  300WHP Supernatural 3.XX Coming Soon! (Page 8)
This topic is 14 pages long:  1   2   3   4   5   6   7   8   9   10   11   12   13   14
300WHP Supernatural 3.XX Coming Soon! by La fiera
Started on: 01-01-2018 09:47 PM
Replies: 534 (17599 views)
Last post by: La fiera on 01-15-2024 10:39 AM
La fiera
Report this Post11-21-2020 07:02 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/yhUBSUyTT9k
Assembling the Longblock.
Blacktree
Total ratings: 350
Report this Post11-22-2020 12:11 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Nice
pmbrunelle
Total ratings: 63
Report this Post11-22-2020 03:35 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your videos are getting better, but it is hard to hear you speak. I had to make the volume very high, then when the music came on, it was blasting.
What does it mean when you say you calculate the camshaft duration based on the rod/stroke ratio?
Is this a La Fiera secret-sauce calculation, determined over years of finding what works?
La fiera
Report this Post11-22-2020 08:29 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I know, sorry you couldn't hear me properly. That is everyone's complaint. As far as the secret sauce I can say it is something like that.
I take EVERYTHING into consideration when designing a cam. People say camshaft designing is a black art, not for me. It is just common sense.
I don't built my engines to make HP, I build them to make torque. And since HP is a mathematical calculation of how fast that torque is delivered, the HP would find its place if you build engines to produce the highest torque per cubic inch. That would also give you an idea of how efficient and effective the engine is using the air/fuel mixture to make power.
You got a PM. Read it and I'd like to hear your thoughts on it. I did that approach year ago on an engine without knowing (by mistake) and after doing a lot of research on why that engine was so powerful I came across this.
sourmash
Total ratings: 50
Report this Post11-22-2020 09:06 PM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
I turned on the close caption and it said something about a lobster and a celebration. Was it a Rock Lobster?
I think it turned 6 degrees of extra duration into a six year celebration. I'm not sure what a "narrow lobster handle" might be though.
[This message has been edited by sourmash (edited 11-22-2020).]
La fiera
Report this Post11-23-2020 07:39 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
LOL!! Narrower lobe center angle is what I said. I know, it's all my fault! I'll see if can find a microphone that works with my Iphone.
sourmash
Total ratings: 50
Report this Post11-23-2020 08:22 AM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ok, lol, I should've gotten that. It's looking ver-nice.
Blacktree
Total ratings: 350
Report this Post11-23-2020 02:09 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by pmbrunelle: Your videos are getting better, but it is hard to hear you speak. I had to make the volume very high, then when the music came on, it was blasting.
I had the same problem, when I started making videos. To balance the audio, I had to crank up the microphone gain quite a bit. There should be a setting for that in the voice recording app. I also had to turn down the volume on the music. You can do that in the video editing app.
pmbrunelle
Total ratings: 63
Report this Post11-23-2020 08:29 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
You did publish the title of the paper in your video, so you could share it here for other folks to read.
So there are perhaps four aspects to consider with the quick-return:
1. With a certain amount of air/fuel mixture in the cylinder, how can the most work be performed on the piston face? The is is called the indicated work. The study you refer to only analyses this aspect of the engine performance, so it's a bit incomplete (not the big picture). Also, it's only computer simulations, so who knows how good those are? The paper did not mention if they adjusted the (simulated) spark advance for different values of offset; I think that optimum spark advance could change.
My personal feeling is that quick-return is not good to maximize indicated work on the piston.
Ideally, to reduce the load on the crankshaft during the compression stroke, the spark should be delayed as late as possible. Then, at TDC, the spark should light the mixture, and the mixture should completely burn, causing the pressure to rise. Then, the piston should move down from TDC, ideally once combustion is complete. This is the ideal. In practice, we seek to have the mixture burn fast, and the spark is advanced relative to TDC; this gives a compromise between negative work on the compression stroke, and positive work on the power stroke.
With quick-return, could the piston start moving down prematurely, preventing the pressure from getting high and pushing down hard on the piston?
2. At the start of the intake stroke, as the piston moves down, this movement kick-starts the movement of the slug of air inside the intake runner. In your engine builds, this seems to be a key factor to success. The quick-return could have a large payoff due to this.
3. Side load on the piston is affected by offset. Since this is for racing, if the engine wears out a bit faster, I don't think you have to worry about that. This doesn't look like a 100 000 km 5-year warranty kind of project.
Side load can cause friction. Friction in the engine is why power available at the flywheel is less than indicated power.
4. Assuming that your racing class limits the displacement, you cannot verify compliance with the normal formula:
number_cylinders * crank_stroke * bore * bore * pi / 4
You can use the formulas in the paper to find your true displacement.
