  300WHP Supernatural 3.XX Coming Soon! (Page 11)
This topic is 14 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14
300WHP Supernatural 3.XX Coming Soon! by La fiera
Started on: 01-01-2018 09:47 PM
Replies: 534 (17598 views)
Last post by: La fiera on 01-15-2024 10:39 AM
Blacktree
Total ratings: 350
Report this Post05-22-2021 11:34 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by La fiera: ... they feed the opposite side. I was able to locate them 7 inches higher up for better atomization and to absorb heat from the incoming air.
The Falconer intake does that too, probably for the same reason. The injectors are high up in the manifold.
La fiera
Report this Post05-22-2021 08:14 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, Google University graduates know nothing about this, they just follow trends. Most of the time I have to go back in time to leap miles and years fordward!
ericjon262
Report this Post05-22-2021 08:24 PM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
injector placement is an interesting topic, the further away you are, the more cooling, the closer you are, the higher the accuracy of the supplied fuel. the trick is finding the middle ground that works for each application, and the ever important packaging problem, it has to fit on the engine to work!
cognita semper
Total ratings: 236
Report this Post05-23-2021 10:20 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Shower injectors above per-cylinder throttles have long been the way for high RPM engines... but that doesn't work for OEM emissions and drivability needs.
Highly optimized racing carbs deliver better mixture *quality*, in terms of mixture homogeneity and dropley size, than port EFI, although port EFI has superior metering and mixture ratio control.
Most port injectors shoot one or more streams rather than a shower or spray of droplets. The need for better atomization in direct injection applications drives 4 digit fuel pressures.
So with large upstream injectors, theoretically there's a sweet spot for injection timing that results in all the fuel injected getting trapped in the cylinder on a cycle-by-cycle basis, rather than averaged across multiple cycles. This window is easy to hit with port injection, but increasingly offset from the valve events as the injector goes further upstream.
In addition, even with stoichiometric combustion in the chamber, an engine with a lot of overlap that traps all the fuel in the chamber will show lean on an EGO sensor because it's sending air out the exhaust port.
[This message has been edited by Will (edited 05-23-2021).]
fishsticks
Report this Post05-23-2021 11:06 AM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't forget that the longer you can keep fuel in the plenum/runner, the more air charge cooling it can do.
Rei, ever thought about doing ITBs? It'd be a packaging nightmare, but you're already into tall intakes.
La fiera
Report this Post05-23-2021 04:59 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's in the drawing board. Meantime the intake for the "9,000RPM Supernatural" is almost finished.
It's the SR1 Supernatural intake which I dubbed as "Meet the fogger", the nickname implies its purpose.
Total ratings: 236
Report this Post05-23-2021 08:23 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Have you ever just tried a Falconer intake?
lou_dias
Report this Post05-24-2021 07:34 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
...eventually Rei will design a Smokey Yunick V6...
La fiera
Report this Post05-28-2021 08:47 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did a compression test today after some miles on the rings and all cylinders are right at 235psi, the 3.4L was about 218psi. The 3.4L had a 244@.050 duration cam and the 3.7L has a 250@ .050 cam. Even bleeding more compression with a bigger cam the 3.7L is looking to my spectations! Bone cold engine.
[This message has been edited by La fiera (edited 05-28-2021).]
Blacktree
Total ratings: 350
Report this Post05-29-2021 11:54 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just out of curiosity, what's the static compression ratio?
La fiera
Report this Post05-29-2021 12:54 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
According to my calculations taking every detail made to the heads and short block into account it is 11.58:1 exactly. Its a huge difference from the calculated dynamic compression of 15.99:1 which is the product of the compression test results divided by atmospheric pressure. The 3.4L also had the same difference in dynamic compression being much higher than the calculated static compression.
fishsticks
Report this Post05-29-2021 01:18 PM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Would you mind showing your math on this? I don't believe DCR can be higher than SCR, since it's a function of stroke and cam timing. Atmospheric pressure doesn't really come into play since it would be a variable depending on where you are, and DCR doesn't change once calculated.
What did your combustion chambers CC out to once you were done working the heads? Curious as I think you said your pistons are above deck at TDC now. DId you have to cut valve reliefs?
Are you giving up on pump gas and turning this into an E85 only ordeal?
This is an excellent starter on DCR for those who are unfamiliar.: http://cochise.uia.net/pkelley2/DynamicCR.html
La fiera
Report this Post05-29-2021 08:21 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I haven't use gasloline in years. Wait, I get E85 at my local gas station, so it is pump gas right!?
fishsticks
Report this Post05-30-2021 11:05 AM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
We used to have an E85 pump up here. But the station shut down.
