  Original speakers shot
Original speakers shot by ag9123
Started on: 07-30-2017 10:15 PM
Replies: 12 (596 views)
Last post by: Kevin87FieroGT on 08-01-2017 09:22 PM
ag9123
Report this Post07-30-2017 10:15 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here's a few pics of the original 4x10s that I need to replace...Foam! What foam?
1984 Indy Fiero
[This message has been edited by ag9123 (edited 07-31-2017).]
shemdogg
Report this Post07-30-2017 10:32 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
cut a piece of plywood in the shape of that speaker and get some 4x6s then cut the wood so the 4x6s fit in there. I think rodney makes adapters
shem
Report this Post07-30-2017 11:41 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can get aftermarket 4x10.
heat etc where they are makes most fail after 3-5 years no matter what brand.
cvxjet
Report this Post07-30-2017 11:54 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rodney Dickman has replacements for around $60.....I actually haven't installed them yet...But they sure look good!
Kevin87FieroGT
Report this Post07-31-2017 12:02 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Pioneer makes exact fit replacements for the front and rear. They work great with the stock radios or aftermarket. About $75-100 for both front and rear.
Front: Pioneer TS-A4103
Rear: Pioneer TS-A4672R
ag9123
Report this Post07-31-2017 02:44 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
it's amazing that the speakers put out as much sound as they did. May go with some 5.25 adapters and install component speakers. There are lots of opinions on which way to go.
I'm sure anything will sound way better than the trashed originals.. Probably a good time to install the Premium Sound System that I found on my last boneyard visit...
1984 Indy Fiero
ag9123
Report this Post07-31-2017 03:19 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
ag9123
Member since Sep 2013
I have a Rodney subwoofer speaker on the way and will probably get some 4x10 adapters from Black Top racing
1984 Indy Fiero
Report this Post07-31-2017 04:10 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have Aftermarket 4x10 coax speakers for 15+ years and while still sound good the glue on the edge to metal failed after ~ 4 years because of heat...
Dash parts can reach 150-200°F when parked and fast too. Most Electronic parts has a max storage temp 150-180°F. Many are less then that. (Cold temp's often don't help either. Speaker parts can become brittle or stiff and break when run like this.)
Fiero Rear speakers get hot too because of location and Moisture Dirt and Ozone won't help them. Old speakers there, after 3-7 years, are often junk too no mater what brand. (Dirt, hair, and worse Cleaning Chemicals get to most speakers.)
OE Radio is "dead" now because heat and age killed caps and other parts and no real interest or money to get a new or good used one. Radio may work but tape died decades age and now clock is always hours off. (I think I even have good GM CD unit but no adapters to use them.)
Spadesluck
Report this Post07-31-2017 05:28 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I did the adapters from BTR and used 5 1/4 component speakers up front. I am have them all fitted in. Have not used them yet as I am still working on everything interior wise but you can not tell from just looking at the dash anything is different.
Total ratings: 460
Report this Post07-31-2017 06:38 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
TS-A4103s have always been my "go to" speaker for the fronts of my Fieros.
I have compared them directly to the similar Kenwoods, and the Pioneers have much better bass response. One guy (a confirmed Fiero-head) even thought I had the performance sound system.
All of my rear speakers (B-pillar, not seat speakers) are the originals. They don't get baked in the sun, and are usually in okay shape, unless they've just been blown out. At least the ones I've found.
Praise the Lowered!
RWDPLZ
Total ratings: 305
Report this Post08-01-2017 07:51 PM Click Here to See the Profile for RWDPLZClick Here to visit RWDPLZ's HomePageSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what mine looked like when I pulled them, zero foam left
Kevin87FieroGT
Report this Post08-01-2017 09:06 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same here. Thought about a refurbishment of the OEM ones, but passed on that. Thirty years was long enough for the cones. Ended out doing the Pioneers.
Kevin87FieroGT
Report this Post08-01-2017 09:22 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kevin87FieroGT
Member since Nov 2010
[This message has been edited by Kevin87FieroGT (edited 08-02-2017).]
