  fiero tach issue 85 2.5L
fiero tach issue 85 2.5L by Ehill85
Started on: 08-14-2018 01:07 PM
Replies: 3 (779 views)
Last post by: phonedawgz on 08-19-2018 10:57 PM
Ehill85
Report this Post08-14-2018 01:07 PM Click Here to See the Profile for Ehill85Send a Private Message to Ehill85Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'm new to anything involving fieros just a fore-warning to anything stupid I might say. I purchased a 1985 2.5L fiero and my tach used to work but now it doesn't work at all. I looked behind the dash and can't find any bad connections. can't locate the mysterious tach filter either
fierosound
Total ratings: 286
Report this Post08-14-2018 02:25 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
It should be in the area around the thermostat housing and distributor.
The diagram shows it as bolted to a head bolt stud.
It may be inside the harness wrap.
[This message has been edited by fierosound (edited 08-18-2018).]
EmilioD
Report this Post08-19-2018 06:53 PM Click Here to See the Profile for EmilioDSend a Private Message to EmilioDEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had the same problem some years back a new filter should solve this issue as it did for me at that time I got the new filter from Rodney Dickman but I understand the Fiero Store has it as well not expensive Item probably shipping and handling cost as much as the filter. I hope this helps Oh i forgot replacing the filter is less than 2 minutes really easy.
Good Luck
Emilio D.
Total ratings: 291
Report this Post08-19-2018 10:57 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Before replacing the tach filter test it first. Unplug the filter and just short between the two terminals. If the tach comes to life, the filter is bad. If not suspect a bad tach board. I do sell replacement tach boards. $79.00 for the board and add $15 to add a low fuel light.
email me at gofast@reddevilriver.com if interested.
