  Fiero weights from the scales at The 35th Anniversary
Fiero weights from the scales at The 35th Anniversary by 2.5
Started on: 08-16-2018 01:56 PM
Replies: 13 (1370 views)
Last post by: tshark on 08-31-2018 06:01 PM
Report this Post08-16-2018 01:56 PM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Found these on facebook posted by Schwa
Keep in mind the fuel level. I assume since 1/2 is half tank, 3/4 is three quarters full, 1/1 would be full?
I have read that a gallon of gas weighs approx 6 lbs.
Fiero Weight Compilation by Schwa MotorSports
Car, Engine, Transmission, Fuel Level, AC?, Bat. Location, Misc, Total Weight
86 GT 3400 Muncie 4sp 1/1 No Front Tube Rear End, Turbo, Stripped HVAC, Upgraded wheels 2466
87 GT 3800SC? Getrag 1/2 No Rear No HVAC, No Wipers 2554
84 SC 2.5 th125 3/4 No Front Convertible 2563
87 Coupe 2.5 Isuzu 5sp 1/4 Yes Rear “20#” of tools in back 2623
84 Coupe 2.8 Muncie 4sp 1/2 Yes Rear Base Coupe with 2.8 Swap 2645
86 Coupe 3.4 PR Isuzu 5sp 3/4 Yes Rear 2707
86 SE 4.9 F23 3/4 Yes Front 2745
86 SE 2.8 Muncie 4sp 1/2 Yes Rear Grand Am Seats 2759
88 Coupe 3400 Turbo Isuzu 5sp 1/1 No Front Widebody, 13” rotors, Turbo w/ Intercooler, Fastback 2766
88 Formula 2.8 Getrag 1/2 Yes Rear Stock T-Tops 2779
85 GT 3800SC Isuzu 5sp 1 No Rear Integrated Rockers 2783
86 GT 2.2 Ecotec F23 1/1 No Front Turbo, A2W Intercooler, Wilwood 2789
84 Coupe 3800SC Isuzu 5sp 1 No Rear Spoiler 2800
88 GT 2.8 Getrag 1/2 Yes Rear Stock Hardtop 2805
85 GT 3.4pr Getrag 1/2 Yes Rear Nitrous Bottle in Trunk, Fastback Conv. 2806
88 Coupe LS4 F40 1/1 Yes Front 2807
86 SE 2.8 Muncie 4sp 1/1 Yes Rear 40lbs tools in rear 2807
88 Formula 2.8 Getrag 1/1 Yes Rear 10lbs of Tools 2815
87 GT 2.8 Getrag 1/2 Yes Rear All options expect Power Mirrors 2816
88 Coupe 3900 Getrag 1/1 Yes Rear 18/19 Wheels, 12” rotors 2818
87 GT 3800SC Muncie 4sp 3/4 No Front Upgraded Wheels 2820
84 283 4t60 1/1 No Front Iron Block and Heads 2823
85 Coupe 3800 4T60 1/2 Yes Front Grand Am Brakes, Bigger wheels 2833
86 GT 2.8 Getrag 1/2 Yes Front Ga Brakes, Hitch, Rear Sway 2836
87 GT 2.8 Getrag 1/1 Yes Rear 87 GT Stock 2838
86 GT 3.4 PR Isuzu 5sp 3/4 Yes Rear W/ Spare, 88 Suspension front and rear 2839
86 GT 2.8 Getrag 1/2 No Rear Extensive Body Mods, Dual Throttle Intake 2846
87 GT 3400 SFI Getrag 1/2 No Rear Train Horn w/ Comp in Front 2847
88 Coupe 2.5 Isuzu 5sp 1/2 Yes Rear Grand Am Wheels, Flush Mount Headlights, SuperCharger and Carb 2848
86 GT 2.8 Muncie 4sp 3/4 Yes Rear Front Spoiler 18” Wheels 2853
88 Formula 2.8 Getrag 1/1 Yes Rear P/W P/L and Sunroof 2855
86 SE 3800SC Muncie 4sp 1/1 Yes Rear Bigger wheels and tire, Trunk full 2865
88 GT 2.8 th125 1/2 Yes Rear Stock T-Tops 2905
88 GT 2.8 th125 1/4 Yes Rear Lebanon Brakes 2912
85 GT 355 Getrag 3/4 Yes Front Alum Heads and Intake 2913
86 GT 3800SC 4t65e-HD 3/4 Yes ? 2916
87 GT 3800SC 4t65e-HD 1/8 No Rear Intercooler, Headers, Upgraded Wheels 2920
88 GT 3800SC Getrag 5/8 No Rear Some Stuff in Frunk 2933
88 3800SC Getrag 1/1 Yes Front Chop top, Widebody, 14” multi piston brakes 2936
88 GT 3.4 PR 4T60 1/2 Yes Rear Body Mods, Upgraded Wheels 2968
40 88 Formula 4.9 4t60e 1/2 Yes Front Upgraded Calipers w/ 12” rotors, Tools in Frunk 2975
87 GT 3800SC Getrag 1/1 No Front Intercooled 3010
87 GT 350 Vortec TPI 4t60 1/4 Yes Front Iron Block and Heads 3027
87 GT V8 305 TPI Getrag 3/4 Yes Front Grand Am Brakes, Iron heads 3050 * my car, more info: rear sway bar, amp up front, aluminum rad, 87 transam seats, 5lb car care stuff, no spare tire.
