OBD1 Scanners won't track fuel/oil/coolant pressure.
Most times won't see intermittent problems because slow data that only updates 1-2 x per sec.
Yes, Can work if you wiggle/pull a wire to cause the problem longer then a few seconds. If you have these most times looking can tell or check output for most sensors using a volt meter. Volt meters will display in real time and way faster using a scanner. Back prob connection or pierce wire w/ a needle. If you pierce then water proof the small hole just wipe silicon or brake grease.
Yes, If Data stream for any ECM/PCM says sensor is "bad" first check grounds and other things highlight in vid above. To Many morons, code = bad whatever and replace and does nothing
but still you pay for the part. That's Including Shops only hire ASE mechanics and Dealer shops w/ "factory certified" people.
See my Cave,
Scan Tool Help and most of rest of section.
| quote | Originally posted by GTaylor: I paid $1800.00 for the above back-in-the-day. Professional tool not cheap parts store junk. I am unaware of any OBD-I aftermarket scan tools. The OTC is very easy to use. Plus it does Ford/Dodge/GM and Asian vehicles if you find the update. I actually have the Asian cables i forgot to send with my old scanner when i sold it.. |
don't bother to check?
Currently have several types on the market and most are cheap. example
http://www.reddevilriver.com/aldl.html and have Bluetooth version too.
Even in 80's-90's AutoXray and a few others had them and cheaper then that and available thru many parts stores.
I have AutoXray GM only scanner for close to 20 years and cost under $200. Got mine on sale at pepboys < $150.
AutoXray
2500 reads obd 1 and 2 for $222 at Actron div of Bosch Auto.
