  purpose buildt Fiero turbo kit
purpose buildt Fiero turbo kit by donj
Started on: 07-27-2018 03:28 PM
Replies: 15 (3551 views)
Last post by: Hudini on 07-31-2018 12:50 AM
donj
Report this Post07-27-2018 03:28 PM Click Here to See the Profile for donjSend a Private Message to donjEdit/Delete MessageReply w/QuoteDirect Link to This Post
Has anyone seen the dedicated turbo kit on E bay?
says that it is made for the Fiero V6( not universal) I was looking for HP, but have no idea how to do a universal kit...........
Price is a grand and change, comments from the knowledgeable people here would be appreciated!
Donj
Is it possible to post pic's here?
Steel
Report this Post07-27-2018 04:03 PM Click Here to See the Profile for SteelSend a Private Message to SteelEdit/Delete MessageReply w/QuoteDirect Link to This Post
Took a quick peek I don't see any kits as you describe. All need exhaust work/crossover/turbo mount fabricated and seem to have mostly cheap korean stuff provided?
But a link would help, maybe I missed the kit you speak of.
Total ratings: 465
Report this Post07-27-2018 04:13 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you're running a Windows PC, use PIP to post images here. Max width - 1024 pixels. Max file size - 300 kb.
Are you referring to This kit? If so, it's hardy Fiero specific. It's listed to fit 1449 different cars!
[This message has been edited by Patrick (edited 07-27-2018).]
donj
Report this Post07-27-2018 05:22 PM Click Here to See the Profile for donjSend a Private Message to donjEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is no pic............
Listed as -pontiac fiero turbo system
Description is follows
this is for a new custom turbo system for the 2.8 pontiac fiero it is a direct fit with everything you need to install it will also fit the 3.4
also if you want any part upgraded just ask i can replace any turbo with gerrett or turbonetics same as wastegate for an additional cost
kit comes with
t3/t4 hybrid turbo
custom header
8# internal wastegate
oil lines
downpipe
turbo specs are as follows
Stage-III Turbo
Oil Cooled Only!
Standard T3 4 Bolt Inlet Flange, Designed to fit most Aftermarket Mainfolds and OEM T3 Manifolds.
5psi to 20 Psi Peak Power Performance Output Capability
Designed with a Standard 5 bolt T3 Flange
Includes internal wastegate port (optional for use)
Compressor Specs :
3" Compressor Inlet
2.130" Inducer
2.755" Major
2" Compressor Outlet
T04B/T4 Type Compressor Housing
Compressor .49 A.R.
Compressor .50 Trim
8 Blade Type T4 Compressor Wheel
Turbine Specs :
T3 Type Turbine flange
T3 5 bolt flange
Turbine .63 A.R.
2.205" Minor and 2.570" Major Propellar
T3 Turbine Housing
2.274" Outlet
12 Blade Type Turbine
pmbrunelle
Total ratings: 63
Report this Post07-27-2018 07:00 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Forum member JCircs tried the $1050 ebay turbo kit. Read about his experiences here:
https://www.fiero.nl/cgi-bin...orum=1&thread=090206
https://www.fiero.nl/cgi-bin...orum=2&thread=139477
Reliable speed is expensive... it'll take a bunch more than $1050 to get rolling.
Total ratings: 465
Report this Post07-27-2018 07:04 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Listed as - pontiac fiero turbo system
Here
These kits aren't exactly flying off the shelf. The last one they sold was in 2013.
donj
Report this Post07-28-2018 09:21 AM Click Here to See the Profile for donjSend a Private Message to donjEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well I looked all of the info links and still have no idea ..............
lots of discussion on whats in the kit and what isn't, did the individual from the forum ever post his results with the kit and was it any good?
inquiring minds want to know!
armos
Report this Post07-28-2018 09:43 AM Click Here to See the Profile for armosSend a Private Message to armosEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm skeptical of doing a turbo without making changes to the ECM.
The 1227170 ECM used on the 86-88 V6 cars doesn't support a knock sensor, so that rules it out IMO. I think the 1985 V6 ECM does support knock sensor but the factory didn't utilize it. Don't know if either of them has any issues with a 2-bar MAP sensor that a turbo tune would require.
I don't know which ECMs are best suited to a turbo, but a turbo build should probably upgrade it to something from the early 90s that has more speed, resolution, feature support, and present-day internet tuning knowledge than either of the stock Fiero ECMs.
