  How to test a fuel sending unit
How to test a fuel sending unit by hcforde
Started on: 05-09-2017 12:14 AM
Replies: 5 (279 views)
Last post by: hcforde on 05-10-2017 01:58 PM
hcforde
Report this Post05-09-2017 12:14 AM Click Here to See the Profile for hcfordeSend a Private Message to hcfordeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have looked through the posting here on how to check a fuel sending unit. Everybody talks about using a multi meter to check for the ohms difference, but the thing I don't see here is, Where should the leads be hooked up on the device to do this test?
USMUCL
Report this Post05-09-2017 05:54 AM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year and engine, and is the sender out of the car now or installed?
Electrathon
Total ratings: 254
Report this Post05-09-2017 08:11 PM Click Here to See the Profile for ElectrathonClick Here to visit Electrathon's HomePageSend a Private Message to ElectrathonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Connect the ohm meter to the sender wire and to the metal body of the sender. 0 ohms empty and 90 ohms full (45 half take and so on). A few one way or the other is no big deal.
shemdogg
Report this Post05-09-2017 11:16 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you have to pull the tank to get to the sender or is it accessable another way? My fuel gauge doesnt work either
shem
Electrathon
Total ratings: 254
Report this Post05-09-2017 11:56 PM Click Here to See the Profile for ElectrathonClick Here to visit Electrathon's HomePageSend a Private Message to ElectrathonEdit/Delete MessageReply w/QuoteDirect Link to This Post
shem
Yes. You can test the top side by unplugging the sender wire (connection on the firewal). Unplugged it will read way past full. Ground the sender wire and it will read empty (key on, engine not running). I think it is the tan wire if I remember correct.
hcforde
Report this Post05-10-2017 01:58 PM Click Here to See the Profile for hcfordeSend a Private Message to hcfordeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have been looking for an official service manual so I don't have to bother people with these mundane issues. No one seems to like the Chilton or Haynes books.
