  Body part removal
Body part removal by LornesGT
Started on: 01-02-2017 09:30 PM
Replies: 7 (503 views)
Last post by: LornesGT on 01-03-2017 05:36 PM
LornesGT
Report this Post01-02-2017 09:30 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know what they are called so I couldn't search. The black framing behind the GT quarter windows is what I want to remove. I plan to remove the quarter window but if don't have to right now I prefer to wait. Do they have to come off to remove the frame behind it?
N4YLR
Report this Post01-02-2017 09:41 PM Click Here to See the Profile for N4YLRSend a Private Message to N4YLREdit/Delete MessageReply w/QuoteDirect Link to This Post
http://www.fierosails.com/howto.html
^^^ Does this link help ^^^
LornesGT
Report this Post01-02-2017 11:16 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
If the quarter window must come out first it does, otherwise no. Thanks for the looks link. Found another by searching the net and an image lead me to this.
https://www.fiero.nl/forum/A...100421-2-093201.html
[This message has been edited by LornesGT (edited 01-02-2017).]
LornesGT
Report this Post01-02-2017 11:41 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
LornesGT
Member since Jan 2013
Forgot to add the second part I want to remove. The gas filler ring, the release cable for the cover is holding it in but I don't know how to get the cable loose from the cover latch.
Monkeyman
Total ratings: 182
Report this Post01-03-2017 06:16 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Notchback:
Fastback:
seajai
Total ratings: 52
Report this Post01-03-2017 06:16 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The service manual does not differentiate between notchback and fastback for this procedure so I don't think the 1/4 window filler needs to be removed to access these parts. Here are the steps from the FSM:
Here are the steps to remove the fastback 1/4 window inner filler panel just for reference:
Monkeyman
Total ratings: 182
Report this Post01-03-2017 06:19 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forgot to add the second part I want to remove. The gas filler ring...
If I was going to keep my Fiero, I was going to remove the door and fill in the rest of the assembly with fiberglass. With a nicer fuel cap, it would look good.
LornesGT
Report this Post01-03-2017 05:36 PM Click Here to See the Profile for LornesGTSend a Private Message to LornesGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the replies. That is the plan to use a pop up gas cap and move it to the back hood.
