| quote | Originally posted by RyuKyu567:
when you charged up the system how much of the R134a did you use to properly fill the system? I looked up the specs but its all referencing the old R12, other forums mention a "best guess" to how much R134a is needed but its somewhat vague. From what I understand there is some method to measure the differences in the Freon due to R134a being a higher pressure than the R12. |
Ryu,
I don't recall off hand the actual ounces needed but R134 is about 80% the R12 amount. I think it took about 22 ounces (about 2 cans) of the inexpensive Walmart Freon.
Another thing to note... I didn't evacuate the system. It had leaked out long ago but I did flush the A/C lines front to back while I had the accumulator/dryer and orifice tube hose section out. Can't remember the brand of flush but it was the "environment safe" stuff in an aerosol can. Kinda smelled like Goo-Gone.
After that I blew the lines out with a small compressor and hose (thanks ignorant neighbor [I'll have to explain that later]) until they were dry. Also I waited til the last minute before taking the plastic seals off the accumulator then installing so the system was only open to the elements for a few monutes. The accumulator/dryer has a hydroscopic material like desiccant that absorbs moisture. It's humid here on the coast.
Once I was confident everything was buttoned up I cranked her up and ran the A/C to suck in the R134. I used the wife's meat thermometer in the central vent until the temp was about 40-ish.
I would still rather take it to an A/C shop and have them vacuum and recharge officially. I think that way the system would be that much more efficient.
[This message has been edited by KMFDMFAN (edited 04-06-2017).]
