  What causes oil pressure/antifreeze temperature warning light to light up?
What causes oil pressure/antifreeze temperature warning light to light up? by Fiero.1984
Started on: 10-17-2018 07:29 PM
Replies: 5 (164 views)
Last post by: Gall757 on 10-18-2018 10:32 AM
Fiero.1984
Report this Post10-17-2018 07:29 PM Click Here to See the Profile for Fiero.1984Send a Private Message to Fiero.1984Edit/Delete MessageReply w/QuoteDirect Link to This Post
The warning light shows an oil pressure and antifreeze temperature warning. Does anyone knows what oil pressure and/or antifreeze temperature causes the warning light up? I had an antifreeze leak and the light came on but the temperature gauge did not show a high antifreeze temperature (less than 160). My chief concern is that something else might be causing the warning light.
Thanks
Report this Post10-17-2018 08:29 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Are you talking about one light or two?
Fiero.1984
Report this Post10-17-2018 10:17 PM Click Here to See the Profile for Fiero.1984Send a Private Message to Fiero.1984Edit/Delete MessageReply w/QuoteDirect Link to This Post
There is only one light for both.
Report this Post10-18-2018 09:44 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Is this a stock Fiero? What year / model and engine, etc?
Oil would light up when oil level (pressure) is low, I am not aware of an oil temp warning?
When the coolant level is low the light will come on. When the coolant temp is way too high it may come on.
[This message has been edited by 2.5 (edited 10-18-2018).]
Report this Post10-18-2018 10:07 AM Click Here to See the Profile for 2.5Send a Private Message to 2.5Edit/Delete MessageReply w/QuoteDirect Link to This Post
Member since May 2007
Looks like you are talking about this light setup, which I haven't ever owned...
On some cars that is where the battery light is, and the temp light for the radiator is to the left of it.
I have only had 86 2m4s, 88 Formula, and 87 GT.
Report this Post10-18-2018 10:32 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
That light was only in '84. I am guessing the sensor input must be the same as later years. Oil pressure would have to go below 5 Lbs. or coolant temp above about 245 degrees F.
[This message has been edited by Gall757 (edited 10-19-2018).]