Blacktree
Total ratings: 350
Report this Post05-30-2021 12:16 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by La fiera: According to my calculations taking every detail made to the heads and short block into account it is 11.58:1 exactly.
Wow. The difference between the cylinder pressure and SCR is impressive! Heads and intake for the win!
Notorio
Report this Post05-30-2021 01:33 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fishsticks, thanks for posting that. It actually makes a lot of sense. I'd love to see a timeline laid out showing a cylinder's pressure over time, when valves operate, piston position, pulse width of the injected fuel and spark. It would help to see the variables we can play with on that timeline for engines like ours with fixed valve timing. I don't know if I agree that there is No Compression until the intake valve is fully seated but it does highlight that at least Some of the compression stroke is wasted, early in the cycle.
[This message has been edited by Notorio (edited 05-30-2021).]
fishsticks
Report this Post05-30-2021 06:09 PM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are a lot of moving parts in that timeline, especially when you factor in things like cam overlap vs engine RPM. I'm not an ME, just a guy who's built a lot of engines, so the calculus involved in generating that is a bit beyond me.
It's interesting to see the various methods camshaft manufacturers have used to manipulate the intake charge. Example:
Comp XER lobes open relatively gradually, but then slam the valve shut very quickly to try to start building compression ASAP.
Ultradyne/Lunati Voodoo lobes open the valve extremely fast to maximize use of the intake stroke on heads that flow well at high lifts, but close the valve much less abruptly than Comp XER lobes.
[This message has been edited by fishsticks (edited 05-30-2021).]
Notorio
Report this Post05-30-2021 11:38 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very interesting!
La Fiera, you've mentioned that you get custom grinds for these builds. Can you tell us about these kinds of decisions you are making? Is there software that can simulate the results given a set of variables?
Total ratings: 236
Report this Post05-31-2021 08:24 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Comp lobe might work better with a long rod (or small port) flat tappet engine at high RPM while the Lunati lobe might work better with a short rod roller cam big port engine with a carb.
fishsticks
Report this Post05-31-2021 10:56 AM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep. Lunati cams seem to have a stronger vacuum signal at similar durations and (usually) make a touch more torque. They're a bit rougher on valve springs though.
I've heard of people seeing accelerated valve seat wear from some of the more aggressive Comp lobes, which makes sense.
fishsticks
Report this Post05-31-2021 10:57 AM Click Here to See the Profile for fishsticksSend a Private Message to fishsticksEdit/Delete MessageReply w/QuoteDirect Link to This Post
fishsticks
Member since May 2021
Very interesting!
Engine Analyzer Pro is a pretty good sim software. I use it to make cam choices for engines. It takes a lot of input variables, and the more info you have to plug into it, the more accurate the results that comes out of it.
https://www.performancetren...ine-Analyzer-Pro.htm
La fiera
Report this Post05-31-2021 09:35 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very interesting!
I personally don't use any analizer software. I use simple math with the128 rule and modify it depending the application and expectations.
La fiera
Report this Post05-31-2021 11:27 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Member since Jun 2008
Changing the subject, I did some front facia removing to make room for the new aero package. The original hood was about 54lbs and this one is 21lbs. I was able to take off 40lbs off the front nose. I want to add 3 times that on down force with the least possible weight to make the downforce gain dynamic. so lets begin!
La fiera
Report this Post06-20-2021 03:17 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/j0BYoie0d-M
Idle tuning is done! Only took me one hour or so to get it where I wanted it.
My neighbor from around the corner came to my driveway with his grandson clear an argument they had about what was making that sound.
The grandpa said "it sounds like a chain saw" and the granson said, "No grandpa, it's a muscle car". So, they had to come to my house to find out.
Grandpa was very impressed, "that little thing is making all that sound?" Were his first words when he saw the engine compartment. We chat for a while, they took pictures and I found myself another Fiero fan, the grandson! He wants a Fiero for his first car!
Report this Post06-20-2021 03:49 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
The grandpa said "it sounds like a chain saw"... Grandpa was very impressed, "that little thing is making all that sound?"
Grandpa must've used massive chainsaws in his day!
Lambo nut
Total ratings: 257
Report this Post06-20-2021 03:53 PM Click Here to See the Profile for Lambo nutSend a Private Message to Lambo nutEdit/Delete MessageReply w/QuoteDirect Link to This Post
So they were both disappointed?
