  The thing under the front fascia...
The thing under the front fascia... by Troy Eckhardt
Started on: 03-08-2018 07:15 PM
Replies: 7 (714 views)
Last post by: randye on 03-20-2018 05:50 PM
Troy Eckhardt
Report this Post03-08-2018 07:15 PM Click Here to See the Profile for Troy EckhardtSend a Private Message to Troy EckhardtEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't know what it's called, but I suppose its job is to give the urethane fascia some support, and probably to crumple a bit on impact. Mine is rotting - in a way that I never imagined plastic could rot. What is this thing called? Can I get one online somewhere? I suppose all of the originals must be a rotten as mine - right?
Report this Post03-08-2018 09:19 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ummm... wrong. I have never seen a "rotten" one. Yours looks like it's sustained an impact or two.
I don't know where you'd find replacements, except from off another Fiero. There's at least three different styles of this egg-crate material, depending on the model (nose) of the Fiero.
[This message has been edited by Patrick (edited 03-08-2018).]
Troy Eckhardt
Report this Post03-09-2018 07:09 AM Click Here to See the Profile for Troy EckhardtSend a Private Message to Troy EckhardtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, Patrick,
Thanks for the answer. I will see if I can find a replacement in a junkyard somewhere. It's an '88 GT.
Here's a little history:
I have had this car since '94, and there were no collisions while I owned it. Of course, I can't say anything about the first six years. After 145,000 miles, 30,000 or so put on the car by me, it began to have an engine knock, so I put it in the barn. A marriage, seven children, and the growth of a business happened while the car hung out in the barn, until about three years ago when I began taking things apart in an attempt to get it roadworthy (and pretty) again. When I took this part out, it was not beautiful, but it wasn't literally crumbling like it is now. It's actually turning to powder, and this happened while stored in a box, (not in sunlight) off the car, in the last three years.
So, yes, it may have been hit (I do remember some cracked cells when I took it off,) but now it's actually rotting. When I touch it, it is brittle and just shatters. I assumed that they all suffered this fate, but if you've seen more than one, you have more experience than I do.
Perhaps if I replace the urethane fascia with fiberglass I don't need this piece. I need to replace the fascia anyway, and I was leaning toward urethane because of its resiliency, but...
Thanks again,
Troy
GKDINC
Report this Post03-09-2018 11:49 AM Click Here to See the Profile for GKDINCSend a Private Message to GKDINCEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have this part I would sell for $30.00 If you could pick it up in Cape Coral FL.
Good Luck
Thanks Gary
Troy Eckhardt
Report this Post03-09-2018 11:57 AM Click Here to See the Profile for Troy EckhardtSend a Private Message to Troy EckhardtEdit/Delete MessageReply w/QuoteDirect Link to This Post
Hey, Gary,
Thank you for replying.
That's about 4 hours away. What would you charge to ship it? Patrick says there are several types - are you sure it's good for an '88 GT?
Thanks,
Troy
Good Luck
Thanks Gary
Report this Post03-09-2018 12:46 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
...it's actually rotting. When I touch it, it is brittle and just shatters. I assumed that they all suffered this fate...
I've had the front removed off of at least a half dozen Fieros, including one right now, and I've never seen that material get rotten. I wonder if perhaps yours might've had some sort of chemical solution (or gasoline or oil etc) applied to it at some point over the last 30 years to cause this brittleness.
If you have an '88 GT, you'll need a replacement for what you have from any year Fiero with an aero nose.
[This message has been edited by Patrick (edited 03-09-2018).]
GKDINC
Report this Post03-09-2018 01:56 PM Click Here to See the Profile for GKDINCSend a Private Message to GKDINCEdit/Delete MessageReply w/QuoteDirect Link to This Post
The one I have came from a 1987 GT, Sorry no shipping. I may be traveling to Sebring 4-8-18 I will be there between 1-3pm if you want to work something out on that day.
Thanks
Gary
randye
Total ratings: 204
Report this Post03-20-2018 05:50 PM Click Here to See the Profile for randyeClick Here to visit randye's HomePageSend a Private Message to randyeEdit/Delete MessageReply w/QuoteDirect Link to This Post
The "egg crate" support under the GT aero nose should be the same from 87 and 88.
During the rebuild of my 87 GT we used one from an 88 with no fit problem whatever.
OH!, and LTNS Gary! How are you doing?
[This message has been edited by randye (edited 03-20-2018).]
