  1988 Fiero GT Medium Red Metallic Paint Job Maybe HOK Brandy Brandywine (Page 1)
1988 Fiero GT Medium Red Metallic Paint Job Maybe HOK Brandy Brandywine by Edo
Started on: 10-29-2017 02:18 PM
Replies: 51 (3340 views)
Last post by: hercimer01 on 08-21-2021 04:59 PM
Edo
Report this Post10-29-2017 02:18 PM Click Here to See the Profile for EdoSend a Private Message to EdoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hello. Just an introduction here. This is Ed's GT. I have started this thread in his name because its his car and he doesn't get on the internet much. We are tracking the progress here. Enjoy!
The bumper covers had to be stripped because of the cracks in the clear coat.
I ground it off with 80 grit. Then 180 grit.
High Build primer, guide coat and block sanding.
Got new sunroof tracks on the the way from the Fiero store.
[This message has been edited by Edo (edited 05-23-2018).]
Total ratings: 206
Report this Post10-29-2017 04:16 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Black primer, gold base and HOK Brandywine is an incredible finish...
[This message has been edited by olejoedad (edited 10-29-2017).]
jaybug56
Report this Post10-29-2017 06:38 PM Click Here to See the Profile for jaybug56Send a Private Message to jaybug56Edit/Delete MessageReply w/QuoteDirect Link to This Post
I will be watching the progress.
Edo
Report this Post10-30-2017 10:12 PM Click Here to See the Profile for EdoSend a Private Message to EdoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Still investigating options.
Were definitely going with base coat clear coat for simplicity. KBC01 or C2C-KBC01 ( Don't understand the difference)
Any experience with that?
Total ratings: 206
Report this Post10-31-2017 07:09 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, sorry.
La fiera
Report this Post10-31-2017 07:40 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome to the forum Edo and your car is going to be awesome when finished.
Report this Post10-31-2017 12:51 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Welcome
Chris_narf
Report this Post10-31-2017 05:14 PM Click Here to See the Profile for Chris_narfSend a Private Message to Chris_narfEdit/Delete MessageReply w/QuoteDirect Link to This Post
That sounds like it'll look delicious. I can find lots fo pics of that color over black, but not over gold. Ironically, I found this thread with that color here
hercimer01
Report this Post10-31-2017 10:37 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks guys.
Hi guys. I'm actually doing the work and posting pics to this thread. That was me getting this thread rolling. From now on if you se a post from Ed, it will actaully be him. I'l be just posting pics in the first post and comuncating as hercimer (Allen)
hercimer01
Report this Post10-31-2017 10:41 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Member since Mar 2008
I've seen that thread.That paint is Kandy Apple Red and Brandywine mixed over black. That is a true candy paint job. Not base coat clear coat. I reaqlly like that. Thats what im going to do on my Black 86GT.
12.840@104.8 MPH Intense-Racing 1.9 rockers, 3" exhaust, 3.4 pulley, ZZP tune and 18 year old tires.
88 Coupe under construction SOLD
88 formula 3.4L 4t60 swap SOLD
Edo
Report this Post11-02-2017 06:48 PM Click Here to See the Profile for EdoSend a Private Message to EdoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hi guys. I am new to this so this should be fun.Allen is painting my car so I know it is in good hands.
hercimer01
Report this Post11-07-2017 01:45 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I jumped the gun on the body work. I need to do the mods first.
[This message has been edited by hercimer01 (edited 11-30-2017).]
hercimer01
Report this Post11-16-2017 11:41 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I think were going all out on this one! Mopar 6 Pack Scoop!
Getting some hi build on finally.
[This message has been edited by hercimer01 (edited 05-18-2018).]
hercimer01
Report this Post11-28-2017 10:31 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Finally done shaping the scoop!
hercimer01
Report this Post11-30-2017 12:27 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
For a little modern touch!
hercimer01
Report this Post12-04-2017 12:18 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
The headliner was not salvageable. Joann fabrics has holiday coupons in their App. 50% off the material was only 8.18$ For 1 yard.
Clean the old foam and glue off with 80 grit sandpaper.
Repair the visor mounts with fiberglass material..
2 coats of resin.
2 coats of DAP Weld Wood contact glue on the board and the material. Be careful not to super soak the material.
Carefully lay on the material losley and roll out with a clean roller.
Don't forget to leave enough edge material inn the middle to tuck it in with the sunroof trim.
Got the headliner done and up. The finger prints will relax out with time and heat.
[This message has been edited by hercimer01 (edited 12-06-2017).]
hercimer01
Report this Post12-17-2017 11:54 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
AR digital cruise control. I made a wiring diagram but still need to convert it from PDF to JPG. I will post it later.
I found this on a LS forum. Its for a manual install.
