  300WHP Supernatural 3.XX Coming Soon! (Page 4)
This topic is 14 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14
300WHP Supernatural 3.XX Coming Soon! by La fiera
Started on: 01-01-2018 09:47 PM
Replies: 534 (17572 views)
Last post by: La fiera on 01-15-2024 10:39 AM
La fiera
Report this Post09-20-2018 11:59 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by lou_dias:
Which block are you using? 3500/3900 VVT?
3.4 PR
Total ratings: 236
Report this Post09-20-2018 12:25 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Iron heads won't work with the 99mm bore block
lou_dias
Report this Post09-20-2018 01:25 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by La fiera:
3.4 PR
To get to 3.7L - are you using a different crank? or will you really just bore it to hell and back and cross your finger?
La fiera
Report this Post09-20-2018 03:27 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Travis D
Report this Post09-20-2018 08:14 PM Click Here to See the Profile for Travis DSend a Private Message to Travis DEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.fiero.nl/forum/Forum2/HTML/140469.html
Look at this thread. That's what I'm using now in the 3.4 250WHP Supernatural. SBC solid lifters.
The block is in machine shop getting the last bore correction to fit the pistons. The only difference between the 3.4 and 3.7 is the bore.
And of course, the entire rotating assembly is lighter. But to answer your question; yes, I'm working on it. I should have the the short block ready
in 2 weeks. I will not install it right away. I want to see how much more I can squeeze out of the 3.4 Supernatural and then the 3.7 will go in.
Glad to hear it! Sorry I thought I'd read that whole thread but I guess not. I really like what you're doing here.
La fiera
Report this Post09-21-2018 12:15 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Its all good! That's what I said "look at this thread". I don't read entire threads either, I skim over them and get the entire idea. But yea, stay tuned!
La fiera
Report this Post09-21-2018 12:28 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Member since Jun 2008
Its not 99mm bore Will.
Total ratings: 236
Report this Post09-23-2018 09:41 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL. Lou asked if you were using the 3500/3900 block. The LZ4/LZ9 block has a 99mm bore from the factory, but is incompatible with the iron heads. Try to keep up.
[This message has been edited by Will (edited 09-28-2018).]
lou_dias
Report this Post09-24-2018 03:17 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL. Dennis asked if you were using the 3500/3900 block. The LZ4/LZ9 block has a 99mm bore from the factory, but is incompatible with the iron heads. Try to keep up.
I believe they bolt up but since the bores are offset, things aren't lined up directly. I forget who posted a picture of one how it lines up... However it looks *possible* to use...
My engine builder was trying to sell me a 3500VVT block. It looked just like at 3400 block until I noticed the VVT menchanism and then I took note of the offset bores...
[This message has been edited by lou_dias (edited 09-25-2018).]
La fiera
Report this Post09-25-2018 08:53 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lol!! I'm sorry Will! Louis made that question. I've been following your thread on your car and the lines look pretty good! When is it going to be ready?
lou_dias
Report this Post09-26-2018 11:20 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Now I remember... It was Joseph Upson that showed that iron heads will bolt up to the VVT blocks.
Total ratings: 236
Report this Post09-26-2018 08:01 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
"Possible" is a many-splendored thing.
If iron heads were made to work on the 99mm bore block, both deck surfaces would be more welding rod than virgin iron.
Total ratings: 236
Report this Post09-26-2018 08:03 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Member since Jun 2000
The end of the year?
Don't ask which year, though.
I bought a new place when I got back from Afghanistan (1.2 acres in DC Metro!) but now I don't have a garage, so I go to my dad's on the weekends to work on the car.
ETA: Err... Ooops; Yeah, Lou
La fiera
Report this Post09-28-2018 09:42 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I see! That's why I made sure that the last house I bought the garage is as big as the house!
Total ratings: 236
Report this Post09-28-2018 12:14 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well... since I have 1.2 acres...
La fiera
Report this Post09-28-2018 11:23 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
You win, I have 1/2 an acre!!
Total ratings: 236
Report this Post10-02-2018 06:39 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'd rather have your mortgage
La fiera
Report this Post10-02-2018 11:21 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
simplify and things will get easier! (Small Cubes)
La fiera
Report this Post11-03-2018 08:47 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Got the short from the machine shop and now I'm just test fitting the pistons. I did this mathematically so the test fitting would verify my calculations and that it would work, and it did. Stay tuned!
La fiera
Report this Post11-18-2018 09:44 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rotating assembly in and torqued. Next items are the camshaft, timing chain and oil pump and then its going to wait to take the place of the 3.4.
As far as the car I ordered a set of mounts and shift cables and the fixture to install an F23. Also have the LSD installed in the F23. I also have the new clutch kit.
I should have it running soon, I'll keep you posted.
Blacktree
Total ratings: 350
Report this Post11-19-2018 05:38 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Neato! Are you going to share the engine "recipe" if everything works out?
La fiera
Report this Post11-19-2018 07:55 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, with the ones on my team! And you are one of them
La fiera
Report this Post03-25-2019 07:55 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Calculated the piston to head clearance to get the custom made head gaskets ordered.
It'll have 11:52.1 compression ratio.
Total ratings: 236
Report this Post03-26-2019 08:36 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're missing the crank sensor.
La fiera
Report this Post03-26-2019 06:56 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes! I use it as a plug!
Total ratings: 236
Report this Post03-26-2019 07:15 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
"I wouldn't say I've been missing it, Bob"
La fiera
Report this Post03-26-2019 07:41 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Marley??!!
