  Broken timing gear
Broken timing gear by edfiero
Started on: 07-14-2017 01:35 PM
Replies: 3 (112 views)
Last post by: theogre on 07-16-2017 05:33 PM
edfiero
Report this Post07-14-2017 01:35 PM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
What would cause this??
[This message has been edited by edfiero (edited 07-14-2017).]
ag9123
Report this Post07-14-2017 03:30 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Was the aluminum gear pressed on at the center near the camshaft or at the outer portion?
Pressing it on at any point other than the inner shoulder could weaken the gear and cause it to fail.
1984 Indy Fiero
edfiero
Report this Post07-16-2017 03:33 PM Click Here to See the Profile for edfieroSend a Private Message to edfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
Heated the gear in the oven. Froze the cam.
Gear went right on. No press was used.
Report this Post07-16-2017 05:33 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cam runs oil pump and distributor before 87. Either/both w/ problems can break the OE gear and in bad cases break the aluminum too.
87 run the oil pump.
88 neither.
Cam retainer plate must have proper clearance or the plate will bind when hot. If installed tight then can bind when cold.
spec's are in my cave.
is cover been hitting the cam gear? Picture the hubs looks like has galling like they rub.
If does and cover wasn't crushed then cam retainer likely broke.
