  Fixing This Scratch and Imperfection in Fiberglass Quarter Panel
Fixing This Scratch and Imperfection in Fiberglass Quarter Panel by scottd
Started on: 09-26-2016 06:57 PM
Replies: 12 (409 views)
Last post by: scottd on 09-29-2016 10:21 AM
scottd
Report this Post09-26-2016 06:57 PM Click Here to See the Profile for scottdClick Here to visit scottd's HomePageSend a Private Message to scottdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey Guys,
I am still pretty new here and just picked up an awesome 86 GT. The body is pretty perfect except for a bad scratch on my passenger side quarter panel. There is also a little area that looks to heave been touched up right above it as well.
Here is a pic:
Any thoughts to how I can go about fixing this? Or should I just bring it to a body shop and get it done right. I am comfortable with bondo, although, I doubt this is preferred on fiberglass. I can also do basic touch ups as well.
Thank you!
--Scott D
Stock 1986 White GT
Report this Post09-26-2016 09:16 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Scott:
Is that the rear wheel well? You will need filler that is compatible with SMC. Fieros were Base coat/ Clear coat paint jobs, so a patch is not going to look great, but better than what you have.
scottd
Report this Post09-27-2016 10:51 AM Click Here to See the Profile for scottdClick Here to visit scottd's HomePageSend a Private Message to scottdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, this is the rear passenger side wheel well. What type of filler works with fiberglass? Should I just take this to a bodyshop? Thank you very much for your help!
--Scott D
Stock 1986 White GT
Report this Post09-27-2016 11:15 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Fiero technically has no fiberglass parts. That rear clip is made of Sheet Molding Compound....(SMC), and there is body filler made specifically for it. A body shop will want to repaint the entire part to make it look right....so it's up to you. You can patch paint it and it will look good from 20 feet, or you can get it back to new condition.l
scottd
Report this Post09-27-2016 11:18 AM Click Here to See the Profile for scottdClick Here to visit scottd's HomePageSend a Private Message to scottdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oh, that makes total sense. Sorry, I thought that part was fiberglass for some reason. Eventually, I will get the car painted back to it's original white color, so I may just try and fill it gently with some SMC body filler and touch it up the best I can. I plan on using the car as a car and actually driving it, so I am ok with a few little imperfections. Thank you for the info.
--Scott D
Stock 1986 White GT
Report this Post09-27-2016 11:21 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The raw materials are the same......glass fiber and resin.....but fiberglass is poured or sprayed into a one-sided mold, and SMC is pressed and heated from both sides. The result is a much denser material that needs different treatment.
[This message has been edited by Gall757 (edited 09-27-2016).]
TopNotch
Total ratings: 60
Report this Post09-27-2016 01:59 PM Click Here to See the Profile for TopNotchClick Here to visit TopNotch's HomePageSend a Private Message to TopNotchEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can repair it with this.
Report this Post09-28-2016 02:42 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Must respectfully disagree. The gouge is on the fender and you need a flexible filler ( IIRC like 3M easy fill) to fill it. Its easy to sand and dries flexible like the urethane fender material. Locate a suitable flexible filler that is used on front facias. That's the one to use.
scottd
Report this Post09-28-2016 03:37 PM Click Here to See the Profile for scottdClick Here to visit scottd's HomePageSend a Private Message to scottdEdit/Delete MessageReply w/QuoteDirect Link to This Post
So something like this? 3M Automix for flexible parts.
http://www.oreillyauto.com/...9&pt=N2545&ppt=C0171
Crap, just read further and it looks like it is not recommended for SMC.
Am I looking at the wrong stuff?
Thanks,
--Scott D
Stock 1986 White GT
Report this Post09-28-2016 03:44 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Dennis is confused...
The front fenders on the Fiero are made out of that stuff.....the rear fenders are actually the entire rear clip, and made out of SMC.
[This message has been edited by Gall757 (edited 09-28-2016).]
Report this Post09-28-2016 05:13 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
My computer isn't letting me see the pic, (my computers fault) but a good body shop should be able to paint blend to where you cant easily see the blend, instead of painting the whole back end. They also can spray clear farther out to help hide the blend.
jaskispyder
Total ratings: 205
Report this Post09-29-2016 09:10 AM Click Here to See the Profile for jaskispyderSend a Private Message to jaskispyderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Take it to 2 body shops and see what they say.... they can paint that section, if they have good color matching system.
Or.. you could fill just the scratch, and touch up with some bottled paint. Cheap fix, and would look better at 10 ft, than now.
scottd
Report this Post09-29-2016 10:21 AM Click Here to See the Profile for scottdClick Here to visit scottd's HomePageSend a Private Message to scottdEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you guys very much for the info. For now, I am going to touch it up the best I can and then get it fixed by a real body shop once I decide to get the car painted. I really appreciate it.
--Scott D
Stock 1986 White GT
