  A/C pressure cycling switch wiring.
A/C pressure cycling switch wiring. by AZ Fiero1
Started on: 06-11-2017 01:44 AM
Replies: 2 (352 views)
Last post by: seajai on 06-11-2017 07:56 AM
AZ Fiero1
Report this Post06-11-2017 01:44 AM Click Here to See the Profile for AZ Fiero1Send a Private Message to AZ Fiero1Edit/Delete MessageReply w/QuoteDirect Link to This Post
The two wires and connector that go to the A/C pressure cycling switch, which mounts to the A/C Accumulator on my 86 were accidently destroyed a year ago. I'm now fixing the A/C and I'm not sure if I have the right two wires to solder to the new pressure switch connector. The two wires I suspect are right are what appears to be a brown wire and a black with a white tracer. Can anyone verify this?
wgpierce
Report this Post06-11-2017 02:44 AM Click Here to See the Profile for wgpierceSend a Private Message to wgpierceEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my 87 GT the wires are light blue and Green, maybe also light green.
[This message has been edited by wgpierce (edited 06-11-2017).]
seajai
Total ratings: 52
Report this Post06-11-2017 07:56 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
A/C wiring diagrams from the 1986 Fiero service manual. The low pressure cycling switch wires are lt green and lt blue if you have the v6, or lt green and grey/red if you have a 4 cyl.
