This is odd... I have an '88, thus the Gen 2 lights, and RM's low profile projectors.
They worked fine when they were first installed, but now the left one won't go all the way up, by about 5 degrees. But it seems to be a mechanical/geometry problem. The light goes all the way up, and locks into place, as normal. It's just that "all the way up" isn't all the way up. As I said, they worked fine when they were first installed. |
watch motor(s) same as above.
a broken output shaft or dowels doesn't always total die to start and try to open and/or close.
If motor(s) stop same time as output shaft then look for binding anywhere.
1 example: Many low lift mods cut off or otherwise eliminate HL lift bearing points that was to run on door plastic strips. W/o those bearing points the lift hit the door anyplace and can have problems no matter how good the motors and module are.
Those bearing points and Door slip strips to 99+% opening the door.
2 more aux contact points on HL trim may hit the door or not only when lift is all the way up.
[This message has been edited by theogre (edited 10-31-2017).]