La fiera
Report this Post06-20-2021 07:21 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, turns out grandpa was a racer back in the 60's and he loves tunnel ram intakes. He was really impressed with my intake.
The other thing that he was amazed by was the change in engine sound from idle to hi RPMs. I don't know if you've seen the video where I take the car out for the first time. The people I sent that video to had different oppinions about the sound. Some said it sounds like a rotary, others said it sounds like a two stroke, others said it sounds like an F1 car from the 70's and my brother said it sounds like a Group B Rally car from the 80's.
The one thing I get from those feedback is what I'm after, one unique engine with one unique sound that no one has.
La fiera
Report this Post07-04-2021 08:10 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Some progress! Between the trunk and some miscelaneos stuff I've manage to shave off 40lbs! Next is taking off the heater box!
La fiera
Report this Post07-06-2021 11:03 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Notorio
Report this Post07-06-2021 11:53 PM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/TfOT3mynSN8
Glad to see that you are OK. Bravo on the quick action to save your car and garage. It's a bit sad to see another 'Fiero on fire!' incident but it's a good reminder for us all to have an extinguisher handy at all times.
La fiera
Report this Post07-07-2021 12:08 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad to see that you are OK. Bravo on the quick action to save!\ your car and garage. It's a bit sad to see another 'Fiero on fire!' incident but it's a good reminder for us all to have an extinguisher handy at all times.
I have two now. One pointing to the gas tank and another one pointing toward the firewall header. And another one handy to use it whereve I need to. Not just with a Fiero, but you neve know
Total ratings: 236
Report this Post07-07-2021 07:13 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oooopsie
Good that nothing worse happened.
I couldn't tell from the video... it was an oil leak around the filter?
[This message has been edited by Will (edited 07-07-2021).]
La fiera
Report this Post07-07-2021 08:05 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Oooopsie
What happened was that I modified the adapter that mounts on the block because it has a restriction. By doing that I took out half of the threads on one side. I must have damaged the threads when doing that because when I was installing it it was hard to turn. I meant to replace it but I sincerely forgot about it.
Total ratings: 236
Report this Post07-07-2021 08:20 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
D-oh! Filter adapters are apparently finnicky... mine is taking up a lot of time as well.
Is there one of these that fits your filter adapter? https://www.gopurepower.com/
Steel
Report this Post07-07-2021 09:48 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Glad you caught it in time!
La fiera
Report this Post07-07-2021 12:22 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
They have the filter but not the adapter. The adapter is Metric 18x1.5 but the remote filter I use SAE out of a '95 Mustang 5.0L.
Total ratings: 236
Report this Post07-07-2021 12:26 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do you need to replace your adapter or is it ok as is?
You could screw their filter onto your current adapter, right?
La fiera
Report this Post07-07-2021 08:09 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
My kit consists of 4 parts:
1- Oil bypass adapter
2- Lines
3- Remote oil filter location and a good oil cooler.
z/
But I decided to go back and investigate what caused the Oil bypass adapter to come off the block and cause that fire!! Look at this!
That part cocked to the side attaches to the block and then bypass adapter screws to it securely right, wrong!!!! Look at the angle.
that's how much wobble there's in the threads. Obvioulsy this oil bypass adapter has the wrong threads, it's standard not metric.
So, the question is; How did it held up all these years and now decided to give up?
I spend a lot of time blueprinting the oil pump and the bypass itself, I must have increase its volume and pressure by 20%at least just my by massaging the oil pump and the adapter.
Look at this for example:
This is how the adapter is when you get one. Do you see that wall there? That creates cavitation and creates bubbles in the oil.
Now, this is how I fixed that!
I smoothed out the oil flow by blending those walls in. Now the pump works more efficient, not dealing with restriction and now it can put out all that flow and pressure without costing energy.
Since the oil pump is working more efficient in tandem with the oil bypass adapter, now I can understand why the fire took place!
I had the wrong threads all along!!! The nipple being cocked gives you an idea of how much play there is between the nipple and the bypass adapter!
[This message has been edited by La fiera (edited 07-07-2021).]
Blacktree
Total ratings: 350
Report this Post07-08-2021 12:22 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
So you have to use a coupling with metric threads on one side, and SAE on the other? LOL
La fiera
Report this Post07-08-2021 01:30 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
No, I ordered a bypass with the metric threads!
