During my engine rebuild, I found that the hole in my charcoal canister mount is "stripped".
The factory sheetmetal screw no longer bites in the hole:
Hence I have decided to drill (don't know how large yet) out these holes and use U-nuts instead.
I picked up this package from Canadian Tire:
They have a spring-loaded tang.
I want to know what is the proper hole diameter (in the panel) for use with U-nuts of this style.
I am presently imagining two possible hole sizes, which I have named A and B:
A:
Large enough to allow the screw to pass through, but the tang does not fall into the hole. The tang maintains a constant squeeze on the panel.
B:
Large enough for the tang to snap into the hole... this kind of "clips" the U-nut into place, making it semi-captive.
Which of these methods is the correct one?
