The club has a Formula with a 95 Park Avenue 3800NA and transmission. It has a constant check engine light. The man who built the car is deceased but his girlfriend says he always had the SES light, so the light isn't really an issue.
TopNotch has connected an OBD1/OBD2 SnapOn scanner and is still not able to determine anything. Raydar tells us that the 95 Buick Park Avenue may have used an OBD 1.5 program or an OBD1 program through the OBD2 ALDL. It has a 16183247 ECM with broadcast code BNUW. Other information on the computer is 215714 BNUW and *868NUWM64271R121*
The following is quoted from TopNotch about his attempts at pulling info from the ALDL, which is an OBD2 connector. Can anyone give us any insight on how to properly retrieve information from the computer?
[Quote]:
I tried Mike's OBD1/OBD2 scanner on the car, and got wildly different readings depending on what year and VIN code I picked. According to information on this site, the VIN code for a 1993, 1994 and 1995 3800 engine is L or 1. From what I found elsewhere, 1 is the code for the supercharged version, so I used L. In 1995, they also added VIN code K for the 3800, but there is still L and 1, so I'm not sure what K is.
Anyhow, if I set the machine for 1994 VIN L or 1995 VIN L, it says there are no DTC codes in the ECM. If I set it to 1993 VIN L, I get a boatload of DTC codes, including one for PROM error and some that don't make any sense. I'm inclined to think that the 1993 result is closer to the truth.
If I set it to 1995 VIN K, it says that it can't read the system.
And in any case I have to use wires, as in this picture, because the OBD2 connector only works with OBD2. [Quote]
I couldn't retrieve the picture he refers to. It's of a 95 F-Body 16 Pin DLC (OBD 1 ALDL but OBD2 12 pin connector. He jumpered cable pin M to ALDL port 9 and cable pin A to ALDL port 5.
[This message has been edited by fierofool (edited 07-10-2017).]
