  250 WHP Supernatural 3.4 Build (Page 1)
250 WHP Supernatural 3.4 Build by La fiera
Started on: 10-07-2017 11:04 PM
Replies: 463 (16825 views)
Last post by: Blacktree on 09-08-2020 01:41 AM
La fiera
Report this Post10-07-2017 11:04 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
This build is dedicated to those that don't give up on the unconventional builds like keeping the iron heads instead of
swapping for the aluminum heads, or discarding the 2.8/3.1/3.4 pushrod engines to install a SBC, 3800SC, 4.9 V8 or 3.4 DOHC
or whatever other engine but the original engine type.
I have no problem with the engines mentioned above, but for me personally; I want to prove to
myself that with some ingenuity, time and some resources I can build an engine that will perform in my Time Trial Duntov Fiero.
The goal is 250WHP out of a Naturally Aspirated 3.4 iron head engine with explosive mid range and killer top end.
This will be on a stock bottom end, head work, custom cam and Intake and a stand alone ECU.
Note: Some items information will not be disclosed.
The weight goal with the engine must be below 2200lbls
to have a competitive power to weight ratio.
So, here it goes:
Spadesluck
Report this Post10-07-2017 11:28 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Watching......
BillS
Report this Post10-08-2017 12:30 PM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is kind of like watching a build of a Ford V8-60 flathead where one just asks "Why?"
La fiera
Report this Post10-08-2017 01:30 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
After looking with what I had to work with it, it was obvious that my 250WHP @ 6000RPM+ goal was impossible with
factory items. Specially the stock intake and exhaust manifold, camshaft, TB, "Y" pipe and exhaust pipe diameter.
Some members have past the 200+WHP succesfully with stock components but those ponies where at low RPM, and the torque was
produced at very low RPM. Good combination for the street, but not for the road course where the engine
will spend most of its time between 3500 to 6800RPM. So, we had to come up with a system to put the power in that
RPM range but it was also important "how" that power was delivered withing that RPM window, it had to be EXPLOSIVE....!
With that idea the Supernatural concept was born!
Intake Manifold:
Size and shape of plenum and runners, injectors location, and TB size and style
was designed to the RPM window in mind.
Heads
Port work and valve size was designed to match the intake manifold, exhaust header and Y pipe flow capabilities.
Camshaft, Lifters & Springs
The most critical parts of the package. Without a camshaft to complement the intake and head combo there is
no sense in installing the head and intake with the cams and springs available over the counter.
A mechanical cam style was chosen over the hydraulic flat tapped and hydraulic roller to get the explosiveness and
top end power capabilities we were looking for. Also the mechanical cam's lash can be adjusted to make the cam
smaller or bigger and that is a plus to match the cam to the track.
The mechanical lifters are lighter than the hydraulics and the ones we used have a little pin whole to provide
the cam lobes with pressurized oil to lube and cool the lobes at the same time.
Aggressive cam profiles call for very aggressive spring rates and the available springs for the V6 iron heads couldn't be
used in our package without having serious consequences. So the heads were modified to take advantage of the plethora
of racing springs and narrow full aluminum roller rockers available for the SBC V8.
Supernatural Top End Package
Next we will compare with pictures some stock vs Supernatural items. STAY TUNNED!!
[This message has been edited by La fiera (edited 10-08-2017).]
Blacktree
Total ratings: 350
Report this Post10-08-2017 01:30 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sure the non-Fiero people look at us building up Fieros in much the same way.
[This message has been edited by Blacktree (edited 10-08-2017).]
Report this Post10-08-2017 09:47 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The goal of 250 RWHP from a 3.4L pr engine is a very aggressive one. I've built these engines and even with a turbo have not reached this goal. You can improve the performance but the engine breathes poorly. With loads of boost like 20 psi you might reach your goal but N/A I say no way.
La fiera
Report this Post10-08-2017 10:05 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Stock VS Supernatural Intake Manifolds
Stock VS Supernatural Y Pipe
This Y pipe is being upgraded to a lighter and smoother version
Supernatural Heads
Next, lets start to put the engine together!