[This message has been edited by hercimer01 (edited 09-04-2019).]
unboundmo
Report this Post12-18-2017 01:25 AM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had to redo my headliner also... I have a T-top---- actually, not to mention as well ---- that I have your car combo almost exact T but with the beachwood interior instead.. but same medium red and gold rims.. that first picture was like looking back in time 😏
Anyway, for the headliner, my foam was crumbly in areas so I taped it all back in place..after, I wrapped all the foam with seran wrap because I was afraid that the fiberglass resin would eat the shape of the foam.. and put divots.. like your "finger prints" you say... Did you have any issues working with the resin and the foam?... I know certain glues eat foam also...?
hercimer01
Report this Post12-18-2017 09:14 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
No problem with the glue. I used DAP Weldwood contact glue.
hercimer01
Report this Post12-29-2017 12:36 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post04-01-2018 09:34 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Winter time blues in April! Uhgg!
InTheLead
Report this Post04-02-2018 05:18 AM Click Here to See the Profile for InTheLeadSend a Private Message to InTheLeadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Out of curiosity what type of flex agent needs to added to the paint and clear to avoid the spider web cracking on the poly/flexible body parts?
Interesting thread, I've painted a few of my own and need to address issues with cracking already. Super super disappointed it happened so I'm trying to learn what needs to be done.
hercimer01
Report this Post04-18-2018 11:05 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Flex additive will make the paint/clear coat more flexible, but it is only temporary and intended only to allow the flexible bumper cover to be installed. The paint will harden over time to normal. I didn't use any on mine and had no trouble but i did sand all he original paint off down to the factory primer.
hercimer01
Report this Post04-18-2018 11:23 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Here is a test panel finally.
(No dust control or appropriate dry time between coats. Rush job.)
DP90LF Primer (black) 3 coats
C2C KBC01 basecoat 3 coats
3 coats of HOK USC01 clearcoat.
And a comparison with the factory Dark Red Metallic.
[This message has been edited by hercimer01 (edited 04-19-2018).]
hercimer01
Report this Post04-18-2018 11:24 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
I love how the black shifts away from the direct light.
[This message has been edited by hercimer01 (edited 04-18-2018).]
hercimer01
Report this Post04-19-2018 05:00 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
This is Brandywine over OEM black and OEM silver metallic.
It looks like less black fade over the silver but not much.
Silver on the left.
Outside.
[This message has been edited by hercimer01 (edited 04-28-2018).]
Shho13
Report this Post04-19-2018 08:14 PM Click Here to See the Profile for Shho13Send a Private Message to Shho13Edit/Delete MessageReply w/QuoteDirect Link to This Post
That color is very nice, it looks like the paint is 10 feet deep!!!
It's gonna look really good!!!
"Discord"
Let's Go Mets!
( ͡° ͜ʖ ͡°)
Report this Post04-20-2018 12:27 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Good color
hercimer01
Report this Post04-26-2018 11:03 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Starting repairs on the side scoops.
hercimer01
Report this Post04-27-2018 11:18 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I have no idea why the PO drilled holes in the door jams on the scoops.
hercimer01
Report this Post05-03-2018 10:55 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Shaved the antenna.
Steel
Report this Post05-04-2018 12:56 PM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Too dumb to install them properly.. saw a set of scoops at a show last year screw into the car that way...
Looking real good enjoying your progress. + for a good thread.
hercimer01
Report this Post06-01-2018 10:48 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Lil bit of progress.
[This message has been edited by hercimer01 (edited 06-01-2018).]
hercimer01
Report this Post06-28-2018 02:59 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post06-29-2018 01:02 AM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post07-30-2018 11:55 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
Getting close to final spray.
hercimer01
Report this Post08-03-2018 04:19 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
Report this Post08-19-2018 09:02 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
I got started but had to stop because it rained. To humid, the door skin started to blush on the corner. I fixed it with adhesion promoter. It still needs another coat.
hercimer01
Report this Post08-19-2018 09:06 PM Click Here to See the Profile for hercimer01Send a Private Message to hercimer01Edit/Delete MessageReply w/QuoteDirect Link to This Post
hercimer01
If any one has had experience with blushing please chime in.
Edit: 09/18/2024
The blushing was the the KBC-01 base coat . The humidity was over 60%. Alot of the parts turned gray due to blushing. From what I had already known from furniture finish repair, you need to resoften the lacquer if you get a gray ring or spot due to heat or water. So I ended up spraying the parts in base coat (rear bumper cover and other panels) very lightly with BullDog Adhesion Promoter. You can see it in the next pic. It softened the base coat and the color came back like normal once it had a chance to recure slower.
[This message has been edited by hercimer01 (edited 09-19-2024).]
Spadesluck
Report this Post08-19-2018 10:42 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I need to repair a side scoop myself, how did you fill in the holes? Did you just use a fiberglass resin?
