the spring in my hand but I just can't seem to get it back in past the rubber sleeve.
Or do I have to buy a repair kit? I'd rather not have to buy a new caliper if I don't have to.
Report this Post09-18-2016 08:31 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You mean outer seal/dustboot?
Boot is like axle and crank seals that have metal edges to meet trans or timing cover.
Try Carefully pry out the metal part out of the caliper. Work around the boot, not pry in one spot.
If you wreck it or anything else like the seal on the PB screw or o-ring for piston, need a seal kit.
Install piston (Lube o-rings w/ brake fluid.)
then put boot on the piston and "drive" it into the caliper again.
1.5" plastic plumbing and old inner pad or scrap metal to make a driver. (you can/will wreck the pad)
stack pipe and pad on boot then tap w/ hammer to drive the boot.
Don't need much force but is a bit hard w/o a driver.
85 SE VIN 9
Report this Post09-19-2016 01:09 PM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
+1