88 Mera 3800SC Getrag 1/2 Yes Front SS Intercooler, Slalom Front End, 12” brakes, 20lbs in Trunk 3066
87 GT Northstar 4t80e 3/4 Yes Front Power Steering 3068
88 Formula V8 TPI F40 1/2 Yes Front Corvette Brakes, Aluminum Heads, 30lbs of Tools 3072
86 GT 3.1 4t60e 7/10 Yes Rear 3076
84 Indy Northstar 914 5 Speed 1/4 Yes Rear 12” Stretch, Lots Custom 3076
88 GT 3800SC Getrag 1/2 Yes Rear T-Tops Intercooled (Skitime) 3083
88 GT 3800SC 4t65e-HD 7/8 Yes Rear 3085
87 GT 3800SC Getrag 1/2 Yes Front Custom Body Parts 3086
85 GT Northstar 4t80e 12ga Yes Behind Trunk Scorpion, 11.25 Brake, Fuel tank in Front 3125
84 Coupe 455 Olds th425 1/1 No Front Blown and Intercooled 3937
[This message has been edited by 2.5 (edited 08-16-2018).]
Crasian
Report this Post08-16-2018 10:37 PM Click Here to See the Profile for CrasianSend a Private Message to CrasianEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was reading the list and finally read the very last car. 455, blown, and intercooled? Really? Anyone got pics of that thing? I’m a GTO (original) nut and have always wanted to put a 455 Poncho in one of these Fieros.
[This message has been edited by Crasian (edited 08-16-2018).]
cvxjet
Report this Post08-17-2018 12:45 AM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I had my 1985 SE V6 weighed with; 3.4 F-body engine, getrag 5spd, 88 rear subframe/suspension, and 86-88 GT rear quarters(Without ground effects)...No A/C, PW, PM, PL ,and the battery is up front. Total weight was 2640 with a 43.5/56.5 weight distribution.....Oh yeah, I have a tool kit, spare IM and coil, and a gallon of coolant up front. The accuracy would be pretty good,....the scales were for weighing vehicles before placing them on C-130s......
I do not know what the fuel level was...I was more interested in distribution.....After adjusting the rear coil-overs, I had 570 lbs on each front tire and 750 lbs on each rear.
Do a search for 455 Fiero and there is an orange one with the engine taking up the whole rear of the car....No trunk, and I would suggest the weight dist' would be worse than 40/60......
[This message has been edited by cvxjet (edited 08-17-2018).]
Report this Post08-17-2018 10:10 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hmm that car wasn't at the 35th, the orange 455 car with the olds trans was at the 30th. Maybe this is a combo list from both shows.
A 2012 vid
[This message has been edited by 2.5 (edited 08-17-2018).]
wftb
Report this Post08-18-2018 08:21 AM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
My car is the 86 GT with 2.2 ecotec. It was weighed at the 30th show, I did not make the 35th. I have since shed some weight by getting rid of the muffler and tearing out most of the AC stuff . Car now weighs 2746 lbs.
[This message has been edited by wftb (edited 08-18-2018).]
