Apparently, there are multiple GM knock sensors that all share the same physical form factor as the 10456287; all have a 1/4" NPT mounting thread which screws into the water jacket.
The Standard Motor Products catalog is most useful to get a handle on the available knock sensors. Skip to page 145:
http://www.pageturnpro.com/...uide-v2/index.html#1Knock sensors with same form factor (by visual comparison of the photos), listed by the Standard Motor Products PN:
KS2 (10456287 cross-reference)
KS2T
KS3
KS3T
KS6
KS6T
KS7
KS7T
KS8
KS8T
KS21
KS50
KS61
KS62
I suspect they vary in resonant frequency and possibly Q factor. Or maybe sensitivity? What does the "T" suffix mean? Some may be general-purpose parts-bin parts, some may have been developed to deal with a particular problem of a certain engine.
If other sensors can fit, we should consider them before running straight to the 10456287 without thinking.
Since I doubt we will get specifications (though I can always ask) for the knock sensors, we may consider characterizing the knock sensors ourselves.
This website demonstrates the use of impedance measurements to characterize a knock sensor:
http://www.solaraguy.com/viewtopic.php?t=38336Not sure how accurate that thread is, considering they mention the Fiero as having a knock sensor
Besides Fieros, I have an interest in audio. I have a PC-based test setup to measure the Thiele-Small parameters of speakers. With the test setup, I can test the impedance (magnitude and phase) of a DUT (typically a woofer) over the audio frequency range.
I should be able to use my test rig to characterize a knock sensor. I would like to measure the resonant frequency and Q of each unit.
Here is the test setup: Screw sensor into block, then fill water jacket with enough water to at least submerge the sensor. I don't know if the water adds any significant damping to the knock sensor response, but I would perform the test with water, just in case.
Ideally, I would purchase all 14 sensors and characterize them all. However, I am a bit too cheap to do this
I could potentially test a handful though, and then if people want to pitch in by shipping me uncharacterized knock sensors from the list, we could collectively complete the list, which I believe would be valuable to us as tuners.
From the solaraguy thread above (the same formula appears elsewhere), here is a formula to estimate (within a few hundred Hz) the knock frequency of an engine based on the bore size:
Frequency in kHz = 573 / Bore in mm
Once you know the knock frequency of the engine, choose a knock sensor having the same (or close) resonant frequency.
The formula is a bit of a hillbilly method. The real method to determine the knock frequency is to provoke knock in your engine of choice, and then record the knock frequency. However, you may kill some engines doing it the proper way...
Another approach is to copy what the factory did, if you can find a close match to your setup. I will be building a 3.1 with iron heads and a later-model block (459 casting number). If I can find a factory engine like mine, that was equipped with a knock sensor, then I can simply use
that knock sensor.
Also, while it may take a fair amount of work, we may be able to correlate each part number with the bore diameters of the engines they were installed on. Though that may be too much work for the quality of the data we shall obtain that way.
On a side note, I was thinking of getting a Cloyes double roller chain, since the silent chains seem to stretch a lot, but I am unsure if the noise will be picked up by the knock sensor.
