https://www.fiero.nl/forum/Forum2/HTML/132779.htmlMy experience with a OEM block heater on the 2.8L.
It’s been installed for sometime now with no leaks and it still heats just fine. You can view the heater I installed online, it was plug and play for the 2.8L block freeze plug hole . The block heater was an easy install. Only issue is you have to refill coolant when finished. Many mm sizes are available if your freeze plug hole is a different size on the 2.5L.
All block heaters and in-line heaters fail heating at some point, just like a heater sold to drop in your coffee cup. The problem becomes just how much trouble to replace. I don’t see the block heater/ freeze plug style being any harder to do than the others, you need to refill the coolant for 90% of them anyway.
Some will say the heater restricts the coolant flow. Trust me, on the 2.8L stock coolant system it’s not an issue!
Personally I feel the block heater is the best result as it warms the entire block which is the goal in the first place. After all it’s not till the block warms that the coolant warms and you get heat to your seat.
[This message has been edited by Kevin87FieroGT (edited 11-21-2017).]
