Hey Kevin and everyone else helping out, I helped work on Kevin's car last year so if it helps here's a little more info.
He started out with an 85 with power trunk release with the wire in the engine harness. His engine gave up the ghost so we brought it to my place for a swap. He had an event to get to after the weekend so we did the swap Roadkill style. By that I mean we did it in a weekend and then he drove off in it for a several hour drive with minimal testing. In our haste we kept the wiring harness from the donor which was an 86, not realizing the decklid switch was not in that harness. So he headed out without decklid power. Later the decklid was switched to one with no power option.
So he has all the needed components in the cab. Switch, relay and what not. What needs to be done is put the wire in the decklid and then figure out which pin in the harness needs to have the actuator wire. Or any way that can be wired in, C500 or C203? I'm out of the country now, otherwise I would try to offer more help on the matter.
-Jason
[This message has been edited by liv4God (edited 09-06-2018).]
