  3800SC idles but thats all (Page 3)
3800SC idles but thats all by Lou6t4gto
Started on: 06-22-2017 07:20 PM
Replies: 93 (1532 views)
Last post by: 85 SE VIN 9 on 10-15-2017 11:58 AM
Lou6t4gto
Report this Post09-25-2017 07:22 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
bump
Phirewire
Report this Post09-27-2017 11:17 AM Click Here to See the Profile for PhirewireSend a Private Message to PhirewireEdit/Delete MessageReply w/QuoteDirect Link to This Post
late here but curious TPS IAC?
Lou6t4gto
Report this Post09-27-2017 02:08 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
TPS is new, I don't "think" the iac would affect "Wide Open Throttle" performance, Would It ???
T4Turtle
Report this Post09-27-2017 04:56 PM Click Here to See the Profile for T4TurtleSend a Private Message to T4TurtleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still no scan on this vehicle? Crazy to try to diagnose without this.
Lou6t4gto
Report this Post09-27-2017 05:16 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Back to working on this thing Again. it starts, idles. just off idle picks up a intermittent "Miss". Fuel pressure at Idle 45, slowly rev it to 3000RPM, still 45 PSI. But, quick WOT and it drops to 35 , then back to 45 !! Is there a PERFECT Fuel pressure for these engines ? The vacuum line leading to the Pressure Regulator is from a stem on the "Side of the super charger" (This Is a 1997 Riviera engine, supercharger Vacuum Ports are different than my 1999 GP3800SC) WHERE is the vacuum "supposed to originate" ? the manifold UNDER the supercharger, OR the top of the Supercharger at the Throttle body ???? no fuel or smell in the Reg line or Reg. just rechecked all the "plug wires". where should the MAP Vacuum Line be coming "from" , under the SC, or At the throttle body ??
All Coils are brand new. new Air Filter. new TPS.New Injectors. HELP, before I go crazy and drop the cradle and replace the wire harness, & every sensor on this thing. all my code reader says is "Linking Error" :-(
Domtech
Report this Post09-27-2017 06:00 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
The stem on the side should be correct for that early supercharger. There or under the snout, just not the top vacuum manifold.
I'm pretty sure that the pressure shouldn't drop when you blip the throttle.
What fuel pump do you have, and is the filter new?
Lou6t4gto
Report this Post09-27-2017 07:25 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
filter was new, only 30 or so miles, could have gone bad from sitting 8 months ? pump ? I'm thinking it is a 1997 chevy truck 5.7 pump. (been a couple of years)
Lou6t4gto
Report this Post10-10-2017 03:04 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
as of Tomorrow (WED), It will be NEW NGK plugs gapped at .045, New plug wires, 3 New Coils. New TPS, New walbro pump, New Fuel, new Filters/lines, New Injectors, & New MAF. Hopefully this nightmare will finally be over. I'll let ya know.
Lou6t4gto
Report this Post10-11-2017 06:35 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fuel pressure now at 50PSI, jumps up when throttle is mashed. brand new MAF. still runs like **** ! will go for a scan within the next week or so.. the whole damn car is new except for the Icm, and I can't use it. getting very sick of this car Grrrr
Lou6t4gto
Report this Post10-14-2017 12:41 AM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
END OF STORY. I suspected all along what it was but I got pointed in every direction except that. I finally took a ICM from my project Chop Top and installed it, Now it runs like New Again ! YAY :-)
Domtech
Report this Post10-14-2017 03:41 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
So glad you got it figured out!
To diagnose that kind of thing in the future, I highly recommend that you invest $100 in a cheap android tablet and an obdII adapter.
That would have caught a problem like this quickly.
Lou6t4gto
Report this Post10-14-2017 04:33 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't even own a cell phone, doesn't a tablet require I have some kind of pay by the month service ?
Domtech
Report this Post10-14-2017 05:07 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nope, most don't have cellular and even the ones that do don't require you to use it.
If you have never had a cell phone then I understand how the idea of setting up a tablet for that could seem complicated.
85 SE VIN 9
Report this Post10-15-2017 11:58 AM Click Here to See the Profile for 85 SE VIN 9Send a Private Message to 85 SE VIN 9Edit/Delete MessageReply w/QuoteDirect Link to This Post
You can take modules to many car parts stores and have them test it. O'Reilly's has guaranteed modules. Whatever place you have it tested have them test the new one too.
[This message has been edited by 85 SE VIN 9 (edited 10-15-2017).]