There was a Sunbird Turbo (4cyl) of course. No idea how suitable it would be, but I'm guessing a later ECM would be better.
Doesn't look like the kit mentions injectors - stock ones won't flow enough.
[This message has been edited by armos (edited 07-28-2018).]
fierosound
Total ratings: 287
Report this Post07-28-2018 10:59 AM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
'85 ECM will work, but needs PROM needs reprogramming for 2 BAR MAP, knock sensor and fueling of course.
Information https://www.fiero.nl/forum/A...050119-2-054278.html
[This message has been edited by fierosound (edited 07-28-2018).]
pmbrunelle
Total ratings: 63
Report this Post07-28-2018 06:22 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
That turbo kit can be viewed as a key ingredient of a turbo install, but not the entire recipe. It is a big chunk though.
I am doing a turbo project, and I will be using the knock module recommended in the previous post, but with a MegaSquirt 3.
[This message has been edited by pmbrunelle (edited 07-28-2018).]
donj
Report this Post07-28-2018 07:46 PM Click Here to See the Profile for donjSend a Private Message to donjEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since I am getting no where with this, how about High Performance Intake Manifold west coast Fiero's.
As to the turbo..... one of the members supposedly bought one, and I am assuming that he installed it what was the outcome!
[This message has been edited by donj (edited 07-28-2018).]
Total ratings: 328
Report this Post07-28-2018 08:46 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am familiar with the guy that installed that kit. The results were not satisfactory but f he sees this I will allow him to speak for himself.
RudyGT
Report this Post07-28-2018 11:36 PM Click Here to See the Profile for RudyGTSend a Private Message to RudyGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
this is his summarization
"My eBay turbo update. It's been about 10 months since I purchased the turbo kit and although it had issues it did work, and it made a difference in power but it wasn't perfect. It lacked the power it should have been producing, it had way to much lag and the turbo wasn't balanced properly and caused a minor vibration. For most normal people it would have been fine but I'm far from normal, a perfectionist with a little OCD, long story short... Every piece of the eBay kit is now in the garbage, I purchased a Precision 58mm billet Turbo and wastegate and had it installed on new improved header pipe and 3" V band stainless exhaust all custom made by AMS Autowerks here in NJ. Along with the meth kit it's now dialed up to 10psi and the boost is immediate, it feels smooth and strong and sounds even better then before. In short, you get what you pay for."
but that doesnt include all the tuning and working with the guy to get it right, also in that thread a guy said his came dented and damaged and was waiting a year for replacement.
i thought about it myself but it doesnt seem worth it, better to scavenge a junk yard i guess.
Total ratings: 328
Report this Post07-29-2018 07:02 AM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
For anyone wishing to add a turbo to their 2.8L or 3.4L P/R engine Fiero be advised that you will need a re-scaled timing table in the ECM and some new power enrichment settings to get it to work properly. Its a tricky tuning process that few have perfected. It's much easier to do this on an a PCM with an OBD II program already set up for boost. Bolting on a turbo kit for more horsepower is just not the answer. The tuning is critical.
Joseph Upson
Total ratings: 88
Report this Post07-29-2018 07:43 AM Click Here to See the Profile for Joseph UpsonSend a Private Message to Joseph UpsonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by RudyGT:
...better to scavenge a junk yard i guess.
That's the approach many here took, working with OE used parts you at least have the advantage of starting with quality and durability. Without explicit details and some proof, anything goes on ebay. I take it he has a manual shift car because there's no way a stock Fiero 3 speed auto is going to hold up to that power increase, at least mine never did beyond 2nd gear.
Hudini
Total ratings: 165
Report this Post07-31-2018 12:50 AM Click Here to See the Profile for HudiniSend a Private Message to HudiniEdit/Delete MessageReply w/QuoteDirect Link to This Post
I cobbled together a T3 from a 1983 Ford Turbocoupe on a custom crossover manifold. The engine is controlled by a 7730 ECM running code59 with a 3 bar MAP sensor. Amazing power but as Joseph experienced it trashed my TH125c quickly.
I wouldn't trust Ebay with anything. Everything I purchased for my build turned out to be junk. Fuel pressure regulators, blow off valves, etc. Buy name brand and don't cheap out like I did. You end up paying twice as much.