La fiera
Report this Post10-08-2017 10:48 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Member since Jun 2008
Hello Dennis, the goal of my engine is NO TURBO, NO JUICE, 250WHP NATURALLY ASPIRATED @ 6000RPM. 3.4 PR IRON HEAD ENGINE.
I completely understand your concern in me not reaching that goal, but I'm absolutely sure I can.
So, just be patient and wait and don't ruin the expectation for the rest. Just relax Dennis!
Blacktree
Total ratings: 350
Report this Post10-08-2017 11:42 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The last dyno he posted was 240 RWHP. I'm sure he can find another 10 HP somewhere.
Just because you can't do it, doesn't mean he can't do it.
Report this Post10-09-2017 09:34 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
He is already at 240 whp on a mustang dyno, so there is clearly an opportunity to learn something from him. La fiera is shifting paradigms and that is great!
lou_dias
Report this Post10-09-2017 12:21 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just switching to a Dynojet and he is over 250rwhp. He was also using heavier than stock wheels. Honestly, looking at the heads, his are smoother but mine are ported a little more. That said - smoothening goes a long way in maintaining air-velocities.
Go La Fiera go!
[This message has been edited by lou_dias (edited 10-09-2017).]
lou_dias
Report this Post10-09-2017 12:31 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
lou_dias
Member since Jun 2000
[SIZE=3]
I like how each of the openings on that twin-butterfly TB is larger than the original Fiero TB.
twin-58mm vs 52mm stock and 56/57mm ported. I'm using the Firebird twin 48mm TB myself. But hey, we have different builds/goals with similar mindsets.
La fiera
Report this Post10-09-2017 02:08 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Go La Fiera go!
Thanks Lou!! And thanks to the rest of the crew; fieroguru and blackthree! Thanks for cheering me on
[This message has been edited by La fiera (edited 10-09-2017).]
pmbrunelle
Total ratings: 63
Report this Post10-09-2017 02:40 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
What kind of injectors are you using? They look well targeted, shooting down low.
Do they spray in a thin pencil, with perhaps less atomization/hp, or do they spray a wide fan mist, but with the possible consequence of a larger fuel puddle, and worse response?
Are you using Enhanced Acceleration Enrichment (for non-MS folks, this means transient compensation that is based on a wall-wetting model)?
It looks like the entry of the intake runners are tapered, so even though you probably don't have trumpets hidden in the plenum, it effectively does the same thing as trumpets. I like it.
[This message has been edited by pmbrunelle (edited 10-09-2017).]
La fiera
Report this Post10-09-2017 03:08 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
The injectors pattern are like a cone more than a fan and their location does both things, atomize better and at the same time they give me
the Wall-Wetting effect. But then I learn I can program the Wall-Wetting in the MS!!
You are also right about the runner shape, they act like a set of trumpets but tuned to take advantage of the induction pressure waves at mid to top end,
So technically is a Tuned Port Tunnel Ram!
I also made the runners SQUARE instead of ROUND to get as much volume and flow as possible.
And Lou Dias hit it on the nail; the head ports are matched to the intake to keep the flow velocity at high RPM\, If I would've made them bigger
the flow would slow and killed the performance.
And I'm glad you like it!
Report this Post10-09-2017 05:12 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am relaxed and certainly wishing you all the best on reaching your goal. Just believe that it will be an expensive build with a difficult platform on which to reach that goal. Not saying that it can't be done .
La fiera
Report this Post10-09-2017 08:56 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well thank you Dennis! For me this is a labor of love and I have more time than money invested in the motor. I've spend $2870 on the motor.
That includes all the parts and the machining, No R&D and no labor time.
I don't think we can put a price on the satisfaction we get when we achieve a goal!
La fiera
Report this Post10-10-2017 11:22 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Block painted after being received from machine shop and ready for assembly!
Before installing the crank I did some mods to improve oiling at the rods and mains.
I know I could've made that mod better but I did that like a fast job.
