  Harmonic Balancer/ Damper Replacement
Harmonic Balancer/ Damper Replacement by bortolini
Started on: 09-27-2016 01:47 PM
Replies: 4 (939 views)
Last post by: pmbrunelle on 10-09-2016 10:02 PM
bortolini
Report this Post09-27-2016 01:47 PM Click Here to See the Profile for bortoliniSend a Private Message to bortoliniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just curious if anyone has any experience replacing this part. I will be ordering a new one and am not sure if I should be ordering a fiero specific one, or GM or if it really matters... any help is appreciated!
Blacktree
Total ratings: 350
Report this Post09-27-2016 02:27 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Are we talking about the 2.8 V6? I'm not sure if Fiero-specific harmonic balancers are available anymore. Most people buy one for another vehicle with the same engine (like an S10 or Camaro, or whatever) then transfer the timing mark over.
85 SE VIN 9
Report this Post09-28-2016 07:16 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
The Dorman part number is 594-013 for 85-87. This is the same part you'll get from TFS.
The timing mark is different.
After mine was replaced I checked the timing with an adjustable timing light to see where the new mark falls. For #1 cylinder that is 40 degrees and #4 42.5. I think this would be in advance.
You can also do the procedure to get top dead center and then make a mark on the new damper or you can get products that wrap around the outer ring to give you the correct mark for different applications. They had them at a Pep Boys in the service department.
I used this light, Innova 3555
https://www.summitracing.co...z0sc8CFQERaQodu40Haw
[This message has been edited by 85 SE VIN 9 (edited 09-28-2016).]
murrrey
Report this Post10-09-2016 08:35 PM Click Here to See the Profile for murrreySend a Private Message to murrreyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have yours remanufactured at DamperDudes.com
pmbrunelle
Total ratings: 63
Report this Post10-09-2016 10:02 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought mine from damper doctor.
Plug-and-play. None of that transferring marks over nonsense.
Plus, if you're replacing the balancer because your original has slipped (the reason I changed mine), you can't use the original part as a reference.