General remark: On the big-bore 60° V6 models such as LZ9, the piston bores are offset (away from the camshaft) by 1.5 mm (I think that's the number). I don't know if the piston pin is centered in the piston. Anyway, if the ECM uses the same tune for both banks, then that means that 1.5 mm shift is not significant.
The piston motion is the same for these two scenarios:
Pin centered in piston, bore offset
Bore centered, pin offset in piston
ericjon262
Report this Post11-24-2020 01:44 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
OEM's have been offsetting piston pins for years to better balance the thrust loads on the cylinder walls.
La fiera
Report this Post11-24-2020 08:16 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Very true Eric.
La fiera
Report this Post11-24-2020 08:41 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Member since Jun 2008
The reason I sent it to you was because since you are an engineer and an analytical person, I wanted to hear your input on the matter.
This is only one of the reference material I used to do my research.
I also read a paper from an Italian kart engine manufacturer where the shorter ratio engine was much faster on the short and twisty tracks.
On the tracks that had long straights the long ratio engine was king.
I've been working on this rotating assembly and everything that comprises the engine for 2 years and after I was satisfied then I made it a reality.
The only custom parts on it are the pistons.
As far as the increase of wear and friction I don't think is going to be a problem. the 3.4L has a rod ratio of 1.72, My 3.7L has a rod ratio of 1.63; same rod ratio found in the 5.7L Chevy smalblock and I have personally seen cars and trucks with those engines hit 200,000 miles on the odometer.
ericjon262
Report this Post11-24-2020 09:00 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm not sold that rod ratio is worth much of anything as long as you aren't at some kind of crazy extreme.
Total ratings: 236
Report this Post11-24-2020 09:27 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Reher-Morrison peeps have said it's just not important to maximum power... but they're into Pro-Stock, which is neither roundy-round nor road course action.
That doesn't mean rod ratio is not important to getting the combination to run at its best... meaning that there's probably some cam optimization that works better with long rods than with short rods, as well as some level of voodoo with regard to vacuum pulses at the venturi for those running calibrated lea--errr... carburettors.
sourmash
Total ratings: 50
Report this Post11-24-2020 09:37 AM Click Here to See the Profile for sourmashSend a Private Message to sourmashEdit/Delete MessageReply w/QuoteDirect Link to This Post
All racing is to an extreme.
ericjon262
Report this Post11-24-2020 10:10 AM Click Here to See the Profile for ericjon262Send a Private Message to ericjon262Edit/Delete MessageReply w/QuoteDirect Link to This Post
True, my statement wasn't meant to imply that it should be brushed aside and forgotten about, but more that for most people operating on the level at which we are probably won't notice a difference between a short and a long rod, as long as the rod isn't ridiculously out of normal range.
My point isn't that racing isn't extreme, my point is that the ratio would have to be off by a massive value to have a noteworthy difference. IE, you probably won't see a difference going from a 1.65:1 to a 1.72:1, OTOH, if you were to go from a 1:1 ratio to a 1.72:1 ratio, there would potentially be a pronounced difference in performance.
La fiera
Report this Post11-25-2020 08:58 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here where I live there's a lot of short oval races and the advantage of the short rod ratio (SRR) engine can clearly be seen on those short tracks.
The SRR car leaps and accelerates like a Cheetah off the corners, pulling away from the LRR car. By the time the LRR car stretches its legs and gets close to the SRR car, it is time to hit the brakes. The same process repeats lap after lap. In 20 laps the SRR car almost puts a lap on the LRR car. Now, on a longer track it would be a different story.
I've also heard from local 1/8 mile drag racers that the LRR engine makes more power on the dyno but the SRR is faster on the track. Then again, there has to be an advantage.
I can see where the LRR engine would shine; 1/2 mile drag race, 1 mile oval track, road race at Daytona, Lemans, etc.
In my case I opted for the SRR because the tracks I frequent are short, have tight turns and there's not much straights.
La fiera
Report this Post11-27-2020 07:12 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
So, got the trans together this evening. Does anybody know what is the torque spec for that bolt?
Thank!
La fiera
Report this Post12-05-2020 07:07 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Update!!
The Quife is finally installed
And the trans is ready to go in!
Upgraded rods, pistons and cam are installed along with the water pump and oil pan.
The only things I'm waiting for are the lifters. They were in back order but they are finally on their way.
Other miscelanious stuff I'm waiting on are: Modded tall valve covers with vents, new solid clutch disc and "The Fogger" TR5 intake manifold.
I'll start the engine for break-in with the TR4 intake to simplify things.
claude dalpe
Report this Post12-05-2020 10:36 PM Click Here to See the Profile for claude dalpeSend a Private Message to claude dalpeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Good job Rei What kind of clutch and model are you going to install
pmbrunelle
Total ratings: 63
Report this Post12-05-2020 11:48 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
So finally you decided to do the transmission work yourself, versus your usual transmission shop guy?