I'm working on another crank and it will be much lighter and have much work,
it will be for this block but with a much higher HP goal, same thing; NA.
Crank dropped and ready for torque!
There's more to come, stay tuned!
[This message has been edited by La fiera (edited 10-10-2017).]
Francis T
Total ratings: 119
Report this Post10-11-2017 04:04 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here's my attempt at 220+ HP @ 6 - 7+K rpm with a norm asp 2.8 engine. It's in the car waiting for me to complete the paint / body mods, get some dyno data and burn a chip.
Hopefully we'll both meet our goals!
CUSTOM VENOLA FORGED PISTONS AND WORKED RODS
[This message has been edited by Francis T (edited 10-12-2017).]
La fiera
Report this Post10-11-2017 06:10 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looking nice Francis!! Can't wait to hear it wail!! Keep up the good work!
pmbrunelle
Total ratings: 63
Report this Post10-11-2017 06:55 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Isn't a good crankshaft, a good crankshaft, period?
What would you do for an NA engine's crankshaft that wouldn't also be good for an engine having a power-adder?
Blacktree
Total ratings: 350
Report this Post10-11-2017 07:06 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
It takes power to rev up an engine. The less mass the engine has to spin up, the more power can be delivered to the wheels.
La fiera
Report this Post10-11-2017 09:26 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm sorry for not being more clear PMBrunnelle, It's exactly what Blackthree described. Make it as light as possible
and being NA I can make it lighter rather than stronger. With that in mind the rods will be of a lighter material and longer
so I can get a shorter and lighter piston.
I don't know if I mentioned it yet but I'm working on a set of 3500 aluminium heads to complement that bottom end I just
mentioned and my goal for that set up is 300+ WHP.
But that is going to take a little bit of time.
First I want to use this engine on my Fiero and start doing Time Trials. I also want to make the car lighter to decrease
my power to weight ratio for the same reason, less weight = more usable power.
[This message has been edited by La fiera (edited 10-11-2017).]
Francis T
Total ratings: 119
Report this Post10-12-2017 10:27 AM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would suggest limiting your targeted peak power to around 5k - 5.5k RPM if you have an iron crankshaft, especially with a 3.4 - which is a stroked 2.8- too much reciprocating mass.
I got lucky - cost me $110- and brought one of the last -discontinued- Eagle STEEL crankshafts, else I would not have built my 2.8 for high RPM use.
BTW Venola makes good forged pistons that are priced good.
Francis T
Total ratings: 119
Report this Post10-12-2017 05:38 PM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
Francis T
Member since Oct 2003
We've -trueleo racing- have seen our customer's 2.8 engines with our headers and intake manifolds make more than 210HP and those were with stock or mild cams, stock heads, stock pistons, and stock ECU chips! BTW on the flow bench with our intake the 2.8 iron heads flowed enough CFM to support 300+ HP.
It will no-doubt take a lot of dyno time and probably, more than a few chip burns to get the tuning spot-on.
That said, I don't think his or my goal HP is impossible.
NOTE: I did not state the above to get new customers, whereas do to my medical issues and my son's very successful road racing program, we no longer make products for the 2.8 - 3.4 engines.
Blacktree
Total ratings: 350
Report this Post10-12-2017 05:50 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3.4 V6 bottom end is safe up to about 6500-7000 RPM (assuming it's in good condition). But anything beyond that is pushing your luck. Looks like Rei is going to improve the odds with lighter weight pistons and rods. That will push the RPM envelope a little higher.
Edit to add: for what it's worth, I'm going to be following in Rei's footsteps. Although I won't be taking the engine build quite as far as he is. But I also have a crazy intake manifold (from Ryan Falconer), and a "secret weapon" camshaft that Rei made for me. Plus the heads will be race ported. And I already have the Trueleo headers. Should make for a lively engine.
[This message has been edited by Blacktree (edited 10-12-2017).]
