  WinALDL works on Windows 10
WinALDL works on Windows 10 by ag9123
Started on: 03-07-2018 01:20 PM
Replies: 3 (1118 views)
Last post by: theogre on 03-12-2018 12:34 AM
ag9123
Report this Post03-07-2018 01:20 PM Click Here to See the Profile for ag9123Send a Private Message to ag9123Edit/Delete MessageReply w/QuoteDirect Link to This Post
I was using my old Windows XP notebook to log WinALDL data until it finally crapped out.
I found the following link online that explains how to set up your Windows 10 laptop
to work with WinALDP.
http://forums.ihpartsameric...owthread.php?t=13290
1984 Indy Fiero
Total ratings: 465
Report this Post03-11-2018 02:33 AM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm still using an old WinXP laptop with WinALDL... but I'm glad to see there are newer options if required. Thanks for the info.
lou_dias
Total ratings: 67
Report this Post03-11-2018 02:23 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is probably the same issue I'm having with TunerPro RT not reading from the com port...
Report this Post03-12-2018 12:34 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
If usb com port work w/ XP and others then can try that above.
Can try new drivers for ALDL tool in Win10 too. Some use same chip to run them but can't find data right now. maybe search for red river aldl new driver here.
But... USB isn't completely "Universal" even now. Some examples:
Some older USB (1 to 2) can have problems when used on USB 3(& 3.1) that many newer laptop only have.
Some times setting in the "BIOS" are problems. Other times is a problem w/ windows or USB main/root hub drivers or default settings for it/them.
(Some USB3 devices don't work is some USB 1 or 2 ports even in same system.)
And if you run 64 bit Windows, many old devises will have problems. Mainly because many Never made a x64 driver and can't use a x86(32bit) signed or unsigned driver.
Note: Some USB and even 9 pin com ports won't work w/ old methods to connect to GM OBL1 ALDL ports. Max232 and others works electronically but many Com ports can't handle nonstandard bit rates. Many problems like these in the PFF archives for old systems w/ WinXP.
[This message has been edited by theogre (edited 03-12-2018).]