La fiera
Report this Post12-06-2020 07:39 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had a Stage 4 Spec pressure plate to use with this engine but I used the disc on the 3.4L.
Wanted to get the same disc but somehow I can't get it. So, I got the equivalent from ACT.
La fiera
Report this Post12-06-2020 07:48 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
Yes, he was taking too long. It was very easy with the right tool which I ended up making out of my old clutch diskc.
I replaced one bearing which I found locally for $27, OE brand.
claude dalpe
Report this Post12-06-2020 11:13 AM Click Here to See the Profile for claude dalpeSend a Private Message to claude dalpeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The transmission is an f23 is the pressure plate you specified is for an f23? or for fiero if I am not mistaken the pressure plate of the f23 has a smaller diameter to take place in the belhousing of the f23 than that of a fiero? if so does it support all the engine power you have? I ask because I have an f23 in reserve in case my getrag breaks because I also have more power than the original 2.8 (3.5 LX9)
Thank you Rei
La fiera
Report this Post12-06-2020 12:26 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you Rei
Thanks for the observation Claude! I'll check that today and let you know!
La fiera
Report this Post12-06-2020 09:03 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
La fiera
This is the pressure plate I used on the Supernatural 3.4L (Ebay)
This is the pressure plate I plan to use on the Supernatural 3.7L (Spec)
Supernatural 3.4L pressure plate.(Ebay)
Supernatural 3.7L pressure plate.(Spec)
Claude, the diameter of both pressure plates are the same but I found a couple of differences.
If you look at picture 1 and 2, pay attention at the fingers that come in contact with the through out bearing.
Picture 1 looks like the TO bearing is too small. Pic rure 2 looks like the pressure plate fits the throw out bearing better.
Now, look at pictures 3 and 4. Pay attention to the height of the plates. Ebay plate is higher than Spec's.
That leads me to believe I had the wrong pressure plate all along!
claude dalpe
Report this Post12-06-2020 09:44 PM Click Here to See the Profile for claude dalpeSend a Private Message to claude dalpeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rei
When you ordered your pressure plate from spec did you choose an f23 and what is the diameter of the new friction disc to work with this pressure plate.
Did you need to shim the throughout bearing with the old pressure plate or now with the new spec?
La fiera
Report this Post12-07-2020 12:42 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Rei
I bought it for the 5 speed '85-'88 Fiero. Model number is SCC884.
Total ratings: 236
Report this Post12-07-2020 12:49 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Be careful with compatibility... some people have had problems with some Fiero clutches when used in F23's. Do a fit check and rotate the engine before doing the final assembly.
La fiera
Report this Post12-07-2020 02:47 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the recommendation Will! I'll make sure to double check.
Total ratings: 236
Report this Post12-07-2020 08:38 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Did you just add the pics? I haven't seen them before.
Do you run your transmission with the bellhousing cut away like that?
La fiera
Report this Post12-08-2020 02:04 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, to allow some clutch cooling. The flat bottom I'm building for the car will have a big NACA duct aiming to that opening.
La fiera
Report this Post12-09-2020 10:28 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correction, the Spec pressure plate number is SCC883.
I put it in the back on the trans and pressed down on the plate to depress the hydraulic throw out bearing and while spinning it there was no contact whatsoever.
I'll repeat the same test once the trans is attached to the engine.
Total ratings: 236
Report this Post12-10-2020 10:03 AM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Right... the diaphragm spring compresses as it's bolted to the flywheel and the pressure plate ends up deeper into the bellhousing because of the thickness of the flywheel.
La fiera
Report this Post12-10-2020 11:43 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Steel
Report this Post12-11-2020 06:31 AM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yowza, that's like a small skyscraper.
Interested to see your dyno results!
Cool build.
La fiera
Report this Post12-11-2020 07:41 AM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
Cool build.
Thank you! I'm a big fan of Tunnel Ram intakes and this is my version of one!
Blacktree
Total ratings: 350
Report this Post12-11-2020 05:27 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by La fiera: I'm a big fan of Tunnel Ram intakes...
Same here. (tunnel rams and cross rams)
ragoldsmith
Report this Post12-11-2020 05:54 PM Click Here to See the Profile for ragoldsmithSend a Private Message to ragoldsmithEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://youtu.be/EqCNvLj4ytc
Wow, I really, really like the white headers. I never would have thought of doing white. It looks great with the red! I may have to steal this idea when I do my 3800 swap...
Ryan
1986 Fiero GT "FierBro"
La fiera
Report this Post12-11-2020 08:33 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
You can steal it from me because I stole it from the Ferrari's F1 cars of the 60's and 70's!