La fiera
Report this Post10-12-2017 06:32 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well my redline is 7100RPM and my engine gets there pretty quick. But right now I have the rev limiter set up at 6800 for one reason,
When the engine gets to the rev limiter it cuts off fuel and spark (makes big BOOM and shoots flames!) and I can flat shift and even though I have flat shift capability in
the MegaSquirt I prefer the rev limiter method. The car just pulls like a freight train non stop in all the gears, I love my 4:10 gears with the welded diff!!
Mike, let mie know when you put that head, cam and intake combo. I can assist you with the tuning specially low to mid range with that cam, the stock timing table simply wont work. But don't worry we got you covered
Blacktree
Total ratings: 350
Report this Post10-12-2017 06:51 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome!
Edit to add: Can't you select what the ECM does to limit the revs? I know with my 7730 setup, I can have it retard the spark, cut the fuel, or both. Maybe there's a setting in the MegaSquirt for that?
(PS: I prefer to use the spark retard only, because that's easier on the engine)
La fiera
Report this Post10-12-2017 11:06 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Awesome!
Yes I can. I'ts very adjustable. I can cut spark only, fuel only or both. But I think it makes that POP and make flames because the injectors are high in the
runners and even though it cuts the fuel and spark, there is some fuel on the walls of the manifold that when digested and gone through the hot exhaust pipes
raw that fuel is at the right temperature to ignite but it can't because there is no oxygen, once it gets to the tip of the exhaust it ignites and you can see the flames and
hear it.
I also have the high rpm decel (7100 to 4500) at -0.3 timing and enriched on purpose it makes loud poping sounds and the flames can be seen from miles!!!
Its awesome!!!
I have it like that so it can help with the scavenging of the exhaust thus increasing my intake draw in also. It works pretty good and keeps my throttle response sharp.
I have stainless steel racing valves designed for that torture.
One thing I tell you, you know when you see most of the cars when they hit full throttle and all you see is black smoke? You don't see that in mine, mine burns clean and the AFR's are right on target.
But don't worry, once you are ready just let me know and I'll make a special trip!
[This message has been edited by La fiera (edited 10-12-2017).]
Francis T
Total ratings: 119
Report this Post10-13-2017 12:34 AM Click Here to See the Profile for Francis TClick Here to visit Francis T's HomePageSend a Private Message to Francis TEdit/Delete MessageReply w/QuoteDirect Link to This Post
It makes loud poping sounds and the flames can be seen from miles!!!
Its awesome!!!
Yup unspent fuel meeting say a hot muffer would do that. Back in my younger, more devious days before the invention of steering wheel locks, we discovered that turning the ignition off for maybe 5 seconds on say a highway and then back on would produce a nice loud boom. It could and often did explode the muffler. Yeah, we used it to scare AHs on the highways. Lol it was especially effective when going through an underpass.
To avert such you may want to cut the fuel off too.
BillS
Report this Post10-13-2017 11:04 AM Click Here to See the Profile for BillSSend a Private Message to BillSEdit/Delete MessageReply w/QuoteDirect Link to This Post
On my turbo Fiero, the limiter was set to simply cut fuel - there was no popping, the fire just went out if you exceeded a certain preset boost pressure or if there was knock. Very disconcerting if you aren't used to it - you wonder what you blew. Most spark limiting systems just eliminate every other spark to the plugs and the engine still runs but 'goes flat' without allowing any increase in engine speed.
I grew to appreciate the over-boost limiter - only happened occasionally on long straights using full boost.
La fiera
Report this Post10-14-2017 11:14 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Prep the bores for piston installation.
I used my own assembly lube. Its hi in MOs2 thus the grey color.
Pistons get coated with a MOs2 dry lubricant on the top and skirts
This dry lubricant is also a shield for hi temperature.
Rings gapped for my application and going in.
I opted for +.040 pistons to increase compression
The block was decked to purposely have the crowns of the pistons protrude out.
You can see how much the crown comes out. That is a flat bar on top of the piston
and the gap between piston crown and engine block is pretty wide.
Torque mains and rods to the specified torque and mark them as you go along!
The bearing clearances of the mains and rods have been checked already.
I opted to be on the looser side so I have to use 10w-40 and up oil.
