  Short Stack intercooler radiator
Short Stack intercooler radiator by Bubblhd90
Started on: 04-08-2018 01:23 AM
Replies: 4 (720 views)
Last post by: Dennis LaGrua on 04-12-2018 09:59 AM
Bubblhd90
Report this Post04-08-2018 01:23 AM Click Here to See the Profile for Bubblhd90Send a Private Message to Bubblhd90Edit/Delete MessageReply w/QuoteDirect Link to This Post
We are into a 3800 SC swap with a ZZP short stack kit. We have hit a snag. Where to put the radiator? If anyone has done this or knows of someone who has, could you help us here? 3 core custom radiator installed to cool the 3800.
1986 GT Stock
1987 GT 3800 SC/ original getrag
Total ratings: 329
Report this Post04-08-2018 07:31 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you have the long 8" H 30" long rectangular unit, It mounts very nicely in front of the air dam and below the radiator. Thanks to photosucket the post pictures that I did on the Intercooler install is long gone
hnthomps
Total ratings: 51
Report this Post04-08-2018 08:03 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
My car with a 3800 SC engine and ZZP short stack intercooler is about 175 miles away in the paint shop, but I believe that I used the same location fererenced in Dennis's post. I hope to have the car back in about 30 days but may be able to get a photo prior to that if it is really needed.
Nelson
Bubblhd90
Report this Post04-11-2018 01:10 AM Click Here to See the Profile for Bubblhd90Send a Private Message to Bubblhd90Edit/Delete MessageReply w/QuoteDirect Link to This Post
You fellas were spot on and a big thank you. I fabricated two 1/8" steel brackets and mounted the radiator (it is 31 5/8" long) parallel with the A/C condenser. A third stiffening bracket runs from the bottom center by a clamp back to the engine coolant radiator bottom crossbrace. If I could ask one more question, What is the best method of getting power to the proflo pump when the engine is running?
Total ratings: 329
Report this Post04-12-2018 09:59 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
My intercooler pictures are still here on the forum somewhere. I just added the fix to Firefox that enables viewing of all photobucket pictures once again. Just can't find the detailed install post
