  Unused area of Fiero gauge cluster modification.
Unused area of Fiero gauge cluster modification. by DeLorean00
Started on: 06-10-2017 10:30 PM
Replies: 4 (405 views)
Last post by: DeLorean00 on 06-26-2017 10:46 PM
DeLorean00
Total ratings: 100
Report this Post06-10-2017 10:30 PM Click Here to See the Profile for DeLorean00Send a Private Message to DeLorean00Edit/Delete MessageReply w/QuoteDirect Link to This Post
This info is in my Mera build thread but I thought that people that are not reading my thread might be interested in this since it is not Mera specific.
I have always thought the Fiero gauge cluster looked incomplete with the unused unexplained blank panel on the opposite side from the odometer. Looking for ideas I saw a fellow forum member 30+mpg put an air-fuel gauge there and I really loved the look but I was unable to find an air-fuel board I could adapt to fit. However looking on eBay for hours I found this voltage gauge that was exactly the size of the spare opening in the Fiero and it was super $13 and even cheaper if you are willing to wait for it to come from China, so I went ahead and bought it.
Here is the link to buy one if anyone is interested.
http://www.ebay.com/itm/282...e=STRK%3AMEBIDX%3AIT
This is what it looked like when it arrived. It is a little goofy looking and too thick in its original casing but that is no problem because I was not planning to use the casing anyway.
This was the hardest part of the whole project. It has 4 screws in the back, I thought 'awesome this will be simple', I was wrong. After removing the screws I found it was glued together extremely well, it must be water proof. I broke 3 xacto kinfe blades cutting it open. Once inside there is a large blob of hot glue that I carfully cut through. Then I was able to carefull pry the board out only after I cut the case to let the power cable to come out. Once out I wanted to see if I could get the lense out, I figured if I break it I will use tinted plexiglass. I just used flat head screwdriver and push hard on both ends back and forth until it popped out.
Now that it was out I did a trail fit and was happy with how it looked.
People following my build know that every modification I am doing I want to be able to easily reverse because I think the Mera is a special car and I plan to take all my mods and Ferrari stuff off in the future. So I used Gorilla Tape to hold it in place. This picture was the trail fit, I actually did a better tape job when I did the final install.
Next I made a harness for it so I can quickly and easily remove the gauge cluster. I covered it in heat shrink and it made a nice harness. In the car since my dash was out I routed the wiring through all the factory wiring brackets and attached it to the switched power lead on the stereo harness since I do not want to cut any of my factory harness.
Here is the finished product. The angled line you see in the lense is a refection of my arm. Also the car is running but none of my other gauges are currently plugged in since I am still doing dash work and the factory pastic gauge wiring doesn't hold up well to repeated plug and unplugs.
Here is a quick video of it in operation.
Report this Post06-13-2017 02:22 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Looks good in there. So this is giving you the data that the aux gauge pod in some fieros have for battery charge?
DeLorean00
Total ratings: 100
Report this Post06-13-2017 05:14 PM Click Here to See the Profile for DeLorean00Send a Private Message to DeLorean00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Exactly. It just keeps an eye on your charging system. When the ignition is on but the car has not started it stays in the yellow area, but as soon as you start it jumps into the green. If your charging system started going bad you would notice a drop in the LEDs.
Honestly, it really isn't needed as my car is a Formula and already has the extra gauges, but I like pretty lights. lol
RPYRAZOO
Report this Post06-26-2017 03:24 PM Click Here to See the Profile for RPYRAZOOClick Here to visit RPYRAZOO's HomePageSend a Private Message to RPYRAZOOEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's one of those "Gotta Have" mods, reminds me of F1 steering wheel RPM light bars.
Thanks fo posting.
Rich
DeLorean00
Total ratings: 100
Report this Post06-26-2017 10:46 PM Click Here to See the Profile for DeLorean00Send a Private Message to DeLorean00Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks fo posting.
Rich
Thanks, Rich! I glad to find someone else that enjoys it! It is such a cheap mod and easily reversed, also I love seeing it light up when I start the car.
