  UNKNOWN PART/SENSOR?
UNKNOWN PART/SENSOR? by QCMANAGER
Started on: 04-24-2017 08:41 PM
Replies: 6 (232 views)
Last post by: fierofool on 04-26-2017 08:54 AM
QCMANAGER
Report this Post04-24-2017 08:41 PM Click Here to See the Profile for QCMANAGERSend a Private Message to QCMANAGEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi,
I have an 85 GT and I was cleaning up the engine compartment yesterday when I came across an unconnected wire just hanging there under the three vacuum lines just to the right side (viewed from rear of car) of the upper plenum. I searched around and found the other end also just hanging there. If I remember correctly, the first wire I found was green (not sure if it had a stripe or not) and the other wire was white. The other end of the white wire seemed to be connected to some round metal object about the size of a nickel that sits between the thermostat housing and the upper plenum but underneath the three vacuum lines that run through there. I searched through my Hayne's manual hoping for a photo showing all the V6 engine sensors, etc. but could not find a photo of this area that showed this wire or the part it is connected to.
Does anyone have any idea what this is?
Thanks
Report this Post04-24-2017 08:47 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here are the three sensors in that area. I think the ECM Temp Sensor has a green wire and white wire.
[This message has been edited by Gall757 (edited 04-24-2017).]
QCMANAGER
Report this Post04-24-2017 09:12 PM Click Here to See the Profile for QCMANAGERSend a Private Message to QCMANAGEREdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the reply. I found a photo and added a circle and arrow to the part that I think this wire was attached to. It had the plastic flexible wire cover around it.
http://s1002.photobucket.co...zpsb76a4b18.jpg.html
QCMANAGER
Report this Post04-24-2017 09:13 PM Click Here to See the Profile for QCMANAGERSend a Private Message to QCMANAGEREdit/Delete MessageReply w/QuoteDirect Link to This Post
QCMANAGER
Member since Jan 2015
Spadesluck
Report this Post04-25-2017 08:24 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here you go
Hudini
Total ratings: 165
Report this Post04-25-2017 11:41 PM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
Appears you are looking at the fan switch. Single wire with a big, rather squishy plastic cover? The fan switch goes to ground when the resistance hits the design value which completes the circuit to the radiator fan. When I first bought my car the PO had just hooked an alligator clip to the wire and permanently grounded the circuit so the fan ran whenever the car was running. Not the approved solution to an overheating problem.
Total ratings: 154
Report this Post04-26-2017 08:54 AM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fan switch image from Rodney Dickman website.
http://rodneydickman.com/ca....php?products_id=349
Cold Start Injector Switch from Advance Auto website.
https://shop.advanceautopar...e+temperature+switch
