  Windshield Glass Spacer Blocks
Windshield Glass Spacer Blocks by Rodrv6
Started on: 05-16-2018 11:32 AM
Replies: 4 (805 views)
Last post by: Rodrv6 on 05-17-2018 09:31 AM
Rodrv6
Total ratings: 76
Report this Post05-16-2018 11:32 AM Click Here to See the Profile for Rodrv6Send a Private Message to Rodrv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm doing a repaint on my 88 GT. The windshield was previously installed using butyl tape, which appears to have allowed it to settle too far into the opening in the roof panel. (The windshield trim won't fit correctly) I plan to reinstall it using the urethane adhesive that was done originally. According to the shop manual, there are supposed to be some rubber blocks, called glass stops, that maintain the correct spacing. Does anyone know how thick these blocks should be?? Thanks!!
Rod Schneider, Ball Ground, Ga.
"You can't have too many toys!"
1988 Fiero GT
1988 Porsche 928S4
1987 Corvette
2016 Mustang EcoBoost
Van's RV-6 airplane
pmbrunelle
Total ratings: 63
Report this Post05-16-2018 12:29 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Around 1/4" from memory. But don't take my work for it.
Since the roof itself is stuck onto the spaceframe with butyl, the height of the roof may vary depending on the final butyl thickness.
When I re-used the spacer blocks that were already there, the top part of the windshield ended up too low. So, before the urethane set, I salvaged the situation by slightly propping up the windshield from the inside to make the outside of the windshield flush with the roof.
You probably need to test-fit the winshield a few times, and adjust the spacer block thicknesses so the windshield lines up correctly in the roof.
Once you're happy with the positioning, then glue the windshield for real.
[This message has been edited by pmbrunelle (edited 05-16-2018).]
Report this Post05-16-2018 01:01 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
The blocks in my setting tape box are precisely:
.85" Long
.48" Wide
.382" Thick
fierosound
Total ratings: 286
Report this Post05-16-2018 06:07 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Windshield "professionals" throw them away.
I had my GT windshield removed so I could do some cleanup work first. I saved all the spacer blocks.
When they came back to install the new windshield I gave him the spacers and he said "we don't use those".
Even before he tried to install the windshield trim I could see he had fukked it up and set the windshield too deep.
I was on the phone to his managers as soon as he drove away.
A week later I took it to their shop so their guy who works on "special cars" put in another new windshield.
It took a different shop 3 windshields before they got it right on my Indy.
[This message has been edited by fierosound (edited 05-16-2018).]
Rodrv6
Total ratings: 76
Report this Post05-17-2018 09:31 AM Click Here to See the Profile for Rodrv6Send a Private Message to Rodrv6Edit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for the info!
1988 Fiero GT
1988 Porsche 928S4
1987 Corvette
Van's RV-6 airplane
