  Ep381, ep376 fuel pump questions
Ep381, ep376 fuel pump questions by Lambocountach
Started on: 02-18-2017 12:45 PM
Replies: 9 (815 views)
Last post by: Lambocountach on 02-21-2017 06:44 PM
Lambocountach
Report this Post02-18-2017 12:45 PM Click Here to See the Profile for LambocountachSend a Private Message to LambocountachEdit/Delete MessageReply w/QuoteDirect Link to This Post
In the process of doing a 3800 swap and ordered fuel pump acdelco ep381 from eBay what a mistake. Not only was it incorrect it showed up and no box like that was advertised. Came from some non USA market pump not one intended for USA and they sent me an equivalent to a ep240. So far spent what I could have on two pumps that are wrong when I could have just bought one from rock auto or jegs lesson learned. My question is has any used and ep381 or 376 equivalent pumps airtex, non oem brands.
cmechmann
Report this Post02-18-2017 03:26 PM Click Here to See the Profile for cmechmannSend a Private Message to cmechmannEdit/Delete MessageReply w/QuoteDirect Link to This Post
For the EP381 use a named seller Napa, Rock auto ect. Seen too many copies. Also I would stick with AC Delco or the Delphi equal. Carter in desperation.
Bosch used to be reliable, but been seeing them cheapen out on their aftermarket coverage. Still ok for OEM. Seen many failures with Airtex.
Lambocountach
Report this Post02-18-2017 04:29 PM Click Here to See the Profile for LambocountachSend a Private Message to LambocountachEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you appreciate the input I think I may order the ep381 from jegs. I was considering the Walbro 255 or DW 200 but don't feel like buy a copy by mistake. I am pretty much going to be stock so I don't feel the need for higher one as realistically probably 2 years before I would make some upgrades needing a bigger pump. Has anyone had any luck with the acdelco bvg00240 I couldn't find specs.
nosrac
Total ratings: 51
Report this Post02-18-2017 11:55 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lambocountach
Report this Post02-19-2017 11:26 AM Click Here to See the Profile for LambocountachSend a Private Message to LambocountachEdit/Delete MessageReply w/QuoteDirect Link to This Post
That pump looks very promising I had come across it on eBay but was unsure the quality warranty sounds good not that I hope to use warranty. I think I may do that pump I almost bought the 69225 Bosch last night till I read this now I have to think about it some more. Thanks for suggestion.
sardonyx247
Total ratings: 219
Report this Post02-21-2017 03:28 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
Autozone has even switched to Delphi now instead of airtex, ACdelco = china now, if you can find an AC-Delco then old stock oem (notice the dash) so delco is no better than any other brand now. But I keep hearing stories of buying acdelco and getting a genric box. My airtex may be going out (after a few years) not sure yet, haven't run a Delphi pump long enough to tell how they do. So beware of ACDelco now, more china crap. Not worth the extra money people want, unless you find an ebay ad of "actual pic" of an AC-Delco. FYI
Lambocountach
Report this Post02-21-2017 09:28 AM Click Here to See the Profile for LambocountachSend a Private Message to LambocountachEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes I have noticed that as well I think I may purchase the pump norsac suggested even thought I found the wallbro cheaper has anyone else run this pump?
darbysan
Report this Post02-21-2017 11:14 AM Click Here to See the Profile for darbysanSend a Private Message to darbysanEdit/Delete MessageReply w/QuoteDirect Link to This Post
The referenced pump is a Walbro Knock Off. Might save you a few bucks, but not worth the effort to have to change it if it goes out. I have the Walbro 255 in my El Camino. Works OK, but it is loud ( even with the tank in the back). Got to be even louder sitting right next to you. I used the EP381, and I'm very happy with it. It is quiet ( have to look at volt gauge to see if it is priming). I plan on replacing the Walbro with one of the EP381 next time I have the tank down in the Elky.
Like was mentioned, be sure to find and EP381 from a reputable dealer. Might cost a few more bucks, but it's still cheaper than a Walbro.
'87 GT , '00 3800 Series II SC, 4t65e.
nosrac
Total ratings: 51
Report this Post02-21-2017 04:46 PM Click Here to See the Profile for nosracSend a Private Message to nosracEdit/Delete MessageReply w/QuoteDirect Link to This Post
Why do you say it's a knockoff? It is made in the USA, quiet, lifetime warranty, and outputs 255lph as advertised and The OEM ep381 doesn't output 255lph so it's not recommended for high hp builds.
[This message has been edited by nosrac (edited 02-21-2017).]
Lambocountach
Report this Post02-21-2017 06:44 PM Click Here to See the Profile for LambocountachSend a Private Message to LambocountachEdit/Delete MessageReply w/QuoteDirect Link to This Post
I actually like what I read online about it I am between the dw200 and the high flow. It maybe a copy but doesn't mean it's bad. Let's face it like most things 1 or two major company's put all the r&d only to have spent so much developing it. Then some company copy's it and sometimes makes it better and cheaper because not the same overhead.
