  3800 sc swap question
3800 sc swap question by ceoair
Started on: 06-20-2018 12:37 AM
Replies: 7 (248 views)
Last post by: larafan on 06-20-2018 10:59 AM
ceoair
Report this Post06-20-2018 12:37 AM Click Here to See the Profile for ceoairSend a Private Message to ceoairEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've been researching the 3800 sc engine swap for quite some time but I still cannot find a clear answer to the following questions (have stock v6):
1. Can I use my current transmission, or will I need to replace? (Munchie 4 speed)
2. Any special modifications that need to be done to the engine to fit into the engine bay?
Thank you for your time!
viperine
Report this Post06-20-2018 12:55 AM Click Here to See the Profile for viperineSend a Private Message to viperineEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your Muncie (not your munchies) 4 speed will bolt up with help from a custom flywheel (98 Camaro t5 flywheel machined to .84 at the crankshaft flange and balanced to match your donor 3800 flexplate). You will need a custom wiring harness and a 3800 front engine mount, as well as an alternator relocation, several options exist for the latter. You further need a custom thermostat housing to aid in coolant line routing. Lastly, you need the ECM retuned.
[This message has been edited by viperine (edited 06-20-2018).]
ceoair
Report this Post06-20-2018 01:12 AM Click Here to See the Profile for ceoairSend a Private Message to ceoairEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thank you, that really cleared things up!
Report this Post06-20-2018 07:25 AM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The shift cables for the transmission and the crossover pipe for the engine exhaust occupy the same space.
Custom exhaust work is needed.
crashyoung
Report this Post06-20-2018 09:06 AM Click Here to See the Profile for crashyoungSend a Private Message to crashyoungEdit/Delete MessageReply w/QuoteDirect Link to This Post
When you say the flange is machined to .84", that is from the flange side, and the total flange thickness is .84, or from the face of the flywheel?
larafan
Report this Post06-20-2018 10:39 AM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
When using my 4spd I chose to make a slightly modified shift cable bracket to clear my exhaust rather than change the exhaust. I cut the top off the aluminum bracket and made a steel plate to bolt onto it that mimicked the bracket. I then duplicated the removed portion in steel and weled it to the plate after calculating the slight angle change needed to clear the exhaust crossover pipe well. I then put heat insulator wrap around the cables for extra heat protection. 2 years later, all good.
larafan
Report this Post06-20-2018 10:53 AM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
larafan
Member since Nov 2013
No mods were needed to the engine bay. The engine and trans fit on original mounts with Fierorog bracket at front. I kept my alt in stock location and notched my decklid slightly. The trans stays in stock location and original axles all work. The flywheel is as above, I got mine from fierorog, he does them as well.
larafan
Report this Post06-20-2018 10:59 AM Click Here to See the Profile for larafanSend a Private Message to larafanEdit/Delete MessageReply w/QuoteDirect Link to This Post
larafan
Your question was about mods to the engine. It does require you relocate the coils and modify the bracket they originally mount on. That is well documented in other posts. I mounted mine to the firewall just in front of their original location.