Total ratings: 236
Report this Post03-26-2019 08:13 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Report this Post03-26-2019 09:04 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
White folks stuff I guess!!! I'm from the Caribbean so you know I don' t speak your jargon
Spadesluck
Report this Post03-26-2019 10:44 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
That was an "Office Space" movie reference. Lol
La fiera
Report this Post04-05-2019 09:37 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Report this Post04-19-2019 01:14 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since I'm upgrading the valvetrain to make it more efficient I had to re-work the cam profile I previously had
to take advantage of the valvetrain upgrade. Also taken into consideration was the "Race Pipes" that I have
on the 3.4 now and the percentage of exhaust to intake flow ratio. I dubbed it the "370 GTO" cam
WIth a primary coat of dry Molibdenum its going in with plenty of Gibbs Racing breaking lube!
Timing chain on and camshaft degreed.
thedrue
Report this Post04-19-2019 02:59 PM Click Here to See the Profile for thedrueSend a Private Message to thedrueEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are doing some great work and it is exciting to see someone else pushing the 60degree engine platform. I look forward to your results.
That being said I do wonder why you are using the Camaro engine and not any of the highly available roller cam blocks? I have moved away from flat tappet completely and see no reason to even be messing with it in this day and age. Not to mention that any of the later blocks have a much easier to seal cast aluminum structural oil pan with better bottom end support and a windage tray. They also have an OEM oil cooler option that is really trick. I just view it as a much better starting point in my opinion and is just as easy to mount and work with as the Camaro engine.
Keep up the good work and I cant wait to see how this engine performs... I may have to copy some of your bottom end ideas for my next race engine!
La fiera
Report this Post04-19-2019 11:43 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well thank you very much for your kind words and complements!
But to answer your question on why I don't use the highly available roller cam block, the one thing that keeps me away from them is the weight of the lifters.
A good solid flat tappet lifter weights 60 grams and the roller lifter in your V6 weights about 325 grams.
That is almost five and a have times the weight of one solid lifter! Now multiply that weight times 12.
On roller lifters only, your engine is carrying 8.60lbs of extra weight
That means that if you are running a very aggressive cam you must have a very hi pressure set of springs to prevent valve float and keep those lifters under control.
If you are a visual person like me here are 2 pictures that represent the weight difference between a roller and a solid flat tappet lifter.
That's 3 exhaust valves and 1 push rod from the stock 3.4/2.8 engine and 1 pen.= 1 roller lifter
Thats 2 intake valves out my 206cc Go-Kart engine.= 1 solid flat tappet lifter.
Also your RPM climb will slow down due to the weight of the lifters and the engine will loose between 1300 to 800rpm also due to the extra weight.
And then last but not the least, the timing chain will stretch easier and faster due to the lifters weight.
So, the bottom line is that the few hp you think the roller cam gives you due to friction, It will require 5 times that same hp to run it because of the weight of
its components.
On a low RPM, slow response UPS or FEDEX truck rollers lifters work wonders! But on a All-Out racing engine I'll never use them.
Now, if everything is lighter, the engine will rev faster, more freely and higher. Will need less spring pressures and less timing chain stretch.
My goal is not only 300WHP, but also how fast it gets there.
Report this Post04-20-2019 09:51 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rei,
The real benefit of the roller lifters isn't the reduced rotating resistance, it is the roller tip allowing lobe ramp rates far beyond what a flat tappet allows (flat tappet lobe ramp rates are limited so the edge of the tappet doesn't gouge the cam lobe). The faster ramp rate gets you to the higher lift portions of the profile faster and you stay there longer with the same overall duration which provides a significant area under the curve benefit to them.
Solid roller lifters are lighter than hydraulic rollers (but still heavier than flat tappet) and might be a good compromise, but I also don't know if there are any aggressive roller cam options for the 60 degree V6 family either. It might be worth getting a roller lifter and cam and dial indicate the ramp rate profile between the two.
lou_dias
Report this Post04-20-2019 11:39 AM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
WOT-Tech sells a variety of roller cams...up to .540" lift IIRC.
I just switched to E85 and I'm still tuning but I picked up 7rwhp and 8 or 9 ft*lbs... If you don't care about fuel economy and just want even more power, I recommend it.
thedrue
Report this Post04-20-2019 11:43 AM Click Here to See the Profile for thedrueSend a Private Message to thedrueEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the response! I knew you must have had a very good reason for doing what you do, engines like this don’t happen by accident.
I think you might want to rethink your roller lifter weight though. LS lifters, the same diameter but taller than 60° lifters, appear to weigh 122 grams. I would expect a 60° roller lifter to weigh less than double a flat tappet. Combine that with the shorter pushrod weighing less and the weight penalty may not be as great as you think. Also I believe the roller lifter is inherently more reliable and can take higher spring loads better. Although flat tappets have been very successful they just take much more care to not screw up the cam.
I have a set of roller lifters on my bench but no scale to verify. There are also no solid rollers or other performance hydraulics available for this platform. I just went through all that. I thought the v8 lifters would work but they’re too tall.
Anyway, I’ll keep following along and rooting for you, good luck!
La fiera
Report this Post04-20-2019 11:01 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
The cam on this engine is .550 on the intake.
Total ratings: 236
Report this Post04-21-2019 10:36 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rei,
This.
At the same peak lift, the greater area under the lift curve means that a roller cam can get way more air into the cylinder than a flat tappet cam.
Would a *MECHANICAL* LS roller lifter work?
There are a LOT of those on the market, including ones with the roller riding on pressurized oil instead of needle bearings, making them immune to bearing failure with stiff springs and high ramp rates.
Total ratings: 236
Report this Post04-21-2019 10:42 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't have one to weigh, but this is definitely not an accurate weight. That's 10 oz.
