  L vs R Cylinder Heads?
L vs R Cylinder Heads? by bortolini
Started on: 03-03-2017 02:34 PM
Replies: 3 (299 views)
Last post by: bortolini on 03-06-2017 05:24 PM
bortolini
Report this Post03-03-2017 02:34 PM Click Here to See the Profile for bortoliniSend a Private Message to bortoliniEdit/Delete MessageReply w/QuoteDirect Link to This Post
just curious if there is a difference between the left and right cylinder head. i got my heads rebuilt at a machine shop and they didn't specify which one was which.
when looking at them there is a bolt in the side of one and a plug in the corner of one but not the other. does either of these indicate which side is which?
Thanks!
Blacktree
Total ratings: 350
Report this Post03-03-2017 03:01 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The heads themselves are identical. However, one of them gets the coolant temperature sender installed in it, and the other gets a plug. The temperature sender goes on the trunk side cylinder head, by the ignition coil. So the head with the plug goes on the firewall side.
[This message has been edited by Blacktree (edited 03-03-2017).]
Lou6t4gto
Report this Post03-03-2017 06:07 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heads are exactly the same, BUT when installing, get the head with the "threaded hole" for the sender on the correct side, The Plug Is a Real PIA to get out if you mix them up (Especially AFTER you put the engine in ! )
bortolini
Report this Post03-06-2017 05:24 PM Click Here to See the Profile for bortoliniSend a Private Message to bortoliniEdit/Delete MessageReply w/QuoteDirect Link to This Post
How about the bolt that has additional threads on it like it's meant to hold a ground wire? I think I've narrowed it down to the front of engine (when looking into trunk of car) all the way to the left. does this sound right? cant tell from the photos and posts i've looked at so far. just wouldnt mind confirmation on my thoughts. Thanks!
