  Oil Pressure Sender Relocation?
Oil Pressure Sender Relocation? by Spadesluck
Started on: 01-27-2018 02:22 PM
Replies: 8 (387 views)
Last post by: fierofool on 02-15-2018 05:33 PM
Spadesluck
Report this Post01-27-2018 02:22 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would like to relocate the oil pressure sender right off the motor itself. Anyone foresee any problems? I am also going to upgrade to the 88 style sender as well.
Total ratings: 154
Report this Post01-27-2018 03:24 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
It's a little more difficult on AC equipped cars, but it can be done. You'll need a 90 degree street elbow with 1/4 NPT male on one end and female on the other end. You might even need Rodney's fitting to go along with it.
Here's a picture of one that f85gtron did. The AC isn't shown, but he later installed the compressor and it's mounts.
Report this Post01-27-2018 07:36 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
can be done w/ standard pipe fittings...
See my Cave, Oil Sensor
fittings listed may not work for some but tells size(s) etc.
Spadesluck
Report this Post01-27-2018 07:55 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks gents for the informations.
Lou6t4gto
Report this Post02-12-2018 01:33 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Do it just like the 2.8s were done. a 90 degree fitting, a 5/16" steel line to "wherever you want it" and a female fitting for your sender. I've done it many times. I always put it somewhere that you can just " Lay your hand on it". LOL
Lou6t4gto
Report this Post02-12-2018 01:35 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou6t4gto
Member since May 2008
while you're at it, put a "T" in the line for a Mechanical pressure gauge !
Spadesluck
Report this Post02-12-2018 04:36 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Lou, I thought about a gauge but thats just one more thing to go wrong or leak. ha
The plan is just to keep it down low and out of site. The original is just a massive (literally) eye sore.
f85gtron
Report this Post02-15-2018 05:21 PM Click Here to See the Profile for f85gtronSend a Private Message to f85gtronEdit/Delete MessageReply w/QuoteDirect Link to This Post
That is a 45° elbow fitting. Hope this helps.
Total ratings: 154
Report this Post02-15-2018 05:33 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sorry, Ron. I thought you used a 90.
