  signs of bad or loose engine mounts
signs of bad or loose engine mounts by Bruce
Started on: 06-02-2017 02:04 AM
Replies: 11 (1029 views)
Last post by: Bruce on 06-10-2017 03:28 PM
Bruce
Report this Post06-02-2017 02:04 AM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
What are some of the symptoms and/or sounds of a bad engine mount? If one is bad, should all the rest be replaced, just to be on the safe side.
bb
Monkeyman
Total ratings: 180
Report this Post06-02-2017 04:31 AM Click Here to See the Profile for MonkeymanSend a Private Message to MonkeymanEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, I'm not much of a mechanic, but I think a good sign your motor mounts are bad is when your motor falls on the ground but what do I know?
Kevin87FieroGT
Report this Post06-02-2017 05:02 AM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
A lopsided dog bone strut. Some may say leaning to one side or another. Not square with the mounts. If this is you, check the other 3 mounts. Two on the trans and one below the crank pulley in the front of the engine.
[This message has been edited by Kevin87FieroGT (edited 06-02-2017).]
Total ratings: 463
Report this Post06-02-2017 05:56 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I actually broke a rear (trunk side) trans mount.
The only thing I noticed was a "clank" noise when the tab on the bracket raised up and hit the top of the rear cradle rail. Noticed it under decel, when I was in stop and go traffic.
Bruce
Report this Post06-02-2017 11:22 AM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks
Fiero Vampire
Report this Post06-03-2017 11:42 AM Click Here to See the Profile for Fiero VampireSend a Private Message to Fiero VampireEdit/Delete MessageReply w/QuoteDirect Link to This Post
Another good sign of a bad engine/transmission mounts is excessive vibration (especially in automatics in drive while not moving)
Blacktree
Total ratings: 350
Report this Post06-03-2017 01:53 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have an automatic transmission, try shifting back and forth between Reverse and Drive while you hold down the brake pedal (with the engine running). If you hear and feel a clunk in the back, you may have a bad motor mount. You can do the same with a manual gearbox (set the parking brake instead of holding the brake pedal), but it may be more difficult to tell.
[This message has been edited by Blacktree (edited 06-03-2017).]
Report this Post06-03-2017 03:18 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
A this point in time, I would change all the trans and engine mounts even if they are not broken. They are 30+ years old and most likely the rubber has stretched softened and excessive movement is being allowed.
Threedog
Total ratings: 61
Report this Post06-03-2017 03:50 PM Click Here to See the Profile for ThreedogSend a Private Message to ThreedogEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you need a replacement, Rodney sells tougher ones that are less likely to break again.
Larry Nakamura
Report this Post06-04-2017 12:11 AM Click Here to See the Profile for Larry NakamuraSend a Private Message to Larry NakamuraEdit/Delete MessageReply w/QuoteDirect Link to This Post
What year/engine/trans do you have? I have an 88GT. To check the top
engine mount (Dog Bone mount), try grabbing the top of the engine and
rock it forward and back to see if it moves some. If so the bushings on the
dog bone mount need replacing. I believe these go bad over time on all
V6 fieros. Not sure if there is a dog bone on the 4 cylinder engine.
Blacktree
Total ratings: 350
Report this Post06-05-2017 12:13 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 4-cylinder Fieros also have a dogbone mount. And the bushings deteriorate the same as the V6 dogbone.
Another issue with the 4-cylinder dogbone mounts, especially on the '87-88 ones, is that the dogbone mounting bracket on the cylinder head will split in half, right down the middle. I've seen this on so many 4-cylinder Fieros, I've lost count. My solution for that is to weld the bracket back together, then use some really big washers on the mounting bolts, to spread the load.
Bruce
Report this Post06-10-2017 03:28 PM Click Here to See the Profile for BruceSend a Private Message to BruceEdit/Delete MessageReply w/QuoteDirect Link to This Post
It was missing muffler springs and loose wheel well liner; no charge from my mechanic. How often does that happen when you take your Fiero in?
My next question is: where do I get a replacement liner, or, better yet, how do I tighten the existing one?
Thanks!
bb
