  Who has the stainless steel braided brake lines?
Who has the stainless steel braided brake lines? by viperine
Started on: 02-15-2018 12:04 PM
Replies: 13 (671 views)
Last post by: viperine on 02-18-2018 06:57 PM
viperine
Report this Post02-15-2018 12:04 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
And whose did you buy? Fiero store or Russell's?
Any fitment issues? Quality concerns?
I realize that OE replacements are just fine, but actually cost the same. I figured I would simply upgrade anyway.
Any input is appreciated!
Russell 692110 is the part number, at quick glance.
Total ratings: 465
Report this Post02-15-2018 03:42 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by viperine:
Russell 692110 is the part number...
Maybe someone with an '88 can answer this... Does this same kit fit the 88's as well as it fits the earlier years?
viperine
Report this Post02-15-2018 04:35 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
It seems that we'll soon find out. $99 shipped from summit racing, and it'll be here overnight. I need to replace the front calipers on Manda's 88 this Sunday since we are driving it to Tennessee the following Saturday. Here's to hoping that the fronts are the majority of the culprit.
VanGTP5000
Report this Post02-15-2018 05:53 PM Click Here to See the Profile for VanGTP5000Send a Private Message to VanGTP5000Edit/Delete MessageReply w/QuoteDirect Link to This Post
I am running TFS set $116.43 shipped. No issues...nice addition.
-Van
mrfiero
Total ratings: 150
Report this Post02-15-2018 07:23 PM Click Here to See the Profile for mrfieroSend a Private Message to mrfieroEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Russell brake lines on my stock '88 GT as well as my modified '88 GT. They fit and work very well, but they don't come with anything to hold it to the upper control arm. You'll need to buy some small clamps to hold the lines away from the wheel. I tried modifying the stock brackets, but wound up damaging the braided line (kept binding up and eventually snapped the end off).
I just use a sturdy zip tie on the rear ones (attached to the strut)...seems to work just fine.
To answer the fitment question....yes, they fit all '84-'88 Fieros.
Total ratings: 465
Report this Post02-15-2018 08:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks.
cvxjet
Report this Post02-15-2018 09:22 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have the Ocelot lines from the Fiero Store; They fit and work well....I too used Heavy duty zip-ties in the rear between the lines and the strut. 1985 SE V6 with 88 rear subframe and 88 brakes all around.
George P Wood
Report this Post02-15-2018 09:38 PM Click Here to See the Profile for George P WoodSend a Private Message to George P WoodEdit/Delete MessageReply w/QuoteDirect Link to This Post
TFS, work great.
unboundmo
Report this Post02-16-2018 12:33 AM Click Here to See the Profile for unboundmoSend a Private Message to unboundmoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I just went down to the store, Hose-man.. 25min from here .. and just made me some on the spot.. I believe, any hose specialty store could make them for you .. no shipping cost too. Just bring the old. I don't remember the cost, though, for the brake lines.. they made my oil cooler to/ and return lines also.
[This message has been edited by unboundmo (edited 02-16-2018).]
PK
Report this Post02-17-2018 12:51 PM Click Here to See the Profile for PKSend a Private Message to PKEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't believe there is any advantage over rubber coated items but they were way cheaper than importing. Mine made by Goodridge locally.
tshark
Total ratings: 68
Report this Post02-17-2018 02:17 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
viperine
Report this Post02-17-2018 02:27 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
I appreciate everyone's input. I will post pictures of the Russell hoses either tonight or tomorrow, and comment on fitment when I install at least the fronts on Sunday. Manda's 88 almost definitely has a collapsed hose based on how it brakes and kicks the brake light on without loss of fluid.
viperine
Report this Post02-17-2018 11:52 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
viperine
Member since Feb 2015
Some pics of the bare product. No clips for securing the slack line, I will either reuse the OE clips from the original hoses, or use heavy duty zip ties. Very smooth and attractive.
Will post pics installed tomorrow.
viperine
Report this Post02-18-2018 06:57 PM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
What a massive fail. I could NOT get the OE brake lines off at the flare fitting. Stripped one side, started to strip the other side, and called it quits. I opted to replace the calipers anyway.
They are installed and bled, but the brakes still do not work well at all.
The brake light comes on when the soft pedal reaches full travel, then shuts back off once the pedal is pumped a little. The car can be driven, but shouldn't be.
Starting to suspect the master cylinder. No evidence of leaks, and the rubber hoses bled just fine.
