  2.8 compression, not compression ratio? Both wet and dry.
2.8 compression, not compression ratio? Both wet and dry. by dratts
Started on: 08-21-2018 01:38 PM
Replies: 1 (145 views)
Last post by: theogre on 08-21-2018 05:29 PM
dratts
Total ratings: 118
Report this Post08-21-2018 01:38 PM Click Here to See the Profile for drattsSend a Private Message to drattsEdit/Delete MessageReply w/QuoteDirect Link to This Post
I can't find it in the search. I have a 2.8 hat is only reading 60-75 lbs dry. It is supposed to have only 10,000 miles since a rebuild and was sitting for 6 months.
Report this Post08-21-2018 05:29 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
is it in the car?
Battery is full charge to run starter?
All spark plugs out?
Throttle at WOT and remove air filter?
If those number are accurate the engine have big problems.
Most normal car engines run ~ 110-130 psig dry, a little more wet, and all should be close to same number. Bigger problems as top and bottom numbers get wider and wider.
"Spec" is 14.7(1 Standard Atmosphere) × CR (the compression ratio) = x PSIG IOW 14.7 × 8.5 = 124.95 to give you a target.
(Metric 1 bar or 101KPa × CR = x bar/KPa for testing this depending on gauge used.)
GM allows low number to 80%+ at 200rpm of the highest number but closer is better. Min test pressure is 100psi for all 1982-90 gas engines. (from Alldata.)
If high is 124.95 then 80% is 99.94 and you technically fail testing.
Many other books say 15-20 psi max spread.
[This message has been edited by theogre (edited 08-21-2018).]
