  Is there a way to get the bright white color back on the coolant overflow tank?
Is there a way to get the bright white color back on the coolant overflow tank? by 2.5
Started on: 05-18-2018 05:20 PM
Replies: 9 (883 views)
Last post by: slicknick on 05-22-2018 11:18 AM
Report this Post05-18-2018 05:20 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
It has yellowed over time...
fierosound
Total ratings: 287
Report this Post05-18-2018 05:45 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
I tried with limited success. I then bought a new one for my Indy...
https://www.fierostore.com/...px?s=66923&d=157&p=1
You could give this method I hadn't seen a try though (hydrogen peroxide)
[This message has been edited by fierosound (edited 05-18-2018).]
Total ratings: 465
Report this Post05-18-2018 09:02 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
I thought it was rather funny that the guy in the video thought the peroxide might rejuvenate the orange plastic. Obviously he's not clear on the concept of bleaching with peroxide!
tshark
Total ratings: 68
Report this Post05-20-2018 08:17 AM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
fierosound
Total ratings: 287
Report this Post05-20-2018 11:25 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by tshark:
Does your TFS coolant tank leak a bit?
If you're asking me about the one I bought - nope.
I also bought the windshield washer reservoir from TFS.
RWDPLZ
Total ratings: 306
Report this Post05-20-2018 12:22 PM Click Here to See the Profile for RWDPLZSend a Private Message to RWDPLZEdit/Delete MessageReply w/QuoteDirect Link to This Post
Just washing them inside and out with dish soap and water will restore a LOT of the color. It won't look like new but it'll be close.
Report this Post05-20-2018 03:11 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can help or not. Same as others above.
Many times weak or no coolant allows rust etc and that can stains the plastic.
Can try "CLR" etc but can attach metal at bottom of OV thank.
Spray/poor some in the tank and move the puddle around avoiding bottom tube.
can try borax based cleaner too. Oxy clean, 20 Mule Team Borax, etc. might take longer to clean.
[This message has been edited by theogre (edited 05-20-2018).]
Total ratings: 328
Report this Post05-20-2018 11:05 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Clorox sloshed around and left to sit overnight may brighten up the reservoir. Rinse the following day and it might improve the look.
Report this Post05-21-2018 11:24 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Where did yours leak?
slicknick
Report this Post05-22-2018 11:18 AM Click Here to See the Profile for slicknickSend a Private Message to slicknickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually, the retr0bright process reduces and removed the leaching of whatever fire retardant that was used in these plastics. So it does help with colored plastic as well. Not so much the sun fading, but It wouldn't bleach a colored plastic that was not otherwise faded.
I don't think it would work well on coolant tanks though. Wrong process, they're more stained than anything.