Next is the cam and lifters. Besides lubing it up I apply a coat of dry MOs2 lubricant!
This is a mechanical cam and lifters set up with high pressure springs, so lubrication on start up
is very important!!
Now the lifters. Look closely at the first picture and you'll see a little pin hole on the face of the lifters. These lifters supply pressurized
oil to the cam lobes. Now you know why I opted for the HV oil pump?
Install timing chain. I chose the Double Roller for this motor.
In my 170WHP 2.8 I used a stock timing chain and with the 2100 racing miles I did
the stock chain stretched considerably!!!! So, I learned my lesson.
Make sure to apply plenty of assembly lube between the chain, sprockets and slider.
Next, the heads go on. And I will reveal with what compression ration I ended up with! Stay tuned!!
[This message has been edited by La fiera (edited 10-21-2017).]
pmbrunelle
Total ratings: 63
Report this Post10-14-2017 11:32 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's the idea of putting the MoS2 stuff in the cylinder bores? Won't that slow down the ring+bore break-in?
Obviously, the engine seems to have been a success, but I'm not sure if that step was a good one.
What kind of oil do you use? Does it have lots of ZDDP ? I suppose there are more ZDDP-filled choices in the 40-weight and up viscosities...
Is the camshaft black because it has been nitrided?
And how did you drill the lifters without leaving a burr?
La fiera
Report this Post10-15-2017 12:30 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
ZDDP is a very good extreme pressure lubricant but the more pressure exerted on ZDDP the more draggy and inefficient it becomes
because it requires energy to overcome the friction. In the other hand MoS2 and WS2 don't have that problem, the opposite happens.
I add MoS2 solid lubricant to the assembly lube to be safe when turning the engine for the 1st time.
I use Comp Cams mineral 30W Breaking Oil for the first start up and 30 mins of engine running.
I also drive the car with the breaking oil and do plenty of accel and decel at different RPMs to seal my rings.
The following oil change is a 10W-40 rich in MoS2 and good ZDDP, so MoS2 is the main anti-friction additive.
I've built many engines and the follow this procedure and have never had an oil comsumption problems due to rings not sealing.
The camshaft is coated with MoS2 dry film before the assembly lube is applied.
The lifters are made that way. Its called "Cool Face"
They have a .024 hole that is precision
machined in the face of the lifter. No
significant oil pressure loss, but significantly
improved cam and lifter longevity
La fiera
Report this Post10-21-2017 11:20 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Installing the pump.
The Camaro pump and screen where used because the screen pump hole and the screen pipe are bigger diameter.
The pump mounts without a gasket but I always use liquid gasket between the mating surfaces to create a tight seal.
Bottom end ready for the top end!
La fiera
Report this Post10-24-2017 10:04 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lets put some heads up!
After torquing both heads the rockers are installed and lashed!
Intake and headers on and torqued.
If you want a REAL harmonic balancer, this is it. After shredding the stock one apart because it couldn't take the RPM I decided to to do some research and found this is the best of the best. Engine revs so fast, free and clean!! I'll never go back to stock!
La fiera
Report this Post10-24-2017 10:15 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
I need some money to keep up with the project so lets work on some expensive cars!
I love this part of my profession. People buy Lambos and Ferraris and Porsches and I drive them for free!!!
Report this Post10-25-2017 10:32 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Cool stuff.
I am a fan of Mos2 as well.
Whats your opinion on running an oil that comes with moly in it all the time, not just break in? Or Moly additives? New or old engines.
Report this Post10-25-2017 10:41 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
Do you have a list of car lightening mods?
La fiera
Report this Post10-25-2017 01:27 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by 2.5:
Cool stuff.
This is the oil I use in all my cars. I have used it for years and never had a problem. It is a REAL antifriction oil.
It has 1200ppm of Phosphorous, 1100ppm of zinc and 1300ppm of Mos2 if I remember right.
Its the perfect match for the flat tapped equipped engine
You can get it in at Advance Autoparts now since they bought WorldPac.
[This message has been edited by La fiera (edited 10-25-2017).]
