  86GT dies
86GT dies by MikieG
Started on: 06-15-2018 06:19 PM
Replies: 4 (292 views)
Last post by: Harold James Kie on 06-21-2018 12:38 PM
MikieG
Report this Post06-15-2018 06:19 PM Click Here to See the Profile for MikieGSend a Private Message to MikieGEdit/Delete MessageReply w/QuoteDirect Link to This Post
Runs fine. Then at light.........dead. Sometimes it restarts right away. Other times it needs a bit. What are common causes. Yes, the check engine light will be on before it happens.
Report this Post06-15-2018 08:01 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Look up the codes and let us know what it is.
https://www.fiero.nl/cgi-bin/main.cgi?ECMCodes
[This message has been edited by Gall757 (edited 06-15-2018).]
MikieG
Report this Post06-18-2018 06:48 PM Click Here to See the Profile for MikieGSend a Private Message to MikieGEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is now in da shop. Next to noone can pull OBD1 codes. Ofcourse, there is alwsys the perennial favorite, the paper clip.
I just decided the man might be a better option at this point.
The car needs 3 start cycles to actually start. Then there is the oil pressure gage issue and lastly, it dies for no good reason. Hopefully i can get to the bottom of this.
Report this Post06-18-2018 07:31 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by MikieG:
It is now in da shop... I just decided the man might be a better option at this point.
With a car of this vintage, often "the man" turns out to be totally out of his element... and it can get expensive paying someone else to work on a 30 year old car (especially if they just start throwing parts at it). I hope this works out for you.
[This message has been edited by Patrick (edited 06-19-2018).]
Harold James Kie
Report this Post06-21-2018 12:38 PM Click Here to See the Profile for Harold James KieSend a Private Message to Harold James KieEdit/Delete MessageReply w/QuoteDirect Link to This Post
I hope you have this fixed by now but just in case, check the metal tube that goes to the bottom of the EGR valve. They are prone to cracking and causing a vacuum leak. It happened on my 86 GT and had the same problem.
