  intake manifold bolt stud
intake manifold bolt stud by tazome
Started on: 10-10-2016 03:30 AM
Replies: 15 (790 views)
Last post by: peterh on 02-13-2023 05:22 PM
tazome
Report this Post10-10-2016 03:30 AM Click Here to See the Profile for tazomeSend a Private Message to tazomeEdit/Delete MessageReply w/QuoteDirect Link to This Post
i was wondering if any one knows what size or kind of socket to use to remove the 4 intake manifold studs, it looks like the studs have a torx head on them or spline head??? thanks for your help
Report this Post10-10-2016 10:06 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 154
Report this Post10-10-2016 10:23 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I believe the last time I removed the upper intake, I used a 12 point, 10mm socket.
Total ratings: 206
Report this Post10-10-2016 10:31 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The O/P is speaking of the four studs that are at the corners of the lower intake manifold.
A small 6 point socket will grab the splined tip of the stud and allow you to remove them.
Total ratings: 465
Report this Post10-10-2016 02:58 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The O/P is speaking of...
It would really be helpful if people could at least mention what engine they're referring to!
Jason88Notchie
Report this Post10-10-2016 05:24 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
Meh. It's got to be the 4 banger.
Total ratings: 206
Report this Post10-10-2016 05:25 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was obvious to me he was talking about a 60° V-6......
Jason88Notchie
Report this Post10-10-2016 05:27 PM Click Here to See the Profile for Jason88NotchieSend a Private Message to Jason88NotchieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know...
Total ratings: 465
Report this Post10-10-2016 07:01 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
My point was... as I'm sure you understand... is that we shouldn't need to be guessing (whether it's an educated one or not) what year Fiero and what engine is being referred to by the originator of any "help" thread. It's a time/effort waster for everyone and it only serves to further muddy the waters when the assumptions are wrong.
[This message has been edited by Patrick (edited 10-10-2016).]
tazome
Report this Post10-10-2016 08:09 PM Click Here to See the Profile for tazomeSend a Private Message to tazomeEdit/Delete MessageReply w/QuoteDirect Link to This Post
it's a 1987 2.8 v6 fiero gt that has about 20 thousand miles on it. i dont know if i should just leave the intake manifold gaskets alone, it's been in storage back in 95, just thought maby the gaskets are dryed up? i'll post some pictures on here later. an they are the four studs on the lower intake manifole
[This message has been edited by tazome (edited 10-10-2016).]
Total ratings: 465
Report this Post10-10-2016 08:34 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Dried up? There's nothing wet going through the intake manifold. (ie It's not like a carburetor.) No need to take any of it apart just for the gaskets.
Total ratings: 461
Report this Post10-10-2016 10:04 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
If it's not leaking, I would leave it alone. The intake gaskets on 2.8s are not known to be problematic.
If it's leaking oil, up high, I would check the distributor O-ring and valve cover gaskets, in that order. With only 20K, I would really be surprised if anything is leaking.
peterh
Report this Post02-11-2023 06:42 PM Click Here to See the Profile for peterhSend a Private Message to peterhEdit/Delete MessageReply w/QuoteDirect Link to This Post
I broke one of these 4 studs taking the heads off my V6 motor, any source?
peterh
Report this Post02-11-2023 06:43 PM Click Here to See the Profile for peterhSend a Private Message to peterhEdit/Delete MessageReply w/QuoteDirect Link to This Post
peterh
Member since Aug 99
greenturnedblue
Report this Post02-13-2023 01:12 AM Click Here to See the Profile for greenturnedblueSend a Private Message to greenturnedblueEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you can just 'unscrew' I can send you one off my parts engine, just cover shipping. If you cant get it out cleanly you will most likely need to drill it out, and helicoil it. Then I can still send you another one
[This message has been edited by greenturnedblue (edited 02-13-2023).]
peterh
Report this Post02-13-2023 05:22 PM Click Here to See the Profile for peterhSend a Private Message to peterhEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't want to remove it, i's good. I do have one broken off that the shop doing the valve shop will remove.
Thanks for offer.
I will just get a bolt of the same size and cut off the head and machine the top like the others.
