| quote | Originally posted by pmbrunelle:
Subaru centre bore is 56.1 mm I think, so the Subaru wheels would not be able to slide over the Fiero 57.1 mm hub spigots. |
This.
You will need to enlarge the centerbores by 1 mm.
The 48mm offset will be perfect for the front of the 88, but will tend to tuck the wheels under, a bit, in the rear.
You may find some interference on the inside edges, but perhaps not. I think I've seen BRZ wheels on other Fieros, so I could be mistaken.
From what I've heard, if they'll fit on the rear of an earlier car, without interference, the 88 should actually provide a bit more clearance.
