  Battery terminal wrench size?
Battery terminal wrench size? by Rsvl-Rider
Started on: 06-29-2017 12:35 PM
Replies: 14 (1399 views)
Last post by: theogre on 06-29-2017 11:20 PM
Rsvl-Rider
Report this Post06-29-2017 12:35 PM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've never been able to get a wrench to make a snug fit on a battery post connection. Maybe because they are so old and somewhat worn. I have tried all metric and SAE sizes but nothing seems to be just right. Does anyone know the correct size for sure?
wftb
Report this Post06-29-2017 12:53 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
10 metric.
Rsvl-Rider
Report this Post06-29-2017 01:13 PM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by wftb:
10 metric.
Pretty sure it's not more than 8mm...
Maybe you are thinking of the battery hold-down bolt. I am talking about the captive bolt that connects the battery cable directly to the battery.
Chris Eddy
Report this Post06-29-2017 01:22 PM Click Here to See the Profile for Chris EddySend a Private Message to Chris EddyEdit/Delete MessageReply w/QuoteDirect Link to This Post
You should try that insulated reversible wratchet wrench made for that purpose. It is slick, the reversible is good for limited depth.
https://www.fierostore.com/...px?s=51674&d=263&p=2
You could wait for your weekly parts order, no need to make an order for just one item.
css9450
Total ratings: 87
Report this Post06-29-2017 02:48 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Did you try an 8? That's what I use and it fits good. Wouldn't surprise me if its supposed to be an SAE size in actuality though.
I remember having to go buy an 8mm socket because I didn't have one...
Report this Post06-29-2017 02:57 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
5/16 is the other common size. Maybe your cable / post isn't stock?
All you can do is one large or smaller til it works.
Crescent wrench, or last ditch effort is vice grip it off and replace it.
css9450
Total ratings: 87
Report this Post06-29-2017 03:25 PM Click Here to See the Profile for css9450Send a Private Message to css9450Edit/Delete MessageReply w/QuoteDirect Link to This Post
Makes sense. 5/16 is real close to 8mm. 5/16 is 0.3125 inches or just a shade more than 8mm which is 0.31something if I remember right.
Rsvl-Rider
Report this Post06-29-2017 03:31 PM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've used both the 8mm and the 5/16" on different Fieros depending on which felt felt more secure on the particular car. Neither one fits just right but that's probably due to the rounding of the bolt heads over the years.
I'm not having a problem currently. Just wanting to confirm the size so I can buy the right size tool. I didn't know the Fiero Store carries a skinny ratchet for this purpose but they don't actually specify the size in their description either.
Domtech
Report this Post06-29-2017 04:17 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
I bought this from amazon a while back.
It is nicer than the one pictured. the one I received has an insulating plastic cover around the end like the one in the customer pictures.
It is labeled as 5/16 and fits pretty well on all 3 of my side post cars. I don't change batteries without it now.
mmeyer86gt/gtp
Total ratings: 74
Report this Post06-29-2017 04:36 PM Click Here to See the Profile for mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
if your having problems with the posts you can easily replace them on the cables i would if you are rounding off the nut on the end.
wftb
Report this Post06-29-2017 04:41 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry I forgot that the fiero came originally with side posts on the battery. Every other car I have has top posts and a 10 wrench fits them all.
Rsvl-Rider
Report this Post06-29-2017 06:57 PM Click Here to See the Profile for Rsvl-RiderSend a Private Message to Rsvl-RiderEdit/Delete MessageReply w/QuoteDirect Link to This Post
That one in the link looks exactly like the one in the fuzzy pic at the Fiero Store. But on this one at Amazon I can actually read the 5/16 lettering on the wrench.
I guess the Fiero Store knows the exact size so I'll add it to my shopping cart. Still hopin' for a Fiero Store holiday sale!
Thanks!
Domtech
Report this Post06-29-2017 07:54 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually this one from harbor freight looks pretty nice. Just like mine except red instead of blue, and only $3!
yamaha94
Report this Post06-29-2017 08:15 PM Click Here to See the Profile for yamaha94Send a Private Message to yamaha94Edit/Delete MessageReply w/QuoteDirect Link to This Post
Yep 8mm seems correct. I just used a standard socket. You have to be careful! if the end of the socket touches bare metal, and both terminals are connected - you will get a nice spark surprise! haha I say go with the tool from harbor freight. The original terminals on my battery did not have the insert and was difficult to attach any accessories like a trickle charge connector. These are the ones I used that fit perfectly. Unfortunately this is sold in Canada - http://www.canadiantire.ca/...ts-0113558p.html#srp
Report this Post06-29-2017 11:20 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Battery terminal are not metric, at least for the GM bolt head.
GM is 5/16" bolt head but if you have aftermarket bolts then anyone is guessing. (Factory bolts thread are 3/8"-16 x 3/8" long. Aftermarket lead ends have longer bolts.)
You can get a 5/16" "battery wrench" almost anyplace local. Example at HF
Handy for tight spaces but normal 1/4" drive 6 point socket works.
Always pull minus/ground before +. More so using normal tools.
Battery wrench is short and insulated enough to prevent battery shorting out.
Normal tools often can easy short the battery and dump 200+ amps.
Do not torque the bolts too tight. You will wreck the battery fast.
Side Term batteries are only made to take a few ft-lb... Max is 17 Nm 13 ft-lb/lb-ft in many GM books.
GM ACDelco cables are best. Made is get good connection w/ little effort and have "locking ears" to stay tight on the battery.
[This message has been edited by theogre (edited 06-29-2017).]