Total ratings: 259
Report this Post08-18-2018 10:12 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here is the list with the format cleaned up some:
code:
Weight Year Model Engine Trans Fuel A/C Bat Other Notes
2466 86 GT 3400 Muncie 1/1 No Front Tube Rear End, Turbo, Stripped HVAC, Upgraded wheels
2554 87 GT 3800SC Getrag 1/2 No Rear No HVAC, No Wipers
2563 84 Coupe 2.5 TH125 3/4 No Front Convertible
2623 87 Coupe 2.5 Isuzu 1/4 Yes Rear “20#” of tools in back
2645 84 Coupe 2.8 Muncie 1/2 Yes Rear Base Coupe with 2.8 Swap
2707 86 Coupe 3.4 PR Isuzu 3/4 Yes Rear
2745 86 SE 4.9 F23 3/4 Yes Front
2759 86 SE 2.8 Muncie 1/2 Yes Rear Grand Am Seats
2766 88 Coupe 3400 Isuzu 1/1 No Front Widebody, 13” rotors, Turbo w/ Intercooler, Fastback
2779 88 Formula 2.8 Getrag 1/2 Yes Rear Stock T-Tops
2783 85 GT 3800SC Isuzu 1/1 No Rear Integrated Rockers
2789 86 GT 2.2 Eco F23 1/1 No Front A2W Intercooler, Wilwood
2800 84 Coupe 3800SC Isuzu 1/1 No Rear Rear Spoiler
2805 88 GT 2.8 Getrag 1/2 Yes Rear Stock Hardtop
2806 85 GT 3.4 Getrag 1/2 Yes Rear Nitrous Bottle in Trunk, Fastback Conversion
2807 86 SE 2.8 Muncie 1/1 Yes Rear 40lbs tools in rear
2807 88 Coupe LS4 F40 1/1 Yes Front C4 seats, 13" Rotors, rear spoiler, rear sway bar
2815 88 Formula 2.8 Getrag 1/1 Yes Rear 10lbs of Tools
2816 87 GT 2.8 Getrag 1/2 Yes Rear PW/PL
2818 88 Coupe 3900 Getrag 1/1 Yes Rear 18/19 Wheels, 12” rotors
2820 87 GT 3800SC Muncie 3/4 No Front Upgraded Wheels
2823 84 Coupe SBC 4T60 1/1 No Front 283 Iron Block and Heads
2833 85 Coupe 3800 4T60 1/2 Yes Front Grand Am Brakes, Bigger wheels
2836 86 GT 2.8 Getrag 1/2 Yes Front Ga Brakes, Hitch, Rear Sway
2838 87 GT 2.8 Getrag 1/1 Yes Rear Stock
2839 86 GT 2.8 Isuzu 3/4 Yes Rear W/ Spare, 88 Suspension front and rear
2846 86 GT 2.8 Getrag 1/2 No Rear Extensive Body Mods, Dual Throttle Intake
2847 87 GT 2.8 Getrag 1/2 No Rear Train Horn w/ Comp in Front
2848 88 Coupe 2.5 Isuzu 1/2 Yes Rear Grand Am Wheels, Flush Mount Headlights, SuperCharger and Carb
2853 86 GT 2.8 Muncie 3/4 Yes Rear Front Spoiler 18” Wheels
2855 88 Formula 2.8 Getrag 1/1 Yes Rear P/W P/L and Sunroof
2865 86 SE 3800SC Muncie 1/1 Yes Rear Bigger wheels and tire, Trunk full
2905 88 GT 2.8 TH125 1/2 Yes Rear Stock T-Tops
2912 88 GT 2.8 TH125 1/4 Yes Rear Lebanon Brakes
2913 85 GT SBC Getrag 3/4 Yes Front 355, Alum Heads and Intake
2916 86 GT 3800SC 4T65HD 3/4 Yes
2920 87 GT 3800SC 4T65HD 1/8 No Rear Intercooler, Headers, Upgraded Wheels
2933 88 GT 3800SC Getrag 5/8 No Rear Some Stuff in Frunk
2936 88 GT 3800SC Getrag 1/1 Yes Front Chop top, Widebody, 14” multi piston brakes
2968 88 GT 3.4 PR 4T60 1/2 Yes Rear Body Mods, Upgraded Wheel
2975 88 Formula 4.9 4T60E 1/2 Yes Front Upgraded Calipers w/ 12” rotors, Tools in Frunk
3010 87 GT 3800SC Getrag 1/1 No Front Intercooled
3027 87 GT SBC 4T60 1/4 Yes Front 350, Iron Block and Heads
3050 87 GT SBC Getrag 3/4 Yes Front 305, Grand Am Brakes, Iron heads, rear sway bar, amp up front, transam seats, 5lb car care stuff, no spare tire.
