  Electrical Troubleshooting Begins - Headlight Circuit
Electrical Troubleshooting Begins - Headlight Circuit by Bakeys
Started on: 08-26-2017 07:20 AM
Replies: 4 (240 views)
Last post by: Bakeys on 08-26-2017 07:27 PM
Bakeys
Report this Post08-26-2017 07:20 AM Click Here to See the Profile for BakeysSend a Private Message to BakeysEdit/Delete MessageReply w/QuoteDirect Link to This Post
So it begins.
'85 GT
Scenario:
Installed a JVC stereo a week or so ago. All went well. No electrical issues. (Not even sure this is relevant.)
One morning this week on the way to work, I reached over to turn on the running lights (overcast, dark morning), pushed the 'P' switch and "POP", the 20A headlight fuse went.
Got to work, dropped the fold-down fuse panel, replaced with another '20'.
Tried the Headlight switch again - "pop" goes the fuse, left headlight came up, then wouldn't retract.
Installed another fuse and it retracted.
That's where I'm at.
Where to start?
~ Fuse panel?
~ Stereo wiring?
If it were stereo related, I would think there would be a symptom showing in the stereo - power, backlighting, etc. But there's nothing.
Thanks all.
Bakeys
[i]'85 Fiasco GT[/]
cebix
Report this Post08-26-2017 08:02 AM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would look around for a short around the headlight bucket area.
seajai
Total ratings: 51
Report this Post08-26-2017 09:16 AM Click Here to See the Profile for seajaiSend a Private Message to seajaiEdit/Delete MessageReply w/QuoteDirect Link to This Post
The headlights are powered through a fuseible link at the battery so there is no "headlight" fuse. I assume you mean the 20 amp "TAIL" fuse is the one you replaced. Take a look at the 2 diagrams of the headlight switch details, it shows every item on that circuit. I would start by checking the lighting in and around the radio and center console area and work your way out from there. You may have pinched a wire somewhere and it took a couple days to wear through and short out.
[This message has been edited by seajai (edited 08-26-2017).]
Report this Post08-26-2017 10:51 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yup, something is shorting Taillight fuse.
OE Radio is wired to parking lights side of HL switch via a Brown wire and dash dimmer Gray wire.
Aftermarket "Radio" can use either or both. I would start looking at new radio wiring. But If a shop installed this... Get them to fix the problem on their dime.
Headlight bulbs have fusible link B and a breaker in the HL switch.
HL motors use Links B C & D and both sections of HL switch... Up is HL half. Down is Park lights Off and blown fuse stops Down function.
Bakeys
Report this Post08-26-2017 07:27 PM Click Here to See the Profile for BakeysSend a Private Message to BakeysEdit/Delete MessageReply w/QuoteDirect Link to This Post
Seagal and theogre,
Thank you for this info.
This is exactly the correlation between the radio and the "tail" circuit (thank you for correcting me) I was looking for.
I did the stereo job myself.
Twice.
Didn't like my choice of connectors the first time so I did it a second time.
Sounds like I gotta go back in and check my work. Specifically the brown wire and gray wire.
May be a couple few days. Got a lot going on.
Thanks fellers.
