  Comp Cam Timing chain/gear?
Comp Cam Timing chain/gear? by Spadesluck
Started on: 04-23-2017 07:35 AM
Replies: 3 (104 views)
Last post by: Spadesluck on 04-26-2017 01:40 AM
Spadesluck
Report this Post04-23-2017 07:35 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Purchased a Comp Cam "package" from a fellow PFF member, includes a 260H cam, lifters, springs and timing chain. However the timing chain is missing the cam sprocket. Is it possible to use the stock one with the Comp Cam? Just wanted to ask before I go through the trouble of finding one. I know a lot of times these parts are packaged together for a reason. Thanks in advance.
Hudini
Total ratings: 165
Report this Post04-25-2017 10:49 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
The cam will have the same bolt holes as a stock cam. I used a Cloyes double-roller on my Comp 260h.
Edit: Pic of my original 2.8L timing chain set.
[This message has been edited by Hudini (edited 04-25-2017).]
Report this Post04-25-2017 11:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd be concerned about the stock cam sprocket (especially the fact it's used) working with the new aftermarket timing chain (although the crank sprocket is both factory and used). It may or may not be an issue, I don't know.
[This message has been edited by Patrick (edited 04-25-2017).]
Spadesluck
Report this Post04-26-2017 01:40 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Couple things, thank you Hudini for providing the picture and info and Patrick, that is definitely a concern of mine as well. I will take a good look at the cam sprocket before proceeding with any change of coarse. However I have not come across a cam sprocket breaking, not saying it couldn't happen though. ha