3066 88 MERA 3800SC Getrag 1/2 Yes Front SS Intercooler, Slalom Front End, 12” brakes, 20lbs in Trunk
3068 87 GT N* 4T80 3/4 Yes Front Power Steering
3072 88 Formula SBC F40 1/2 Yes Front 350, Corvette Brakes, Aluminum Heads, 30lbs of Tools
3076 86 GT 3.1 4T60E 7/10 Yes Rear
3076 84 INDY N* 914 5sp 1/4 Yes Rear 12” Stretch, Lots Custom
3083 88 GT 3800SC Getrag 1/2 Yes Rear T-Tops Intercooled (Skitime)
3085 88 GT 3800SC 4T65HD 7/8 Yes Rear
3086 87 GT 3800SC Getrag 1/2 Yes Front Custom Body Parts
3125 85 GT N* 4T80 1/2 Yes Rear Scorpion, 11.25 Brake, Fuel tank in Front
3937 84 Coupe 455 TH425 1/1 No Front Blown and Intercooled
Just the 88s and cars with 88 suspension:
code:
Total ratings: 206
Report this Post08-18-2018 12:24 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I didn't get mine weighed at the 35th, but I weighed it about a month before.
Formula, 4.9/4T60e, front battery, no power accessories, 1/2 tank
2900#
[This message has been edited by olejoedad (edited 08-18-2018).]
Total ratings: 328
Report this Post08-18-2018 04:51 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Absolutely great info and its good to know that the aluminum block 4.9L Cadillac doesn't add much weight.
Rexgirl
Report this Post08-19-2018 02:54 AM Click Here to See the Profile for RexgirlSend a Private Message to RexgirlEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you wish you can add:
1987 SE based Mera, 2.8, Getrag, 1/2 tank, A/C, battery rear, Stock T-tops - 2835 lbs
FIER086
Report this Post08-19-2018 12:39 PM Click Here to See the Profile for FIER086Send a Private Message to FIER086Edit/Delete MessageReply w/QuoteDirect Link to This Post
Here's mine:
1987 GT 3800SC- No A/C- Battery up front-No spare-Stock wheels and brakes-Headers-Getrag-Full tank of gas-2800lbs
Buck531
Report this Post08-21-2018 07:45 AM Click Here to See the Profile for Buck531Send a Private Message to Buck531Edit/Delete MessageReply w/QuoteDirect Link to This Post
This was mine:
Running on fumes. (I put 11 gallons of gas in the next day). Trans is a non HD and the upgrade wheels are just Beretta GTZ 16's. not sure what is meant by rear intercooler. The IC is in back but my tank is up front (holds a gallon of coolant).
2018-08-21_07-39-23 by Shawn Bucklad, on Flickr
2018-08-21_07-39-48 by Shawn Bucklad, on Flickr
03 Buick Regal. 13.0x @103
87 Fiero GT. L67, XP, Ported heads, SD headers, FSIC, 2.8 pulley. 12.1@111 1.7 60'.
Seelenfresser
Report this Post08-25-2018 08:42 PM Click Here to See the Profile for SeelenfresserSend a Private Message to SeelenfresserEdit/Delete MessageReply w/QuoteDirect Link to This Post
Sad that I missed it, had planed on going but every part i took off showed something else i had to replace.
longjonsilver
Report this Post08-31-2018 05:47 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i understand that at least at the 30th the guy that weighed the cars weighed each wheel. It would be interesting to know the front/rear weight distribution.
jon
[This message has been edited by longjonsilver (edited 08-31-2018).]
tshark
Total ratings: 68
Report this Post08-31-2018 06:01 PM Click Here to See the Profile for tsharkSend a Private Message to tsharkEdit/Delete MessageReply w/QuoteDirect Link to This Post
