  2.5 in line fuel pressure gauge "Valve" ?
2.5 in line fuel pressure gauge "Valve" ? by Lou6t4gto
Started on: 02-02-2018 04:34 PM
Replies: 5 (180 views)
Last post by: Lou6t4gto on 02-12-2018 01:08 PM
Lou6t4gto
Report this Post02-02-2018 04:34 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
WHAT can I rob a "shrader valve" off of to splice into the "4 cyl Fuel line" (1985) for a Fuel Pressure Gauge ? I've got a few from 3800s, but the tubing looks too large in diameter.**
seems the aftermarket ones only come WITH A GAUGE, don't need the gauge. thanks
Report this Post02-02-2018 08:35 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Report this Post02-02-2018 09:07 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I forget if there is accessible rubber fuel line in the duke engine bay, but if there is, you could do something similar to what I'm doing with my Subie.
I'm using two 5/16" (8mm) brass hose barbs screwed into either end of a brass tee. All threads are 1/8" FPT/FIP/MIP, which match those on the fuel pressure gauge.
It's possible the duke fuel lines would require slightly smaller hose barbs (1/4"?), so double-check if going this route.
[This message has been edited by Patrick (edited 02-02-2018).]
Report this Post02-03-2018 03:34 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Permanent Fuel Pressure gauges should be a gauge made for the use. Any cheap gauges often leaks and very bad for you.
testing only See my Cave, TBI Test Adaptor
Duke Link above work with the fuel filter.
Others replace the filter.
but cave #'s have change or discontinued. some new # listed in other threads.
https://www.fiero.nl/cgi-bin...orum=2&thread=137062
found this now... https://www.amazon.com/Tool...s-Test/dp/B001DUV4GA replace the filter for testing w/o bending etc to fit.
L4 only runs 9-13psi and most 100psi gauges can't read low pressure accurately.
[This message has been edited by theogre (edited 02-03-2018).]
Lou6t4gto
Report this Post02-08-2018 06:22 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
everywhere I look for that adapter (LINKS) say no longer Available.
Lou6t4gto
Report this Post02-12-2018 01:08 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
ended up using a aluminum AC "T" with shrader valve and cap, Worked perfectly, $4. holds exactly 13 PSI at all times. But drops like a rock the second it's shut off !
